Old 05-31-2008, 07:14 PM   #1
turn signal relay question
hey guys, my97 240sx turn signal and flasher both not working, im pretty sure its the flasher relay i went to the fuse box by driver side seat i saw 1 row of 4 relays from top to bottom 3 on top is blue one on buttom is brown, which one is the flasher relay? thanks
sl0westz is offline   Reply With Quote
Old 06-01-2008, 01:54 AM   #2
projectRDM's Avatar
The flasher is hanging off a bracket by the SECU, near the steering column.
FORMERLY R240NA
Old 06-01-2008, 01:57 AM   #3
makulit054's Avatar
check your fuses.
makulit054 is offline   Reply With Quote
Old 11-03-2009, 09:31 PM   #4
driftpolice's Avatar
i have this same question. i checked my fuses and they look good.
driftpolice is offline   Reply With Quote
Old 11-03-2009, 11:09 PM   #5
E Double's Avatar
mine used to freeze in the "on" position. turned out it was the relay. as already stated, i would check it out
E Double is offline   Reply With Quote
Old 11-03-2009, 11:30 PM   #6
on a side question - not trying to jack it but since we are on blinkers and i can't seem to find my answer anywhere, which color wire is the flashing function and which is the stationary parking one? I have an s13 just trying to wire my 180sx blinkers. Thanks
blue rexsti is offline   Reply With Quote
Old 11-04-2009, 01:00 PM   #7
is the relay in question the yellow one that says tjr?
Old 11-04-2009, 02:46 PM   #8
E Double's Avatar
mine was black
Old 11-05-2009, 08:05 AM   #9
projectRDM's Avatar
It's black. I've never seen a yellow relay anywhere in any Nissan vehicle.
FORMERLY R240NA
Old 11-05-2009, 08:37 AM   #10
yeah beleive there is a yellow box next to the relay however. any idea what that controls?
Old 11-05-2009, 08:39 AM   #11
AFC #1
S14DB's Avatar
Yellow one is the door chime not a relay.
Also, check your hazard flasher switch. I found out the hard way that you need this installed to use your turn signals.
Comments should be taken as Opinions not as Statements of Fact.
Old 11-05-2009, 10:13 AM   #12
nothix's Avatar
My S13 had a fast blinker, turned out to be a wire that fell out of the plug in the front.
Fixed the plug and it worked perfect for inspection.
Now it seems that the same bulb is burnt =(
2003 350z | 1995 Altima | 1989 240sx
nothix is offline   Reply With Quote
SEO by vBSEO 3.3.0
