Old 05-28-2008, 03:28 PM   #31
steve shadows's Avatar
You run the sensor right after the turbo ala 02 location?
What happened to all that talk about running the wideband sensor 18" or whatever down stream from the turbo?
for 100 yards? or one dyno pull its fine if you have stock turbo elbow.
Otherwise put it AT LEAST 18 inches to 1 METER away from the turbine wheel.
If you can weld in a bung. But just for death check on engine you can shove it in the elbow (if you have the fat 02 thread) and check it for one or two pulls down the street.
It's heat that kills widebands, so you should use a heat sink if your using them for extending periods of time (ie daily driving, race track etc).
Like Us on FaceBook !
http://shadowerks.com Remote Tuning and Base Map Services
Old 05-28-2008, 03:46 PM   #32
Yeast
!Zar!'s Avatar
Hmm.
Ok.
<3
Old 03-19-2009, 12:25 PM   #33
95KA-Turbo's Avatar
I know this is an old thread, but I like it when I search for things to have all of the answers in one place.
I just got a baseline dyno for my S14 SR20 - which, as you know, has a 'T28' turbo and 370cc injectors factory.
Baseline dyno before the cams go in:
The red is ~14psi and the blue is ~12psi....the air:fuel is too shady on the 14psi so 12psi is were it is staying, haha. This is SAE corrected and on a dynojet dyno.
This is a stock S14 SR20 with HKS filter, random jdm tubular manifold, 3" elbow/downpipe/cat and Trust DD exhaust (for NA SR), as well as an Evo 8 intercooler mounted in front of the radiator for super short intercooler pipes.
From the looks of the a:f on the red top, the S14 MAF/ECU is better equipped for higher boost on the stock turbo at higher RPMs (which always seemed obvious to me but now it is documented proof).
My Blog - knoop.sumospeed.com
95KA-Turbo is offline   Reply With Quote
Old 03-19-2009, 12:58 PM   #34
slider2828's Avatar
There is a thread in this section for 2871r's but has all the tech specs and thread you are looking for.... Man that looks a little lean at some points...
What part of the MAFS are you looking at? MAFS is measured in Voltage and thats what it is a measurement to meter air nothing more.... So in order to tell what your mafs is doing, you have to look at the Voltage for AirIn... which a dyno won't tell you.
Turn and Burn!
Old 03-19-2009, 01:15 PM   #35
ROIDMONKEY's Avatar
what r u waiting to get injectors.. u got all the other mods and running 370cc!!! NOOOOOO go get 740cc NOW and a stand alone ecu
TRUE thing: True ////OFFSET\\\\ is acheived without spacers
Running on E85 570whp Precision 5862....laggy as fuck. hate it
ROIDMONKEY is offline   Reply With Quote
Old 03-19-2009, 02:01 PM   #36
95KA-Turbo's Avatar
S14 SRs come with 370s...the motor is stock (minus FMIC, intake and exhaust). I just always wanted to compare a S14 SR to a S13 with T28, and this thread had the S13 info so I was just adding the S14 stuff.
740s are overkill for my stock turbo/easy cams/basically everything I have on the car. I also can't afford stand alone right now, so I'll probably get e-manage and some S15 injectors and work with that.
Old 03-19-2009, 02:05 PM   #37
slider2828's Avatar
At 14 psi bro you are running close to 100% Injector Duty Cycle. that is what he is talking about... you should know better.... Bad example
Turn and Burn!
Old 03-19-2009, 02:25 PM   #38
ROIDMONKEY's Avatar
not overkill AT ALL always more than u gonna need near future. u can always adjust for whatchu need dude.
i was running a T28(s15) with 740cc nismo. no problem. i made a bit over 300WHP
Old 03-19-2009, 02:38 PM   #39
95KA-Turbo's Avatar
I guess I should point out I run 10-12psi regularly and that the dyno was just to see what the air:fuel looks like. I don't believe my boost gauge is extremely accurate so right now it reads ~10psi, so I assume it could be 11 or 12psi (because when I take the boost controller off it reads 5-6psi rather then 7). On the dyno runs the boost gauge read 12psi and 14psi....so those numbers could technically be from 14 and 16psi. The face of my boost gauge is convex so it looks different from different angles....not ideal but I use it to make sure I'm running around where it should be - rather then spiking up at 20psi, etc.
Again to clarify, I don't run the car at 14psi! It would be a short lived motor otherwise. I just wanted to directly compare it to the red top in this thread.
Old 03-24-2009, 04:16 PM   #40
Boost LeRoy
blksylv's Avatar
im also gonna be running an s13 sr w a t28 and how would 550s, z32 maf and a safc fair, dont really have enough cash for a standalone at the moment, would that be safe for the moment, i also have an aem wideband
Originally Posted by Teddy View Post
If you are having difficulty choosing between a Super Advan and a Varrstoen I highly suggest you sell your car, and die.
blksylv is offline   Reply With Quote
Old 03-25-2009, 08:49 AM   #41
Boost LeRoy
blksylv's Avatar
anyone......
Old 03-25-2009, 09:41 AM   #42
G240's Avatar
You probably would be better of with the Stock MAF and low boost before trying to run a Z32 MAF untuned. I really don't know enough of the SAFC to say if it would compensate for the Z32 MAF. Better to be safe than sorry.
BTW are you tuning it yourself with the SAFC or having a tuner do it? Also do you have an upgraded fuel pump and a FPR? Just curious
G240 is offline   Reply With Quote
Old 03-25-2009, 10:08 AM   #43
Boost LeRoy
blksylv's Avatar
i would probably be doing it myself for the moment until i got a chance to hit a dyno with it, itll also have a 255 walbro on it, the safc will allow me to run the z32
Old 03-25-2009, 12:11 PM   #44
G240's Avatar
How about a FPR?
If you feel comfortable messing with the SAFC and it WILL compensate for the Z32. I would think the only issue at this point is making sure you have enough fuel so that you don't lean out.
Good Luck.
Old 03-25-2009, 12:24 PM   #45
Boost LeRoy
blksylv's Avatar
was goin to stick with the stock one but i was hoping the 550s and the walbro which the safc to manage it would suffice for the fuel for the time being
Old 03-25-2009, 01:33 PM   #46
95KA-Turbo's Avatar
I wouldn't run 550cc injectors on a SAFC. Get some S15 injectors, keep your stock MAF, and get it tuned on a dyno with the SAFC by someone who knows what they're doing.
When you say you want to keep your stock fuel pump, are you talking stock Silvia pump or stock KA pump? There's a pretty big difference there. The stock silvia pump should be fine with S15 injectors...but I'm not 100% sure on that because I have not been able to find the LPH rating on it.
Old 03-25-2009, 01:36 PM   #47
G240's Avatar
He was referring to a Stock FPR.
Old 03-25-2009, 01:41 PM   #48
95KA-Turbo's Avatar
Oh, a stock FPR is fine. haha
Old 03-25-2009, 10:22 PM   #49
Boost LeRoy
blksylv's Avatar
kewl thanx for the input guys
Old 03-25-2009, 11:07 PM   #50
SFP will get you in trouble, especially if its got some age and isn't running the best efficiency. If you are up grading to anything more then 340cc injectors get a tomei/walbro tomei easier to install...
Unless you have access to plenty of dyno time, wait to get all your hardware in before you get it tuned on dyno by someone who knows what they are doing, you won't regret it. the last thing you want is blow your motor when your doing something fun like a big slide or pedal to the metal on the back straight of a track =)
insanemaniac is offline   Reply With Quote
Old 03-26-2009, 01:33 PM   #51
bik
Send a message via ICQ to bik
wich one is a safe afr??
I have stock black top with stop t25, 255 fuel pump... when i rise to 14 psi it goes down to 11 psi tru the red line, my afr says around 12.5, i heard that is a good safe afr ratio is right?
i use mexican 91 octane fuel
is this safe? O_o
ps. my english sucks
bik is offline   Reply With Quote
Old 03-26-2009, 04:16 PM   #52
95KA-Turbo's Avatar
12.5 is safe - basically as long as it doesn't go too far over 13 for an extended period of time you'll be fine. Mine got into the 14s on 14psi on my S14 SR (I'm only state this because my picture is not working above because I maxed out my photobucket bandwidth for march, haha!)
T25s shit out at about 14psi, so it will only maintain it for a short period of time (but it gives you a nice torque curve, haha).
Your English isn't bad at all...you write better on the forum then some people I know write in school!
Old 03-27-2009, 01:38 AM   #53
S13 curtis's Avatar
is this safe? O_o
you might wanna grab a Safc and add some more fuel.
S13 curtis is offline   Reply With Quote
Old 09-10-2009, 09:43 AM   #54
Boost LeRoy
blksylv's Avatar
well sorry for bringing a thread back from the dead but finally got the car dynoed yesterday and it made 267whp on a stock s13 sr with a s14 t28, nismo fpr,walbro 255, z32 maf, safc1,fmic and 3" exhaust. the afrs under boost were around 11.98 on 11.5 psi.
Old 09-10-2009, 09:55 AM   #55
SR/RB Guru
Sileighty_85's Avatar
whats your injector duty cycle? more than likely its around 100%
Which mean your injectors will probably crap out soon
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Sileighty_85 is online now   Reply With Quote
Old 09-10-2009, 07:43 PM   #56
Boost LeRoy
blksylv's Avatar
honestly i dont know wat the duty cycle was and 550s and a tuned ecu are in the works at the moment. on 10psi it made 252 and the afrs were in the mid 10s low 11s
SEO by vBSEO 3.6.0 PL2
