| | #31 |
| I dunno if this would apply here but just throwing it out here http://forums.nicoclub.com/zerothread/213470 | |
| | #32 | |
| Doctor Chips ![]() | Quote:
...and "suck the cfm's out of the turbo," seriously? | |
| | #33 | |
| | #34 | |
| Post Whore! ![]() | Quote:
__________________ http://www.laboratory17.com/blu808sig.jpg I NEED A S14 INNER DOOR LATCH. Driver side. If you have one PM me ASAP !!!!!!!!!!!!!!!!!! WWW.BLU808.COM | |
| | #37 |
| Doctor Chips ![]() | As a mechanical engineer, I will freely admit that the only time I would ever expect to hear "suck the cfms out of the turbo" is at the end of a geeky engineering joke. Since you're being serious, I think it's you that doesn't have any idea about what you're talking about. I know plenty about internal combustion engines, so tell it to someone you can fool on the internet with your highly technical "sucking cfm's" speak. ![]() |
| | #38 | |
| Zilvia Junkie ![]() | Quote:
However, if for example your air pump (IC engine) flows 500 cfm and your turbocharger flows 200 cfm, you theoretically have an air pump capable of moving 700 cfm. By adding camshafts with X duration/X lift, your air pump now flows 750 cfm alone, for example, and your turbocharger still flows only 200 cfm, your camshafts now dictate the maximum amount of air the engine can push through. This would most likely be the case for an engine with a relatively small turbo and insanely large duration/lift cams....ie an SR20DET using a T25 with 272 intake/exhaust cams. Does that make sense? | |
| | #39 |
| Post Whore! ![]() |
__________________ 1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
