Old 03-30-2008, 11:30 PM   #1
I.C. affect turbo lag?
Just wondering if intercooler size affects turbo lag? I would think it would, maybe not that much.
Este510 is offline   Reply With Quote
Old 03-30-2008, 11:31 PM   #2
slider2828's Avatar
Intercooler, and piping diameter affects Turbo lag in a very big way...
Turn and Burn!
Old 03-30-2008, 11:36 PM   #3
JonGu's Avatar
Too large of an intercooler will restrict flow and affects lag. What's your set up and what intercooler you plan on using?
JonGu is offline   Reply With Quote
Old 03-30-2008, 11:47 PM   #4
WTF?
It affects lag. What is lag?
Lag is the delay between pushing on the accelerator pedal and having the turbocharger create boost inside the intake tract. If you increase the volume of the intake tract it will take longer to fill/pressurize that volume and create a set amount of boost.
S14 240SX aka "The Dirty S14"
fizzerkart.com/s14.html
DirtyS14 is offline   Reply With Quote
Old 03-30-2008, 11:56 PM   #5
Send a message via AIM to jskateborders
Yea, you see all these sr's on t25's pushing 7lbs of boost with huge ass fmic's, and its retarted.
Less piping + smaller IC = boost faster
Smaller IC = less cooling efficiency.
You have to find a happy medium for your setup.
20 lbs of boost, a big ass fmic is necessary.
Less, doesnt really need it that big.
You dont want your air too hot, but you also dont want to over do it.
"I am Norwegian, and are not familiar with your urban words :P"
jskateborders is offline   Reply With Quote
Old 03-31-2008, 12:07 AM   #6
JonGu's Avatar
Originally Posted by DirtyS14 View Post
WTF?
What is your point?
Too large of an intercooler will cause less throttle response from the increased area the air needs to travel.
Turbo lag itself does not increase, but intake lag increases. It takes more time for the turbo to pressurize the longer air intake tubes and the bigger intercooler.
I stand by what I said, so please tell me what you don't understand and maybe I can point you in the right direction.
Old 03-31-2008, 03:32 AM   #7
sbanzer123's Avatar
how do you figure it would restrict flow?
sbanzer123 is offline   Reply With Quote
Old 03-31-2008, 04:30 AM   #8
JonGu's Avatar
I'm sorry, "restrict air flow" is not what I meant. Bottom line is, too large of an intercooler is not a good thing.
Old 03-31-2008, 07:51 AM   #9
SHIFT_*grind*'s Avatar
There's a difference?
But yeah, the bigger the intercooler, the longer it'll take for you to reach positive manifold pressure (i.e. boost).
1993 SR 'Vert
Originally Posted by Springs1 View Post
I ONLY CONSENTED TO ONE COKE
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 03-31-2008, 03:22 PM   #10
racerjake's Avatar
It also depends on what size turbo and engine you are running. A KA-T with a T25 spools up so quick you'll get very little lag even with a large intercooler.
racerjake is offline   Reply With Quote
Old 04-01-2008, 01:48 AM   #11
I have the gt3076 bottom mount turbo, and planning to go with a icevex i.c. 24x12x3. I want to mount it upside down where the condenser would be and just cut some holes beside the radiator for the piping.
SEO by vBSEO 3.6.0 PL2
