| | #1 |
| Leaky Injector | 4 x 114.3 offset for stock brakes = <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'> offset if you are running JDM S13 brakes = <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'> offset if you are running Z32 brakes = <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'> thanks!
__________________ kg/mm springs bilstein sport struts cusco os front + rear strut bar cusco rear triangle bar cusco sway bars yep, she handles ok... |
| Sponsored Links | |
| | #3 |
| Zilvia Member ![]() | I'm in on this, too. I'd like to run 17x8 in front and 17x9 in rear. I'd like to find out what the stock offset is, so I can determine the offset of the new wheels. I'd like to have the offset in the back just right so the wheels are even with the fenders, not recessed like they are stock. Know what I mean?
__________________ '91 fastback. '97 S13 blktop SR20DET. Cstm Frnt Mnt IC w/ cstm 2 1/2" piping. stnls stl fltr. 3" cstm DP & exhst w/N1 muff. Walbro FP. ACT 6 pck cltch. Go Fast Bits crnk plly. Ground Control coils. KYB AGX shks. 12.98@106 w/g-tech pro. 17psi. All work and fabrication done by ME |
| | #4 |
| Post Whore! ![]() | stock offset is I think +40mm or so. may be more with if you have the steelies and hubcaps. Stock size, I believe, is 15x6. I'll be putting on a pair of 15x7+5 wheels in the near future, which I hear fit fine unless you have a brake upgrade, in which case you may need a 5mm spacer depending on the brakes. This setup SHOULD clear z32 brakes, though I'm not sure why they didn't clear the guy who I bought them off's brakes. (I don't remember what his brake upgrade was-- def. not stock, nor was it z32... I think it was Project-Mu or sth like that.) Luke, if you want 17x9 to fit flush out back, I imagine you should try for something like +35 or possibly +40 to prevent you from shredding your tires on the inside of the fender.
__________________ The Royal FLUSH... since 2004. OP[/b]G[/b], yo. |
| | #5 |
| Zilvia FREAK! ![]() | Big brake fitment is as much about spoke design as it is about offset. Some of the stock 7 spoke alloys will clear the 26mm Z brakes. Some won't without a small spacer. The difference is in the spoke reinforcements. In general a lower offset (+30mm) will aid in clearing the brakes, though a wheel with a deep dish or thick spoke design may not. I think the number you need to know is backspacing.
__________________ Steve 93 240sx FB currently very clean and for sale |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
