Old 09-17-2007, 07:35 PM   #1
Got nismo thermostat, do I need any gaskets
Ready to have my nismo thermostat installed, and it came with no gaskets. So are there any type of gaskets I should get, so when its installed I have no problems afterwards? If you could also give the name of the gasket so I get the right part.
I appreciate any help, having cooling system flush, new hoses, and this thermostat done wed. So I'm trying to make sure I have everything
s13pignose is offline   Reply With Quote
Old 09-17-2007, 07:37 PM   #2
MavericStephenc's Avatar
Send a message via AIM to MavericStephenc
some of the blue rtv seal (I think) works fine
That kind of attitude is SHIT. People with that kind of complacent outlook on law and government are the bane of this country's existence. -Thesquidd
Boycott Berkeley and code pink
MavericStephenc is offline   Reply With Quote
Old 09-17-2007, 07:40 PM   #3
correct me if im wrong but is the only gasket needed called the thermostat housing gasket? I mean I don't mind paying for gasket, just for peace of mind knowing its done right. I'm having a mechanic do install since I"m not familiar with coolant systems as it is, and have problems now that I don't want to make worse.
Old 09-17-2007, 07:46 PM   #4
aznpoopy's Avatar
check the fsm
there's no paper gasket
you use "liquid gasket" aka RTV
its damn hard to mess it up DIY. i suggest saving ur cash. building a lego house is probably more complicated. just follow the steps in the FSM if you're worried about it.
aznpoopy is offline   Reply With Quote
Old 09-17-2007, 07:47 PM   #5
sorry let me correct myself
use the gasket with the blue shit.
sorry I type slower than i can think
Old 09-17-2007, 07:55 PM   #6
make sure the metal is cleaned of the old gasket material, place a small bead of RTV around the housing, install the new thermo, bolt on waterneck, and torque bolts to spec.
here is the RTV, avaible at any auto part store
khilgers is offline   Reply With Quote
Old 09-17-2007, 08:13 PM   #7
nissanguy13's Avatar
Just like everyone else said, RTV. I put a Nismo thermostat on my SR back in December or so. All you have to do is clean metal, put RTV on, tighten bolts, and wait to dry.
Originally Posted by unicoladron;
dick, i had like 4 posi reps in a row and you ruined it
nissanguy13 is offline   Reply With Quote
Old 09-17-2007, 08:14 PM   #8
vqboodah's Avatar
you spread RTV around evenly on the thermostat housing and the just bolt it back up. i used FIPG (form inplace gasket) from toyota and it works out fine.
vqboodah is offline   Reply With Quote
Old 09-17-2007, 11:45 PM   #9
just as a tip, and for all future references, whenever i have to use a sealant i always use Hondabond, its a honda factory sealant and it always works great and i never have had anything leak on me with it. A tube of it will also last a very long time because you only use such a little bit on whatever you are sealing. Instead of seeing that oozing ring of blue or orange sealant, everything will look like it was factory sealed.
thats no dome, bit@h go HOME!
seven.62 is offline   Reply With Quote
Old 09-18-2007, 12:22 AM   #10
articdragon192's Avatar
Hondabond is the best.
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 09-18-2007, 12:44 AM   #11
man i thought that i was the only one. I have never herd anyone else in the tech thread talk about it, but yea dude it rocks.
Old 09-18-2007, 12:59 AM   #12
It's been used in both my old S13 and my current Z32. Good stuff. Recommended to me by a Nissan Master Tech, lol.
Need help?
Click here
Still stumped?
Try this
Here you go.
SEO by vBSEO 3.6.0 PL2
