| | #1 |
| Zilvia.net Advertiser ![]() | SR20DET BUILD/SWAP/WIRING DVD's http://store.driftingshop.com/techdvds.html SR20DET WIRING HARNESS DVD "From Skinnee Pant Productions - the creators of Shift 180 - comes the long overdue must have wiring DVD series! Featuring Yury Lyalko from wiringspecialties, Michael Kent lays out a grass roots approach to S13, S14 and S15 engine wiring in the first of three DVD's scheduled for 2007. This DVD features all of the SR20DET step by step wiring instructions on the S13 chassis covering S13, S14 and S15 motor installations! Scheduled for release in mid Febraury 2007, this 2 hour long DVD will contain special features, Service Manual diagrams, a must have wiring toolkit guide and a troubleshooting section on how to diagnose wiring related SR20DET engine problems. Yury and Michael lay out the step by step sequences in a way both beginners and advanced wiring practicioners will understand." ![]() http://store.driftingshop.com/techdvds.html ![]() http://store.driftingshop.com/techdvds.html ![]() http://store.driftingshop.com/techdvds.html ![]() http://store.driftingshop.com/techdvds.html ![]() http://store.driftingshop.com/techdvds.html ![]() http://store.driftingshop.com/techdvds.html Last edited by DRIFTING.com; 11-17-2007 at 05:03 PM. |
| Sponsored Links | |
| | #3 | |
| Zilvia.net Advertiser ![]() | Quote:
Also, the RB25DET Wiring DVD will be released soon. | |
| | #5 | |
We should have more information by today or tomorrow. | |
| | #7 | |
| | #9 | |
| | #10 |
| Post Whore! ![]() | Will the wiring allow Apex PowerFC Installations without any issues in the future? Carlos |
| | #14 | |
| | #15 |
| Zilvia Member ![]() | s13 Ca18 to s13 sr20? |
| Sponsored Links | |
| | #19 |
| Zilvia.net Advertiser ![]() | We need to contact Mike for an update. Thanks for the reminder!!! |
| | #20 |
| Zilvia.net Advertiser ![]() | Thank you!!! Glad that the Mike's video helped you. |
| | #21 |
| Zilvia Junkie ![]() | What about for a CA18?!?!?! |
| | #23 |
| Zilvia.net Advertiser ![]() | Please post your feedback if you have already watched the Motor Build DVD. |
| | #24 |
| Zilvia.net Advertiser ![]() | Next Project; Head - Speed O Motive o Head port/polish - TOMEI o Poncam Camshafts o Adjustable Duralumin Cam Gears o Strengthened Timing Belt o Head Gasket - Deatschwerks o 650 Injectors - FERREA Racing Componrents o Valves o Retainers o Springs - Phase 2 Motortrend o Seals o Nismo Thermostat - HKS o Exhaust Manifold - Greddy o Intake Manifold - Gizzmo o Phelonic Intake Gasket - KKR o KKR560 Turbo - NGK o Spark Plugs Block - Speed O Motive o Hone and Polish - JE PISTONS o Forged Pistons o Forged Pins o Rings - K1 Rods o Forged Connecting Rods - TOMEI o Connecting Rod Bearings - ACL Performance o Main Bearings - Lopez Crankshafts o Crank work - Phase 2 Motortrend o N1 Water Pump o Misc Seals and Gaskets Other Upgrades Covered - Driveshaft Shop o 450HP+ Axles - TORCO Racing Fluids o Oil o Assembly Lube o Engine Break In Fluid o Gear Oil - SPEC Clutch o Twin Plate Clutch o Aluminum Flywheel |
| | #25 |
| Zilvia Member ![]() | Any video for S14 into S14? Is there mush difference really? Obviously the engine bay will probably be a bit different between S13 and S14, but any differences to wiring, etc?
__________________ 2008 IS-F |2007 R6 |
| | #29 | |
we might produce this DVD | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
