Old 07-24-2002, 08:09 PM   #1
Itsuki's Avatar
Send a message via AIM to Itsuki
Ok, i have some brake fluid which was given to me its "brake man brake fluid" and i was wondering if anyone has used it? and are these boiling points to High or to low or are they good for my car. (dry 577 degrees, wet 300 degrees) its a 1996 240sx i daily drive it but once a week at night i drive hard down mountain roads so you think these boiling points are good??
Itsuki is offline   Reply With Quote
Old 07-24-2002, 10:07 PM   #2
tnord's Avatar
dry seems pretty good, but wet seems low. iirc these are the characteristics of a synthetic fluid. once again, iirc, the synthetic won't mix with the standard stuff. i'd look into it before you go dumpin it in the master cyl.
of course, i could be completely wrong.
tnord is offline   Reply With Quote
Old 07-25-2002, 10:54 AM   #3
Send a message via AIM to Ni5mo180SX
Just check the DOT rating. DOT 5 you have to really watch out for. Im using 5.1.
Mazda RX-7 FC3S: Jspec motor, ported turbo & wastegate, JIC FLT-A2 coilovers, Mazdatrix adj. rear camber link, TB mod, Koyo 53mm Radiator, Corksport Cat back/midpipe/downipe, 3" Al TID, Apex'i air cleaner, Mazda Comp. mission/motor/differential mounts, Mazdaspeed Strut Bar(R), FD torsen differential, HKS SSQV, HKS elec. boost gauge & elec water temp, Cusco Oil catch, 680cc secondary's, Walbro 255, Banzai Racing FCD, RB DTSS Eliminator bushings, Exedy Clutch & PP, Exedy chrome moly flywheel, RB oil baffle, RB dual alt. pulley, 5 lug conversion, FC3S.org thermal bypass pellet, KVR Cross drilled rotors, complete Energy PU bushings, stainless steel brake lines/clutch line, Aerodyne shroud panel, Azenis RS, and some other stuff. A hybrid of sorts I guess
Ni5mo180SX is offline   Reply With Quote
Old 07-26-2002, 01:52 AM   #4
Itsuki's Avatar
It says it is compatable with DOT 3 motor vehicle brake fluid....it also says "non-silicone and i was planning to bleed the whole system and replace it with this stuff...
Old 07-26-2002, 08:35 AM   #5
uiuc240's Avatar
Send a message via AIM to uiuc240
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (tnord @ July 24 2002,11:07)</td></tr><tr><td id="QUOTE">dry seems pretty good, but wet seems low. iirc these are the characteristics of a synthetic fluid. once again, iirc, the synthetic won't mix with the standard stuff. i'd look into it before you go dumpin it in the master cyl.
of course, i could be completely wrong.</td></tr></table><span id='postcolor'>
those are very "racey" numbers. &nbsp;i'd get something with a higher wet boiling point...unless you plan on changing your fluid a lot. &nbsp;
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 07-26-2002, 09:51 AM   #6
Yea it seems good.
SEO by vBSEO 3.3.0
