| | #1 |
| Zilvia Junkie ![]() | compressor surge FTW?!?! http://videos.streetfire.net/search/...8250795ac2.htm Is this all compressor surge? Answer this question.... does he have a blow off valve or not? |
| Sponsored Links | |
| | #4 | |
| Zilvia Junkie ![]() | Quote:
| | #6 |
| Zilvia Addict ![]() | sounds like hes getting some blow off but its too tight. But some track cars dont run them because they dont care about turbo life that much, and would rather have preformance benefits instead. Just depends on how much $ you have to spend.
__________________ FS: my 240sx, black, socal, SR, mods PM me for link to thread. |
| | #9 |
| [JEFE S14] ![]() | This is something that not many outside competitive drifting know about - very few cars use blow off valves. That sound you heard is compressor surge ~ a BOV really only vents once, maybe twice if you've built up a lot of pressure. Whenever you hear the multiple 'pssht' sounds, that's compressor surge. The Formula D car I worked on was a lot like the Falken S15 mentioned above - RB25, GT3076, and no BOV. The newer GT30R series turbos have special vanes around the compressor intake to relieve a little bit of the surge and to make the compressor surge sound even louder, which is what everyone wants, cause it puts V8's to shame =D Anyhow, from a performance standpoint, no BOV means your hotpipe/intercooler stay charged with pressurized air, so your throttle response is 'better'. I put 'better' in quotes because I never enjoyed the jerky feeling, I like to build power in a drift, let off, and have a second to build it back up again, but whatever. From a competitive DRIFTING perpective, it's all for the crowd - people love hearing turbos. That's all. Put that SSQV back on, you dont have 3 spare turbos that Garrett bought you sitting on a shelf in your shop. Keep your bearings/seals in good shape. |
| | #11 |
| Leaky Injector | sounded like a revlimiter and a hks ssqv to me? my car does the same at lower bost
__________________ http://i143.photobucket.com/albums/r...dchic/joey.jpg |
| | #12 |
| The European Contingent! ![]() Join Date: Mar 2004 Location: I'm somewhere where I don't know where I am!
Trader Rating: (0) | ^^Same here. Although, I don't know about the rev limiter part, since I don't have one. And since the newer SSQVs aren't adjustable, even if it is too tight you're SOL. |
| | #14 |
| Zilvia Addict ![]() | not trying to promote this bov, but very useful info... http://videos.streetfire.net/search/...3f0150f005.htm +1 for me ![]() |
| | #15 | ||
| Zilvia Addict ![]() | Quote:
mine shit out on me along time ago, and i just took it off and welded up the pipe. fuck that noise.
__________________ http://i4.photobucket.com/albums/y11...ow/Sector9.png Quote:
| Sponsored Links | |
| | #16 | |
| I'm back. :sadface: ![]() | Quote:
__________________ | |
| | #17 | |
i dont know if i agree with that. because when you run no bov, and your compressor surges. when you step on the throttle again your starting out with a turbine that isnt spinning or is spinning in the opposite direction. so that to me would seem like it would take more time to get spooled up again then having a spinning turbine and half empty intercooler piping, because not all the air in the piping is vented out. just my .02 | |
| | #18 | |
| Zilvia Member ![]() | Quote:
i absolutely agree. compressor surge is when the charged air in the piping comes back and "hits" the compressor momentarily stopping or even reversing the flow. this is not something that you typically want, and is arguable as to any performance gain or not. anyone that hears this and doesnt have a couple spare turbos should cringe with fear. | |
| | #19 | |
| | #20 | |
| Quote:
On the importance of BOV's.. "The pressure spike can also throw the compressor into surge, which can cause it to overspeed and damage the wheels by causing them to bend or even burst. Severe surge will fracture the compressors blades. Spinning at 120,000 rpm, even the slightest unsymmetrical weirdness in a wheel can cause it to burst explode. At best the pressure wave will drastically slow down the spinning turbo causing a loss of power, as the turbo must respool to re gain boost pressure after the shift." From Mike Kojima himself... Nissan Performance Mag | ||
| | #22 | ||
| Nissanaholic! ![]() | Quote:
Or I could go out and drive my car with no BOV and like it. PS, thanks for bumping this shitty thread so you could play Mr. Engineer since you read some shitty 100 page picture book from the 1970s. Quote:
lol. | ||
| | #23 |
| O fuckin' G ![]() Join Date: Oct 2002 Location: VA.. And for those that keep PMing me asking what kit I have, it's Origin Stream.
Trader Rating: (2) | A good friend of mine has run without a BOV on all of his SRs. Never had a turbo blow. Granted he has sold them all fairly quickly too. While compressor surge will shorten the life of the turbo, it will NOT do so in 5k miles. It does cut down on turbo life, but not by leaps and bounds. Plus, from what I've been told, it isn't that expensive/difficult to rebuild one; granted I've never had to do it, so I wouldn't know. P.S. Surge still sounds FUCKING BADDASS!
| | #24 | |
| | #26 |
| Zilvia Junkie ![]() | wow that totally sounded like mad compression serge. i was running a gt28r and had a sard high boost bov that was to tight and it sounded exactly like that. This year i am not running a bov for a bit but thats on a crappy ca t25 so i could give a rats ass what happens to it, just gives me a reason to upgrade and than i will consider a bov |
| | #27 | |
| Leaky Injector | Quote:
| | #28 | ||||
| Zilvia FREAK! ![]() Join Date: Dec 2004 Location: Charlie, I'm going to candy Mountain PA Age: 24
Trader Rating: (4) | Quote:
IIRC Maxium boost was published in the mid to late 90's...but who's checking? Quote:
I run a BOV because i'm a girl., and can't afford replacing turbos like they mean nothing. I've realized that being 'baller status' on a forum usually makes you look silly to 95 percent of the rest of car guys....
__________________ Want Air Conditioning in your SR 240? PM me for Adapter Plates! | ||||
| | #30 | ||||
Trader Rating: (2) | Quote:
Relax, I'm just kidding with you man. Like I said, my post was from my experiences. If I don't know something, I'm sure as shit not gonna tell you it's the truth. I was actually also told by another good friend of mine that had and EVO, that when he took his BOV off alltogether, the car's driveablility was a LOT better.
__________________ | ||||
| Sponsored Links | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
