Old 02-04-2007, 11:36 AM   #3
DRIFTING.com's Avatar
DRIFTING.com is offline   Reply With Quote
Old 02-16-2007, 10:35 AM   #5
http://www.youtube.com/watch?v=kRU7HSMXfU8
Old 02-28-2007, 08:30 PM   #7
RUTH'LESSDET's Avatar
Send a message via AIM to RUTH'LESSDET
when is this dvd gonna be done
LS2 Powered 1997 240sx-Sold
2005 350z
RUTH'LESSDET is offline   Reply With Quote
Old 03-01-2007, 12:23 AM   #8
-Filming - DONE
-Major Editing - DONE
-Chapters - TOMORROW
-Final editing - SUNDAY
-Final Review - END of NEXT Week
Old 03-01-2007, 12:29 PM   #9
welp I would like to have my copy asap please. I need that now when can I pay my $
Originally Posted by DRIFTING.com
-Filming - DONE
2005 350z
Old 03-01-2007, 01:47 PM   #10
Please PM your contact number or call us during business hours.
Old 03-03-2007, 09:48 PM   #11
wangan_cruiser's Avatar
when is this thing gonna be available? i need one
Old 03-03-2007, 10:23 PM   #12
Hi Wagan Cruiser,
We plan to send this DVD out for replication by the 12th. Are you on our sign-up list?
Also, the cover was updated today.
Old 03-07-2007, 11:02 PM   #13
yea i think i signed up for it....how much will it be?
Old 03-08-2007, 03:29 PM   #14
$19.95 for a Two-Disk set
Old 03-08-2007, 03:54 PM   #15
Hi can you please add me to your list. I am very interested in this dvd. I will buy one as soon as it is available. Send me a pm as soon as it is ready and I'll send you the money through paypal.
rauc22 is offline   Reply With Quote
Old 03-08-2007, 09:30 PM   #16
btw.....does this dvd covers s13 swap? or just s14?
Old 03-08-2007, 09:37 PM   #17
kouki_s14's Avatar
Send a message via AIM to kouki_s14
look at the title, it's a s13 swap
not that it matters because it's basically all the same
I'm amazed at how many people are idiots.
kouki_s14 is offline   Reply With Quote
Old 03-09-2007, 10:59 AM   #18
Hi rauc22,
The sign-up form is at the bottom of this page.
http://store.driftingshop.com/rb24sdv.html
Old 03-15-2007, 10:17 AM   #19
Chapter Outline
1
Remove lower engine bay components
-TC Rods
-Sway Bar
-Brackets
-Lower Control Arms
-Rack & Pinion
-Tie Rods
-Spline
-Cross Member
2
Clutch & Flywheel
-RB Flywheel
-SPEC Clutch
-Pilot Bushing
-Clutch Alignment Tool
-Pressure Plate
-Torque to Spec
3
Motor Prep
-Lower Harness
-Motor Mounts
-RB vs. SR Harness
4
Transmission/Downpipe
-Throttle Bearing
-Input Shaft
-Bolt to Motor
-Starter
-Downpipe Heat Shield
-Gasket
-O2 Sensor
-12 POINT Bolts
5
Motor/Trans Install
-Line Up Crossmember
-WOOD Block by Firewall
-Trans. Relocation Brackets
-Tap threads
-Clutch Fork Boot
6
INSTALL lower engine bay components
-TC Rods
-Sway Bar
-Brackets
-Lower Control Arms
-Rack & Pinion
-Tie Rods
-Spline
-Trans/Motor Bracket
7
Ground Wire, Neutral Switch
Lower Harness
Upper Harness
Idle Control Valve
Coolant Temperature Sensor
2nd Sensor
2 Ground Wires
Cam Angle Sensor
Computer, Connect
8
Q45 Throttle Body
Throttle Cable Bracket
Vacuum Booster Hose
Fuel Filter
-Return Line
-Feed Line
9
INTERCOOLER
-Remove Bumper Support
-FABRICATE Intercooler Mounts
-Pipe/Hoses
-Cut Bumper Support
10
-Driveshaft
-Exhaust
11
Vacuum Lines
-PCV Valve
-Fuel Pressure Regulator
Power Steering
Pressure Line
Return Line
Connect to Pump
Reservoir
Power Steering Cooler
12
Radiator (S14)
-Cut Fan Shroud
-Remove Plates
-Zip Tie Fan
-Remove Foam Lining
-RELOCATE a SPACER!
-Wire the Fan, Part #1
-Radiator Brackets
-Wire the Fan, Part #2
-Bleed System
13
-Ground Wire, Block
-Slave Cylinder Install
-Slave Cylinder System Bleed
-Heater Hose Plugs
14
-Idle Control Valve Hose
-Battery Terminal Attachment
-Braille Auto Battery
-Intercooler Piping Reinstall
-Wastegate Actuator Hose
-APEX'i Intake
-MAF Sensor
15
-Fuse Box Bracket
-Throttle Cable S14
-Cable to Throttle Body
16
-Fuel Pump
-Valve Covers
17
APEX'i Power FC Intro with Steve from SR MOTOR CARS
Old 03-15-2007, 06:19 PM   #20
kouki_s14's Avatar
so do i get one for free? haha since my car is kind of in it, i think, unless it was edited out. not that i need it obviously haha, but just curious to see how it turned out
Old 03-15-2007, 06:33 PM   #21
I can send you a review copy. PM your address.
Old 03-15-2007, 06:34 PM   #22
kouki_s14's Avatar
hahahahaha i was kidding but okay
Old 03-16-2007, 01:26 PM   #23
Parts List/Source
R33 Skyline Front Clip - (Sr20Store.Com)
Syko Performance Rb25 Converted Upper And Lower Harness - (Sykoperformance.Com)
Syko Performance Motor Conversion Mounts - (Sykoperformance.Com)
Syko Performance Transmission Brackets - (Sykoperformance.Com)
Syko Performance Sway Bar Brackets - (Sykoperformance.Com)
Syko Performance 1 Piece Driveshaft - (Sykoperformance.Com)
Intercooler Piping - (Sykoperformance.Com)
Intercooler Core - (Meganracing.Com)
Couplers And Clamps - (Hosetechniques.Com)
Power Steering Cooler - (Sr20store.Com)
S13 91+ DOHC Power Steering Lines And Fittings - (Milano Motorsports)
Greddy RB25 Intake Manifold (Purchased From (Phase2Motortrend.Com)
Rb25 Intake Manifold Gasket - (Phase2Motortrend.Com)
Infiniti Q45 Throttle Body - (Junk Yard)
Infiniti Q45 Throttle Body Gasket - (Purchased From Infiniti Dealer)
Apex-I Power Intake - (Apexi.Com)
Apex-I Power FC & Commander - (Apexi.Com)
Apex-I Auto Timer - (Apexi.Com)
Flex-A-Lite Low Profile Dual Radiator Fans (#220) - (Flex-A-Lite.Com)
Clutch Stage 3 Upgrade - (Specclutch.Com)
Flywheel - Stock Resurfaced RB25 Flywheel - (Taken To Local Shop)
Steel Braided Slave Cylinder Line - (Sr20store.Com)
Braille Auto Compact Lightweight Battery - (Brailleautodevelopment.Com)
STOCK S14 Radiator (Milano Motorsports)
High Pressure Fuel Injection Hose (Local Autoparts Store)
Z32 Fuel Filter - (Purchase From Any General Auto Parts Store)
Walbro Fuel Pump - (Phase2Motortrend.Com)
S14 Throttle Cable - (Rhddesign.Com)
Fuse Box Bracket - (Custom)
5 Quarts Of Torco Full Synthetic 5W-40 Racing Oil - (Torcoracingoils.Com)
3 Quarts Of Torco Gear Oil - (Torcoracingoils.Com)
Radiator Fluid - (Local Autoparts Store)
Power Steering Fluid - (Local Autoparts Store)
Old 04-10-2007, 01:14 AM   #24
hksS14sr20det's Avatar
Well I checked out a review copy and this dvd kicks ass. They do a good job of explaining what they are doing and why. Each scene has titles on the bottom so you dont get confused as to what they are working on. They even take the time to explain how to hook up things that they are leaving off (because its a race car). Way to go guys.
http://i80.photobucket.com/albums/j1.../irishbeer.jpg
Interested in a Smog legal SR or RB? We're working on it here:
http://www.zilvia.net/f/showthread.php?t=132325
hksS14sr20det is offline   Reply With Quote
Old 04-10-2007, 10:48 PM   #25
ripnbst's Avatar
damn good idea, props to whoever thought of this. you guys should make a series, like one for the SR, CA, and RB26. You could do one for LS1 and JZ motors too since they are gainging popularity. Again Sweet Idea and props to you guys. If I was gonna do an RB25 swap this would definately be the first tool bought.
1992 240SX COUPE BOOST (totalled)
Rebuild in progress
ripnbst is offline   Reply With Quote
Old 04-12-2007, 02:38 AM   #26
2ZJ filming starts this weekend!! We also want to document a VQ Swap.
Old 05-02-2007, 08:57 AM   #27
ORDER PAGE
Old 05-03-2007, 07:22 PM   #28
ORDER PAGE
Old 05-03-2007, 07:25 PM   #29
ORDER PAGE
Old 03-06-2008, 10:29 PM   #30
This also includes how to pull a KA right?
OfourTHREEfive is offline   Reply With Quote
SEO by vBSEO 3.3.0
