Old 07-12-2006, 11:43 PM   #1
18x9 plus 3 a lil too extreme?
I know, i'm sorry for another stupid wheel offeset question. I've done research and i know about the offesets etc.
For the rear of a s14, how much of a pull(or will i need overfeners?) would be required to fit 18x9 plus 3?
I've seen pics of work emotions in a 9 1/2 plus 12, and they did fine with just a fender roll. So take that 1/2 inch , divide it in two(to get the difference of CENTERS between a 9 and 9 1/2) and that equals 1/4 inch wich equals ABOUT 6mm. RIGHT?
So that means a 9 1/2 with a plus 12, is the same(as far as sticking out) as a 9 with a plus 6...right? So maybe i'll be fine?
ANYONE!? thanks fellas
Old 07-12-2006, 11:45 PM   #2
REDSH!FT's Avatar
Stretched tires and you're fine...
REDSH!FT is offline   Reply With Quote
Old 07-12-2006, 11:49 PM   #3
JVD
It will fit beautifully. Like redshift said, stretched tires. Enjoy!
JVD is offline   Reply With Quote
Old 07-13-2006, 01:03 AM   #4
stretched tires and LOTS of camber? or just stretched tires?
I drive HARD so neg. camber kill tires WAY faster than i like.... Can i run -1 camber with some mildly stretched tires and make it work?
And is that with ONLY rolled fenders...no pull??
thanks again guys!! i'm about to spend a LOT of money and dont want to mess up!
Old 07-13-2006, 01:51 AM   #5
chmercer's Avatar
if you drive hard then negative camber shouldnt kill your tires, as they would be getting a fuller contact patch. negative camber is ideal for agressive driving. id say 2-3 degrees. negative camber only wears tires if you have like toe in and you never drive agressivley.
going from +12 9.5j to +3 9j it will only stick out 3mm more. so almost not even measurable. besides my buddy runs 9j -15 on front with no trouble, and theres more room in the rear. should be an easy fit
chmercer is offline   Reply With Quote
Old 07-13-2006, 12:05 PM   #6
NI_YON_Zenki's Avatar
WOWZerS
Originally Posted by chmercer
#1 (( if you drive hard then negative camber shouldnt )) kill your tires, as they would be getting a fuller contact patch. #2 (( negative camber is ideal for agressive driving )). id say 2-3 degrees. #3 (( negative camber only wears tires if you have like toe in and you never drive agressivley.))
Point #1: Think about that comment. Negative camber WILL effect the performance of a car's wheel alignment and tire wear. The contact patch is still negative when the wheel is SET to the GROUND Negative, come on. Driving hard will NOT Keep the tires free from exceeded wear.
Point #2: Negative camber is not ideal for agressive racing, its for VIP Celiors, Cimas, Chasers, etc. due to them being lowered. Drifting should honestly have NOTHING to do with negative camber at all, if you wanna do it right, the only exception I have observed with this is given to the AE's up front due to turning angle. thats it. Negative camber is only accepted when you lower a car to decrease lateral body pitch.
Point #3: WTF?!?!?! This is just A durt-dur-dur moment, toe in is just a stupid mistake to be made upon any "Drifters" or drivers car for that matter, if you end up with toe-in on the REAR wheels/tires of your car, then you need not be driving that car, except to a new alignment shop, make sure you do your homework before schedualing an oppintment with the new shop!
Go DO YOUR HOMEWORK. .. .
"GHOST"
NI_YON_Zenki is offline   Reply With Quote
Old 07-13-2006, 12:20 PM   #7
I Got you
If you go with a 215/40/18 should be fine. .. .roll the fenders cause you will catch patches of your tire coming to bald.. .. You should even be safe with a 225. .. .cause your wheel really isn't that large, a 235 will put you under the negative camber issue that concerns your preferred style of driving your car.
Call G-Dimensions and ask for an alignment setup, Speak with james, and he'll direct you to speak to Phiffer, alex. He conducted my first alignment, I was terrible. Tell james Skip sent cha.
as far as your measurements uptop. They're the same.
"GHOST"
Old 07-13-2006, 12:50 PM   #8
JVD
So you always run your wheels with +/- 0 degrees? From what I understand mercer is correct. Yeah, you're probably right though. Those "stupid drifters" just can't be right.
Old 07-13-2006, 01:36 PM   #9
OptionZero's Avatar
When a strut-based car turns, the negative camber helps it maximize contact patch. Maybe you assumed he meant driving aggressively in a straight line?
Even factory alignment specs have some negative camber IIRC.
Ever seen an F1 car? Camber and toe like mad.
Toe-in is for straight line stability, a little tiny bit in rear is probably helpful.
OptionZero is offline   Reply With Quote
Old 07-13-2006, 01:59 PM   #10
Pink GodziRa
Dousan_PG's Avatar
are you always a douchebag/dumbass?
i gotta go to work. ill edit my post
Aaron
Pink GodziRa
Old 07-13-2006, 02:25 PM   #11
SpeedMonkeyInc's Avatar
How about you go drive your car at a race track then get back to us with empirical knowlege. This imagination of yours is creating hypothetical race car alignemnts and isn't helping anyone.
SpeedMonkeyInc is offline   Reply With Quote
Old 07-13-2006, 02:35 PM   #12
OptionZero's Avatar
read some of his past posts and it all makes sense in a blind-dog-getting-run-over sort of way
Old 07-13-2006, 02:43 PM   #13
Seriously. I love that he has some show car in his sig with hella neg camber too. Icing on cake.
Old 07-13-2006, 03:06 PM   #14
Retired General
revat619's Avatar
Send a message via AIM to revat619 Send a message via Yahoo to revat619
Unfortunately, i'm at work and i dont have time to elaborate, but...
What the hell are you talking about?
Just a small tid bit: You do realize that F1 cars run around 3 degrees of camber atleast. Reason being suspension geometry and maximum performance. And IIRC, F1 cars ARENT VIP.
Stop smokin the mary-ja-wanna Skip....
revat619 is offline   Reply With Quote
Old 07-13-2006, 04:25 PM   #15
Pink GodziRa
Dousan_PG's Avatar
point 1
you dont know shit about driving apparently or track racing/drifting/etc.
point 2:
go look at any racing events. f1 etc etc etc. get a clue
drifting? tell taka (4ag) about his -4 front camber tell any profession drifter to go back to next to no camber and see what they say. get a tranlater while yoru at it too. you'll need one. no one understands your talking online or in person im sure.
point 3
toe in oh god ur an idiot
you just drive around town
the last drift or track even u probably did was in 4ag heyday.
get a life
geta clue.
i love how u say all this about camber but u run some crazy sized wheels, have tons of camber, pulled your fenders o look like shit AND then do this
but when a wheel thread comes up ur all proud of your setup
ugh.
go away.
Aaron
Pink GodziRa
Old 07-13-2006, 05:21 PM   #16
OptionZero's Avatar
[/i]_Quality ain't cheap. .. . it pertains to the dreams of your better half.
so choose what you think will satisfy your better half Main.[/i]
oh and this one
http://www.zilvia.net/f/showthread.p...758#post995758
i swear the dude posts when he's on crack
Old 07-14-2006, 09:37 PM   #17
thanks for all the replies guys!!!
SEO by vBSEO 3.3.0
