Old 05-20-2006, 10:16 PM   #1
Hi-PeR's Avatar
Send a message via AIM to Hi-PeR
How do u lower rear of the engine??
Need help. . im trying to get the tranny back in but need to lower engine in order for it to clear. . does anyone know how to do this?? thank u!!
Hi-PeR is offline   Reply With Quote
Old 05-20-2006, 10:36 PM   #2
mmdb's Avatar
Loosen the engine mounting bolts and use a cherry picker to pull the front of the engine up to bring it to a better angle to slide the tranny in.
mmdb is online now   Reply With Quote
Old 05-20-2006, 10:43 PM   #3
Hi-PeR's Avatar
any alternatives to a cherry picker???
Old 05-20-2006, 10:55 PM   #4
NIK90s13's Avatar
Yea, put a jack on the frunt of the motor, like on the crank pulley, jack it up and it will tilt the back of the motor down.
NIK90s13 is offline   Reply With Quote
Old 05-20-2006, 10:59 PM   #5
No time for the jibba-jabba!
mrmephistopheles's Avatar
That's a good suggestion. I should copy it into the 'How can I bend my crank pulley' thread.
Originally Posted by PHLIP
mrmephistopheles is online now   Reply With Quote
Old 05-20-2006, 11:05 PM   #6
Mando Performance
why do you need to lower the engine, i put back my tranny back in with out lowering the engine. just turn the tranny upsidedown so the the starter hump is pointing down that way you have more clearence to raise the tranny up.
mandoz85 is offline   Reply With Quote
Old 05-20-2006, 11:06 PM   #7
NIK90s13's Avatar
It didn't bend mine.
Also you arent putting stress on the pulley, just useing it to pivot the motor on the mounts.
You can tilt the motor by hand to get the back down, you just can't steady it.
Old 05-20-2006, 11:20 PM   #8
Hi-PeR's Avatar
thank all of u guys for ur suggestions! im glad that so many 240sx owners are willing to share their knowledge. itz been a good experience using this forum!
Old 05-21-2006, 12:24 AM   #9
Send a message via AIM to CHARLIE2020 Send a message via Yahoo to CHARLIE2020
Best way is using a cherry picker like someone mentioned above...
Using the crank pully as a jacking point is not a good idea...
CHARLIE2020 is offline   Reply With Quote
Old 05-21-2006, 06:06 AM   #10
SLINKY + ESCULATOR = Fun Times
fliprayzin240sx's Avatar
Another ghetto suggestion...leave the downpipe and use a scissory jack to pull the engine down...like i said, its a ghetto suggestion that ive tried and it worked.
fliprayzin240sx is online now   Reply With Quote
Old 05-21-2006, 07:56 AM   #11
projectRDM's Avatar
UNBOLT the downpipe. The engine will tilt easily towards the firewall.
I know I've said that at least 100 times in here. Strange no one bothers to search.
SEO by vBSEO 3.3.0
