| | #1 |
| Leaky Injector ![]() | 350Z OEM Brakes on S14 I have a set of 350z brakes that are really good condition and i was wondering if it was possible for me to use them on my S14?.......anyone have any experience with these? |
| Sponsored Links | |
| | #2 | |
| Self-Proclaimed n00b ![]() | Quote:
http://www.zilvia.net/f/showthread.p...50z+brakes+s14 I'm sure if you did a little better search(ie different words) you would find what u need....I believe that I saw someone w/these on but cant remember where...gl | |
| | #4 | |
| Zilvia Addict ![]() | Quote:
350Z/G35 rear brakes are also a whole other story.
__________________ http://img.photobucket.com/albums/v2...0/P6260002.jpg | |
| | #5 |
| Zilvia FREAK! ![]() | why would there be a diff from s13 and s14.... there the same brakes
__________________ This box is 400x200: http://img137.imageshack.us/img137/8858/400x2005hu.jpg Please do not put your sig pic back if it exceeds this. -Moderation |
| | #6 | |
| | #7 |
| Zilvia FREAK! ![]() | not to burst anyones bubble, but when we put the BBK on my bro's touring model, the caliper holes were off significantly. I'll get pix for you guys when i get a chance. I was under the impression that they were identical and you one would need is to bore out the spindle holes where the calipers mount up, but the mounting points on the 350z caliper are a bit further apart than the s14 stock caliper...
__________________ 2004 NFR S2000 |
| | #8 | |
| | #10 | ||
| | #11 |
| Zilvia Addict ![]() | Ok i know SPL makes the brackets for use with 350Z/G35 12.78" rotors with "Z32" calipers not the BREMBO gold calipers. I think there's two different things being talked about here. It sounded to me that one person experienced the BREMBO torque member bracket was spaced wider than stock therefore not a direct bolt-on.... BREMBO's stock use a 12.78" rotor Z32 stock use's 11" the SPL bracket advertised that I see if for use only with the Z32 30mm calipers.
| | #13 |
| Post Whore! ![]() | Jesus, did you fucking read anything above? Z33/V35 brakes will bolt up in the front only by drilling the spindle ears out to 14mm (9/16"). Rears do not work without a custom bracket. Note that drilling the ears out does reduce the amount of material the caliper anchors to so it's advised to be accurate with it. The SPL kit is designed to use Z33 Track rotors with Z32 calipers, completely different setup. And FYI, the base Z33 brakes are no better than the Z32s, and in most cases heavier since the calipers are iron. Unless they were free you're wasting your time. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
