| | #1 |
| Leaky Injector ![]() | SOHC PS lines with SR20 I'm doing an SR swap into a zenki S13. I always read that you need the DOHC power steering lines, but I've also read you can bend the SOHC PS lines to work just fine. Does anybody have any pictures of how they did it? |
| Sponsored Links | |
| | #2 |
| Zilvia FREAK! ![]() | the SOHC lines do work, you install the line on the DOHC piece, not stright onto the pump itself. |
| | #4 |
| Zilvia Addict ![]() | my friend just bends the lines in place and bolts up to the stock sr pump, now i think this is unsafe and very ghetto looking. But it does work.
__________________ IS300 RHD S13 Coupe |
| | #5 |
| Leaky Injector | Sorry, my car has been on blocks for a few months and I have hardly looked under the hood for even longer, but I'll do my best to describe. follow your high pressure line from the rack towards the pump. On the front side of the cross member, or somewhere near, there should be a short section of flexible high pressure line. You're gonna want to bend that at about 90 degrees, using it as the main way to pivot all the lines toward the other side of the bay. From there, you gotta just really genltly bend the hard lines that go towards the pump, untill you can get it out of the way as best you can. Basically you are just bending everything over to the other side of the bay. Just be really careful bending the hard lines, if you do it too much, they will crease, becoming garbage. It's not the cleanest way, but it works and mine was/pretty much still is working to for a few years. |
| | #6 |
| Zilvia FREAK! ![]() | ah finially found the dame pictures: someone from another forum: ![]() ![]() |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
