| | #1 |
| Leaky Injector ![]() | Just installed 225/45/17s...gonna be a problem? I got some D2s and finally got tires on them. I was told to go with the 45 aspect ratio. When they checked out the % difference at Costco, it was less than 3%, but when I did it on the 1010.com calculator, it was 3.05%. It says anything over 3% runs the risk of brake failure! Makes me nervous and annoyed (should've gotten 40s apparently....gah!) Is this going to realistically going to be an issue? |
| Sponsored Links | |
| | #3 |
| Zilvia Junkie ![]() | you wont experience much, if any change in their behavior. just like for speedometer changes... the difference is minimal, but it does exist.
__________________ http://photos-176.facebook.com/ip007...30176_3951.jpg |
| | #5 |
| Zilvia FREAK! ![]() | um where did you read that your brakes will explode, i've never heard of this. come to think of it, i dont think i've heard of brakes exploding period......for any reason.....whatsoever
__________________ I'm amazed at how many people are idiots. |
| | #9 | |
| Quote:
Just my two cents. Those wheels are hot, btw. props =)
__________________ "He's a sucker for a morning smile and summer cleavage." -Atmosphere '95 S14 '85 300zx N/A | ||
| | #12 |
| Zilvia FREAK! ![]() | What about all those pimped out rides with 26 and 32 inch wheels? Never heard anything bad about those except tranny failure and wheels breaking off and flying into oncoming traffic.
__________________ S.O.L.O. |
| | #13 |
| Leaky Injector ![]() | Hahaha, good stuff. I've plus sized rim and tire combinations for years. I've never had any brake problems, abs malfunctions or anything like what you are describing. The thought of brakes overheating and exploding is totally rediculous. |
| | #14 | |
| Post Whore! ![]() | Quote:
__________________ I'm from Florida so I'm probably a bit more strange than you | |
| | #15 |
| Post Whore! ![]() | think about it too, if they say 3 percent is fine, and your talking 3.05, its not a clear cut anything over exactly 3.0000000000000000000 will explode, there is grey area in which the 3.05 would be in anyway, if something has a rating, then theres always room here and there
__________________ I was going to, but I can not think of a sig less than 75 characters. |
| Sponsored Links | |
| | #16 | |
| Zilvia Addict ![]() | Quote:
__________________ I'm driving fast ![]() -drew | |
| | #17 | |
| Quote:
| | #18 | |
btw i just called discount tire and told em im running 17x8 +35 in front on s13 and said that my 225/45/17 are too big and i should go to a 16x6 and get a 215 oh and i need a spacer, if i wanna go anything larger than stock.
__________________ I was going to, but I can not think of a sig less than 75 characters. | |
| | #20 |
| Leaky Injector ![]() | at all you guys thinking I was serious about my brakes exploding/causing a supernova hahahahha Anyways, I just meant that it might wear out the brakes due to larger/heavier setup. Thank you ZADS for the info about the ABS, I think that covers it all. You guys crack me up ![]() |
| | #21 | |
| Zilvia FREAK! ![]() | Quote:
True. Thats how I paid for my stillen body kit and custom paint on my maxima. Im still waiting for someone to rearend my S14 . . . Papa needs new paint.
__________________ S.O.L.O. | |
| | #22 |
| Zilvia Junkie ![]() | I've seen brakes explode. But that was at Leguna Seca when one of the Speed GT Corvette's blew a front rotor to pieces. It was crazy. But, you won't kill your brakes over wheel size. The larger rotational mass will put extra strain on the brakes to slow the vehicle, so you might go through brakes 3% quicker. But, then again, your engine will also be working harder to turn those bigger wheels so you'll be going 3% slower. ![]() Honestly, unless you are SERIOUSLY plus sizing (like putting 22" on an s13 with stock brakes), then you probably will not even notice a difference. |
| | #23 | |
| Hmm. Wow, look at the flaming because you don't understand. My last post was meant to go ALONG w/ Mjjstang's comment about tolerances. It was not directed at Mjjstang, it was directed at Csdcowboy. Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
