Old 05-17-2006, 05:42 AM   #1
daredevildoug's Avatar
z32 pistons in a s13 blacktop!?
i plan on rebuilding my blacktop motor. what are my options considering i do not have much to spend on pistons/rods. from what motor(SE-R, 300zx. etc) can parts be used? the help is greatly appreciated. thanks
-de
ps. yes i searched!
daredevildoug is offline   Reply With Quote
Old 05-17-2006, 06:30 AM   #2
No time for the jibba-jabba!
mrmephistopheles's Avatar
I would reckon that any SR20DE pistons would work.
I suppose if the Z32 pistons are the right bore diameter, height, have the wristpin holes in the same spots, and roughly the same ring lands, you could use those too.
edit- 2 minutes making love to Google, and it gave birth to this: http://www.optionimports.com/oemnisrpikit.html
Originally Posted by PHLIP
Old 05-17-2006, 08:23 AM   #3
nice find... thanks aye. anyone with more info on these z32 pistons? thanks
Old 05-29-2009, 10:45 PM   #4
timtiminy's Avatar
Send a message via AIM to timtiminy
300zx turbo pistons are 87mm bore and should yield ~9:1 CR in the SR. you will have to overbore your engine, they are relatively cheap and are made the same as stock sr pistons. you will have to grind your rod ends for the piston to have enough side to side clearance or mill out a little on both sides of the underside of the piston where the wrist pin goes through.
timtiminy is offline   Reply With Quote
Old 05-29-2009, 10:57 PM   #5
SoguRacing's Avatar
Send a message via AIM to SoguRacing
just use stock sr pistons.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 05-30-2009, 04:25 AM   #6
Solidus311's Avatar
Wow this thread is old.
cardomain.com/ride/3113705
Solidus311 is offline   Reply With Quote
Old 05-30-2009, 08:00 AM   #7
haha "close to stock compression"
do not want.
Ka24Power is offline   Reply With Quote
Old 05-30-2009, 09:27 AM   #8
Originally Posted by daredevildoug View Post
can parts be used?
Why would you use used parts when rebuilding an engine? There are already used parts in the engine you are rebuilding...
BlazedGlory is offline   Reply With Quote
SEO by vBSEO 3.3.0
