Old 05-15-2006, 08:47 AM   #1
KA FINALLY fired up., kA Idle issues, EGR a factor?
Hey I was finally able to get the KA STARTED after a tedius timing experience, it finally started, only problem is it feels like a bull wanting to jump out of the body, with the sound of a detroit diesel. i HAVE tried and tried to get it smoth with no success. the only thing that was changed when i replaced the head gasket was i blocked off the EGR. are there any specific precedures to go about this? the car works fine on highway driving, just has a bad attitude at low rpm's.
boostlee is offline   Reply With Quote
Old 05-15-2006, 09:11 AM   #2
tre
tre's Avatar
Vacuum leak possibly, or IACV, clean MAF maybe?
Anyways. normally always a vacuum leak.
I didn't buy an Audi because it is a Great Car, but for more of a reason to be an asshole.
tre is offline   Reply With Quote
Old 05-15-2006, 02:18 PM   #3
aznpoopy's Avatar
what have you tried so far? you sure you set timing properly?
aznpoopy is offline   Reply With Quote
Old 05-15-2006, 02:20 PM   #4
tre
tre's Avatar
Wait a second. Did you kill the computer in the car so everything reset?
This is what happend to my 240 when i finally put a new o2 sensor in. It idled/cruised like shit but full open wouldn't be a problem.
It could be the ECU retuning itself.
Old 05-16-2006, 01:33 AM   #5
ledzeppelin240's Avatar
The O2 sensor is not used under WOT. Replace your O2 sensor and unhook the battery for about 10minutes to reset the ECU. If you replaced your headgasket, it may have been burning coolant which wreaks the O2 sensor.
Make sure your timing is set correctly cause that will cause the idle problem.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 05-16-2006, 06:20 AM   #6
Ezel verkrachtende schijteter
!Zar!'s Avatar
Send a message via AIM to !Zar!
I'm almost sure it's your timing, I had a friend with a problem like this.
Factory setting is 20* I believe.
-=Mel=-
Old 05-16-2006, 09:12 AM   #7
well so far i've checked and rechecked almost all the vacum lines, so its eiter timing or ecu issues, howver i did put my computer to check codes and it kept saying the o2 wasnt ready, so maybe my o2 went bad, although, i never had a problem before, i only changes the gasket for boost purposes. i feel it must be timing, uhhh....
Old 05-16-2006, 09:23 AM   #8
tre
tre's Avatar
or maybe your car hasn't retuned it self! mine ran like crap for some time. i'd give it a good day or two of driving.
Old 05-18-2006, 02:02 PM   #9
DONE!! finally got it straight, it was the timing off. now it runs smoot like a baby's ass. thanks for the help.
SEO by vBSEO 3.3.0
