| | #1 |
| i am in the process of converting my s13 from auto to 5 speed. i bought a tranny and the 3 sensors that are on the side had all been cut, this is not including the wheel speed sensor at the back. does anyone know what each of these sensors are for and how they wire up? thanks for your help | |
| Sponsored Links | |
| | #3 |
| Post Whore! ![]() | You need to get a lower engine harness that goes from the back of the gearbox from a manual gearbox. It plugs up to the engine room harness. If it's cut you have to manually wire them up yourself. |
| | #5 |
| Post Whore! ![]() | Go to a local junkyard. If you can see one with a manual gearbox you could probably just unplug all the sensors and take out the whole harness. If you don't have one you need to read the FSM. Try getting one from your local dealer. If it's not possible you have to redo the wire harness yourself. That's as far as I can explain it because it is complicated. A shop would probably charge you 10 hours of labour to fabricate a gearbox harness from scratch. |
| | #7 |
| Post Whore! ![]() | why not just forget about it, you dont need any of that shti, the only useful one is speed and that is on the main harness.
__________________ I was going to, but I can not think of a sig less than 75 characters. |
| | #10 |
| Zilvia Junkie ![]() | OD... maybe Overdrive? When the car tends to lean itself out to give you premo gas mileage on the freeway?
__________________ I didn't buy an Audi because it is a Great Car, but for more of a reason to be an asshole. |
| | #15 |
| sweet deal. thanks for the help guys i really appreciate it | |
| Sponsored Links | |
| | #18 |
| Post Whore! ![]() | never needed a service manual on disc, and ive done a lot of work, how bout www.zeroyon.com????? FRREEEEEEEEEEE
| | #23 |
| Post Whore! ![]() | neutral is so you cant start the car when the clutch is not pushed in, at least this is what I think, I mean i can start mine in any gear i want with the pedal not pressed in, this is because I dont have my sensor connected. someone correct me if im wrong.
| | #27 | |
| Nissanaholic! ![]() | Quote:
| | #29 | |
| | #30 |
| Sponsored Links | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
