| | #1 |
| HKS Turbo Timer Type-01 Install problems, please help! Ok ive searched throught these forums, dl'ed the s14 FSM and have the installation instructions. However im stuck. I have a zenki sr in a 95 240sx and am trying to put in the above mentioned turbo timer.In the instructions it says to locate the key switch connector and connect the turbo timer harness in between the key switch connector and the main connector plug. Going though the FSM I cant figure out which is the key switch connector. Anyone that can help me out is a godsend. BTW, here is the link for the HKS Turbo Timer Type-01 Instruction manual if it is needed: http://www.hksusa.com/info/download.asp?id=1634 | |
| Sponsored Links | |
| | #2 |
| BANNED ![]() | Heres what i THINK it is...take off the plastic part around the key switch..there should be a harness you can unplug and use the turbo time wiring harness. i need to know where the 2nd harness is located for the ignition switch too. cuz I dont wanna mount next to the key switch |
| | #3 |
| ok dude i got all hooked up right. you have to buy an extra harness for you model then that part hooks right in. as far as the speed and RPM signal wires. check out this other thread i started. http://www.zilvia.net/f/showthread.php?t=109139 | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
