Old 03-10-2006, 06:06 PM   #1
s14 s14 battery relocation
I recently put a yellow optima battery in the trunk of my 96 240sx with a sr vvt black top so I could get rid of the little bulshit battery and everything is good but I was researching and seen that you should have a heavy duty fuse on the battery to stop a fire in in case the wire or terminals corode or short out. Could somebody out there please, tell me what kind of fuse I should use and where I could get my hands on one?
ny-s14blacktop is offline   Reply With Quote
Old 03-10-2006, 06:36 PM   #2
sunnys14's Avatar
i didnt wire a fuse... works good so far for me
sunnys14 is offline   Reply With Quote
Old 03-14-2006, 10:13 AM   #3
then you r running the risk of your wires running from the front of the car corodingand shorting and starting a fire once they get a little old
Old 03-14-2006, 01:01 PM   #4
Jefferson's Avatar
Dude I didn't use a fuse either and have not had any problems (on both my cars). And you should not have corroded battery wires anyway because you are supposed to change them to a heavier gauge wire.
But I assume you could just use a fuse block(the big one) like the audio kind and splice it in the power wire
Just my 2 cents
Jefferson is offline   Reply With Quote
Old 03-14-2006, 01:29 PM   #5
Send a message via AIM to jmauld
You need to find a 100Amp fuse or circuit breaker somewhere. With a previous car, I picked up an 100Amp audio circuit breaker from Circuit City and mounted it inside the box with my battery. I believe it was $30, but this was probably 5 yrs ago.
For those not using fuses, you should keep that advice to yourself. If you're fine with the possibility of burning your own car down, then so be it. You don't need to recommend to others that it's okay, since you are obviously not aware of the power potential in a car battery.
Jason
'95 240sx SE
jmauld is offline   Reply With Quote
Old 03-14-2006, 03:38 PM   #6
Tenchuu's Avatar
Send a message via AIM to Tenchuu Send a message via MSN to Tenchuu Send a message via Yahoo to Tenchuu
My problem with fuses on the main power cable was peak draw. i ran a 100A and it kept on blowing after i was driving with the heater, defroster, and stereo all going. yes there is some safty issues, but if you are that concerned then put a cut off switch in the system. when i removed the factory wireing there was about 2-3 ft of non fused battery cable that i replaced with about 12-15 ft of batterey cable, but then again all my clamps that hold the cable in place are rubber lined so an to be non abrasive and non conductive. also li covered any wear points with rubber to isolate it also. all of those things are kinda common sense but then again sometimes peope don't know about it.
untimatlesy it's up to whoever you are, but a cut off switch IS always a smart idea.
Rightwheeldrive the Northwest non douchebag forums.
Tenchuu is offline   Reply With Quote
Old 03-14-2006, 04:28 PM   #7
No more nissan.
NemeGuero's Avatar
Old 03-14-2006, 04:44 PM   #8
I ran welding cable so I am not to worried about then corroding this stuff is ALOT thicker and tougher then stereo wire or regular battery cable.
Stillslow is offline   Reply With Quote
Old 05-20-2006, 12:28 PM   #9
Silverbullet's Avatar
Send a message via AIM to Silverbullet
sorry to bring back from the dead. Perhaps i just need to be educated better in the electrical aspect, but why do some people use a fuse? The stock battery/pwer system dosn't have a fuse so wouldn't it be the same if i just extended the + wire to the trunk?
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 05-20-2006, 01:31 PM   #10
kouki_s14's Avatar
Send a message via AIM to kouki_s14
cuz stock the wire just runs through your engine bay, so a fuse is not needed. when you route it to the trunk there is a "hot" wire running through your car that carries a lot of power. that wire can heat up and cause a fire. the fuse prevents that by regulating the amount of electricity going through the wire. this only really happens when someone uses a wire that is not thick enough to handle the power, because a bunch of people run without fuses/ breakers and are fine. just make sure you have good connections, but the breaker is always a smart investment.
I'm amazed at how many people are idiots.
kouki_s14 is offline   Reply With Quote
Old 05-20-2006, 01:37 PM   #11
Send a message via AIM to phrozen
i just relocated my battery in my s14, ran a 100amp circuit breaker. no problems i ran a power and a ground along the pass side, ill post pics of it when i get home today
This box is 400x200:
http://img137.imageshack.us/img137/8858/400x2005hu.jpg
Please do not put your sig pic back if it exceeds this.
-Moderation
phrozen is offline   Reply With Quote
Old 05-20-2006, 02:59 PM   #12
sean350z's Avatar
is there any detriment to running a shielded 1 gauge power wire within 6 inches of the ecu?? will it mess with the computer?
i'm in the process of running my cable right now and not sure where i want to bring it through the firewall. the ecu harness already has extra stuff ran through it for my guages. i found a spot (s14) right below the lower heater hose area...any other genious ways anyone can think of that would be better
sean350z is offline   Reply With Quote
Old 05-20-2006, 03:16 PM   #13
No more nissan.
NemeGuero's Avatar
You don't need to run a ground wire.. you can ground it in the trunk itself to the chassis.
Just scrape away the metal and bolt it to the trunk latch or something.
Old 05-20-2006, 03:33 PM   #14
its better if you ground at the trunk and back to the engine bay
-Moderation
Old 05-20-2006, 03:45 PM   #15
SLINKY + ESCULATOR = Fun Times
fliprayzin240sx's Avatar
The biggest issue with relocating your battery to the trunk is when the cable runs back thru the firewall. If you have a slight vibration, the firewall can eventually start slicing thru the power cable and that will cause a short.
fliprayzin240sx is online now   Reply With Quote
Old 05-20-2006, 04:00 PM   #16
Gramentz's Avatar
I second that, the same vibration shorted my wire and made my car die going down a bridge..
Gramentz is offline   Reply With Quote
Old 05-20-2006, 04:23 PM   #17
sean350z's Avatar
yea, i think i found another way (s14)...behind the ecu where the two blue relays sit is a panel. that panel there are two bolts that hold the door to the car. i'm thinking directly above that, drill a hole, add a grommet, run the wire between fender and wheel well plastic piece and then run it through the plastic circle by the windshield washer bottle.
Old 05-20-2006, 05:17 PM   #18
samms95s14se's Avatar
When you move your battery to the trunk how do you check your timing? Also is it better to just run the cable under the car and into the trunk? I'm about to either replace my old amp power wire which goes from the battery to the trunk with some thicker stuff or relocate the battery to the trunk and just run some thick wire to the amp. What is the best solution?
samms95s14se is offline   Reply With Quote
Old 05-20-2006, 06:02 PM   #19
Ezel verkrachtende schijteter
!Zar!'s Avatar
Send a message via AIM to !Zar!
I'll have Evan do a writeup for you when he relocates mine for me. HAHA.
-=Mel=-
!Zar! is online now   Reply With Quote
Old 05-20-2006, 08:27 PM   #20
No more nissan.
NemeGuero's Avatar
Hahah, not me Evan, right?
A ground is a ground.. as long as you pull good voltage it doesn't matter if you ground it in 1 place or 20 places.
If you use a fuse distribution box like me.. you can jumper power for a timing light right from there. I ran my cable through the interior for the purpose of keeping the wire safe and protected. I used my old amp power wire. 4 guage.. people say its too thin, but I've never had any problems with it. Summits kit uses 4 guage.
Old 05-20-2006, 11:01 PM   #21
How or where do you clip the timing light on it?
Old 05-20-2006, 11:10 PM   #22
No more nissan.
NemeGuero's Avatar
Originally Posted by NemeGuero
The clear case pops off..
Just grab onto the metal.. anywhere..
Old 05-21-2006, 08:10 AM   #23
projectRDM's Avatar
The stud in the front fusebox that the alternator feed bolts to is constant +12V, connect the timing light there.
SEO by vBSEO 3.3.0
