| | #1 |
| Zilvia.net Advertiser ![]() | Fortune Auto Coilovers w/ FREE IIR T-SHIRT! Master Dealer of FA!!******************** ![]() ![]() CALL 804-690-2452 and mention BILLY to receive special pricing ON ZILVIA!!!!! ![]() Price: $999 shipped to your door w/ free IIR shirt!!!!!!! ![]() ![]() ![]() **COILOVERS NOW HAVE A BLACK COATING TO PREVENT RUST** Zilvia, We are now the Master Dealers of Fortune Auto coilovers! **Join their Facebook page!** Fortune Auto's Facebook Page Fortune Auto | Facebook All coilovers incorporate a 50mm piston, 30 way damping, fully anodized body, custom rates & a 1 year warranty. This rigorous testing has earned us our ISO certification. Furthermore we incorporate features only found on our coilovers such as Seamless stainless steel monotubes, Forged lower mounts & proprietary nitrogen gas chambers. Features: * Dyno tested*** * Stainless steel body / piston * 30-way adjustable dampers * Pillowball mounts * Forged aluminum locking collars * Dust boots on all pistons * 50mm piston (beyond the industry standard of 44-47mm) * Anodized aluminum camber plates** on front upper-mounts * Fully anodized body * 1 year Manufacturer's Warranty * Height adjustment independent of preload * ISO 9002 certification Every Fortune Auto coilover is extensively dyno tested and matched with in specifications to insure a consistent and uniform set of coilovers. This rigorous testing has earned us our ISO certification. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() THEY GO LOW! ![]() ![]() ALL FORTUNE AUTO COILOVERS CAN BE UPGRADED WITH SWIFT SPRINGS FROM THE FACTORY!! HELPER SPRINGS ALSO AVAILABLE! Add $375 for Swift Springs! OR Add $475 for Swift springs with the helper springs! Spring Upgrade? Why Swift Springs? Swift springs of Japan noticed that most spring manufacturers use old silicone chrome material, which is not strong enough for automotive springs. Other manufacturers use a heat tempering method that damaged the strength of the material that inevitably require more coils, in turn, more weight. The material was also suffering from a shortened life span. With springs like this leading the industry, Swift saw massive room for improvement. Swift's R & D team created material, called H5S.TW, which is stronger then regular silicone chrome material. Because of this material, Swift could make the spring wire thinner, and could wind the springs with fewer coils, which greatly decreased weight while dramatically increasing available stroke. Helper Assist Springs: Assist springs have two functions. The first is the spring adds a progressive rate to the initial portion of the stroke. This progression can add increased comfort is used on a daily driver coilover setup that has stiff springs installed. It provides racers added softer spring rate progression. Once the assist crushes, the normal spring rate will take over. The second job is the same as helper springs. They prevent the loss of traction during rebound, and extreme cornering. Assist springs are designed to repeatedly be fully crushed. Every assist spring crushes to the same height. That allows drivers to change assist springs without resetting the spring perch on coilover without changing ride height. ![]() ![]() ALSO INQUIRE ABOUT OUR DRAG SPEC OPTION!! ![]() CUSTOM RATES AND VALVING AVAILABLE FREE OF CHARGE! ![]() Multiple Time Attack Winning Fortune Auto Evos! ![]() ![]() ![]() Last edited by IMPORTIMAGE; 04-10-2011 at 11:01 AM.. |
| Sponsored Links | |
| | #4 |
| Zilvia.net Advertiser ![]() | PM'ed!! It's Friday!!!! Regards, Billy@importimageracing.com Direct Line: 804-690-2452 Shop Line: 239-540-6385 AIM: ImportImageBilly Import Image Racing Your Online Source for Aftermarket High Performance Car Parts and Accessories for Subaru WRX and STI, Nissan, Mazda, Misubishi Evolution and others. |
| | #5 |
| | #7 |
| Premium Member ![]() Join Date: May 2003 Location: bangladesh Age: 26
Trader Rating: (26) Feedback Score: 26 reviews | can you do s13 coils with 300zx rear forks on the rear?
__________________ CURRY www.tm-spl.com - New York's #1 240sx Tuner. @tm_099 @tarmac_spl #tmspl Check us out @bdcsasdlol |
| | #8 |
| Zilvia.net Advertiser ![]() | No problem! Yes we can! Tuesday Bump! A great day to buy parts!! Regards, Billy@importimageracing.com Direct Line: 804-690-2452 Shop Line: 239-540-6385 AIM: ImportImageBilly Import Image Racing Your Online Source for Aftermarket High Performance Car Parts and Accessories for Subaru WRX and STI, Nissan, Mazda, Misubishi Evolution and others. |
| | #9 |
| Zilvia.net Advertiser ![]() | Wednesday Hump Bump! Regards, Billy@importimageracing.com Direct Line: 804-690-2452 Shop Line: 239-540-6385 AIM: ImportImageBilly Import Image Racing Your Online Source for Aftermarket High Performance Car Parts and Accessories for Subaru WRX and STI, Nissan, Mazda, Misubishi Evolution and others. |
| | #10 |
| Zilvia.net Advertiser ![]() | Thursday Bump! Regards, Billy@importimageracing.com Direct Line: 804-690-2452 Shop Line: 239-540-6385 AIM: ImportImageBilly Import Image Racing Your Online Source for Aftermarket High Performance Car Parts and Accessories for Subaru WRX and STI, Nissan, Mazda, Misubishi Evolution and others. |
| | #11 |
| Zilvia.net Advertiser ![]() | Saturday Bump! |
| | #12 |
| Zilvia.net Advertiser ![]() | Happy Monday! We hope everyone had a great weekend. Regards, Billy@importimageracing.com Direct Line: 804-690-2452 Shop Line: 239-540-6385 AIM: ImportImageBilly Import Image Racing Your Online Source for Aftermarket High Performance Car Parts and Accessories for Subaru WRX and STI, Nissan, Mazda, Misubishi Evolution and others. |
| | #13 |
| Zilvia.net Advertiser ![]() | Tuesday Bump!! Regards, Billy@importimageracing.com Direct Line: 804-690-2452 Shop Line: 239-540-6385 AIM: ImportImageBilly Import Image Racing Your Online Source for Aftermarket High Performance Car Parts and Accessories for Subaru WRX and STI, Nissan, Mazda, Misubishi Evolution and others. |
| | #14 |
| Zilvia.net Advertiser ![]() | Midweek Bump!! Regards, Billy@importimageracing.com Direct Line: 804-690-2452 Shop Line: 239-540-6385 AIM: ImportImageBilly Import Image Racing Your Online Source for Aftermarket High Performance Car Parts and Accessories for Subaru WRX and STI, Nissan, Mazda, Misubishi Evolution and others. |
| | #15 |
| Zilvia.net Advertiser ![]() | Thirsty Thursday! Regards, Billy@importimageracing.com Direct Line: 804-690-2452 Shop Line: 239-540-6385 AIM: ImportImageBilly Import Image Racing Your Online Source for Aftermarket High Performance Car Parts and Accessories for Subaru WRX and STI, Nissan, Mazda, Misubishi Evolution and others. |
| Sponsored Links | |
| | #16 |
| Zilvia.net Advertiser ![]() | Monday to the top! Regards, Billy@importimageracing.com Direct Line: 804-690-2452 Shop Line: 239-540-6385 AIM: ImportImageBilly Import Image Racing Your Online Source for Aftermarket High Performance Car Parts and Accessories for Subaru WRX and STI, Nissan, Mazda, Misubishi Evolution and others. |
| | #17 |
| Zilvia.net Advertiser ![]() | Bump up! Regards, Billy@importimageracing.com Direct Line: 804-690-2452 Shop Line: 239-540-6385 AIM: ImportImageBilly Import Image Racing Your Online Source for Aftermarket High Performance Car Parts and Accessories for Subaru WRX and STI, Nissan, Mazda, Misubishi Evolution and others. |
| | #18 |
| Zilvia FREAK! ![]() Join Date: Jan 2011 Location: Irvine, So. Cal. Age: 26
Trader Rating: (13) Feedback Score: 13 reviews | after reading this and watching your vid's.. You guys def won another buyer. Definitely have you guys in mind for the next setup i go to.
__________________ Simplicity is the key to brilliance |
| | #19 | |
| Zilvia.net Advertiser ![]() | Quote:
!!Bump up! Regards, Billy@importimageracing.com Direct Line: 804-690-2452 Shop Line: 239-540-6385 AIM: ImportImageBilly Import Image Racing Your Online Source for Aftermarket High Performance Car Parts and Accessories for Subaru WRX and STI, Nissan, Mazda, Misubishi Evolution and others. | |
| | #20 |
| Zilvia.net Advertiser ![]() | Wednesday Bump! Regards, Billy@importimageracing.com Direct Line: 804-690-2452 Shop Line: 239-540-6385 AIM: ImportImageBilly Import Image Racing Your Online Source for Aftermarket High Performance Car Parts and Accessories for Subaru WRX and STI, Nissan, Mazda, Misubishi Evolution and others. |
| | #22 | |
Wednesday Bump! Regards, Billy@importimageracing.com Direct Line: 804-690-2452 Shop Line: 239-540-6385 AIM: ImportImageBilly Import Image Racing Your Online Source for Aftermarket High Performance Car Parts and Accessories for Subaru WRX and STI, Nissan, Mazda, Misubishi Evolution and others. | |
| | #23 |
| Zilvia.net Advertiser ![]() | Thursday up to the top! Regards, Billy@importimageracing.com Direct Line: 804-690-2452 Shop Line: 239-540-6385 AIM: ImportImageBilly Import Image Racing Your Online Source for Aftermarket High Performance Car Parts and Accessories for Subaru WRX and STI, Nissan, Mazda, Misubishi Evolution and others. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
