| | #1 |
| Zilvia.net Advertiser ![]() | Fortune Auto Coilovers w/ FREE IIR T-SHIRT! Master Dealer of FA!!******************** ![]() ![]() CALL 804-690-2452 and mention BILLY to receive special pricing ON ZILVIA!!!!! ![]() Price: $999 shipped to your door w/ free IIR shirt!!!!!!! ![]() ![]() **COILOVERS NOW HAVE A BLACK COATING TO PREVENT RUST** Zilvia, We are now the Master Dealers of Fortune Auto coilovers! **Join their Facebook page!** Fortune Auto's Facebook Page Fortune Auto | Facebook All coilovers incorporate a 50mm piston, 30 way damping, fully anodized body, custom rates & a 1 year warranty. This rigorous testing has earned us our ISO certification. Furthermore we incorporate features only found on our coilovers such as Seamless stainless steel monotubes, Forged lower mounts & proprietary nitrogen gas chambers. Features: * Dyno tested*** * Stainless steel body / piston * 30-way adjustable dampers * Pillowball mounts * Forged aluminum locking collars * Dust boots on all pistons * 50mm piston (beyond the industry standard of 44-47mm) * Anodized aluminum camber plates** on front upper-mounts * Fully anodized body * 1 year Manufacturer's Warranty * Height adjustment independent of preload * ISO 9002 certification Every Fortune Auto coilover is extensively dyno tested and matched with in specifications to insure a consistent and uniform set of coilovers. This rigorous testing has earned us our ISO certification. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() THEY GO LOW! ![]() ![]() ALL FORTUNE AUTO COILOVERS CAN BE UPGRADED WITH SWIFT SPRINGS FROM THE FACTORY!! HELPER SPRINGS ALSO AVAILABLE! Add $375 for Swift Springs! OR Add $475 for Swift springs with the helper springs! Spring Upgrade? Why Swift Springs? Swift springs of Japan noticed that most spring manufacturers use old silicone chrome material, which is not strong enough for automotive springs. Other manufacturers use a heat tempering method that damaged the strength of the material that inevitably require more coils, in turn, more weight. The material was also suffering from a shortened life span. With springs like this leading the industry, Swift saw massive room for improvement. Swift's R & D team created material, called H5S.TW, which is stronger then regular silicone chrome material. Because of this material, Swift could make the spring wire thinner, and could wind the springs with fewer coils, which greatly decreased weight while dramatically increasing available stroke. Helper Assist Springs: Assist springs have two functions. The first is the spring adds a progressive rate to the initial portion of the stroke. This progression can add increased comfort is used on a daily driver coilover setup that has stiff springs installed. It provides racers added softer spring rate progression. Once the assist crushes, the normal spring rate will take over. The second job is the same as helper springs. They prevent the loss of traction during rebound, and extreme cornering. Assist springs are designed to repeatedly be fully crushed. Every assist spring crushes to the same height. That allows drivers to change assist springs without resetting the spring perch on coilover without changing ride height. ![]() ![]() ALSO INQUIRE ABOUT OUR DRAG SPEC OPTION!! ![]() CUSTOM RATES AND VALVING AVAILABLE FREE OF CHARGE! ![]() Multiple Time Attack Winning Fortune Auto Evos! ![]() ![]() ![]() Last edited by IMPORTIMAGE; 02-14-2011 at 10:24 AM.. |
| Sponsored Links | |
| | #2 |
| Zilvia.net Advertiser ![]() | Need a combo deal? No problem here @ IIR! Let us know what you need. Regards, Billy@importimageracing.com 804-690-2452 AIM: ImportImageBilly |
| | #3 |
| | #4 |
| Zilvia.net Advertiser ![]() | Happy Thursday! Come make your own combo deal! Regards, Billy@importimageracing.com 804-690-2452 AIM: ImportImageBilly |
| | #5 |
| Zilvia.net Advertiser ![]() | |
| | #6 |
| | #7 |
| Zilvia Junkie ![]() | just a suggestion guys, you should make a drag set up for the mk4 supra .cause a lot of them are getting megans and I don't think that is a good set up for drag racing. anyway they are looking for a set up between $1000-$1500 . hope this help...Omar here is the link http://www.supraforums.com/forum/sho...-a-1500-budget
__________________ 618 whp tuned by alpha |
| | #9 | |
| Zilvia.net Advertiser ![]() | Quote:
Up to the top! Regards, Billy@importimageracing.com 804-690-2452 AIM: ImportImageBilly | |
| | #10 |
| | #11 |
| | #12 |
| | #13 |
| Zilvia.net Advertiser ![]() | Saturday Bump! |
| | #14 |
| | #15 |
| Zilvia Junkie ![]() Join Date: Feb 2006 Location: Biloxi, MS Age: 29
Trader Rating: (2) Feedback Score: 2 reviews | Just got my order in a little while ago. Not a chance of me getting a better deal than what Billy gave me. The more parts you order the better it gets. Definitely going to spend more $$ with these guys. (KYB AGX's are finally going in the garbage) Thanks, Bubba 4x4 status R.I.P.
__________________ Good at wrenching, terrible at electrical. Lord help me... HAHAHA |
| Sponsored Links | |
| | #16 | |
![]() Up to the top! Regards, Billy@importimageracing.com 804-690-2452 AIM: ImportImageBilly | |
| | #17 |
| Zilvia.net Advertiser ![]() | Mid week bump! Ask me about combo deals ![]() Regards, Billy@importimageracing.com 804-690-2452 AIM: ImportImageBilly |
| | #18 |
| | #19 |
| Zilvia.net Advertiser ![]() | Happy Saturday we are making deals, thank you for an amazing month! |
| | #20 |
| Zilvia.net Advertiser ![]() | happy sunday, selling parts and shipping them monday AM. get your orders in today! |
| | #22 |
| Zilvia.net Advertiser ![]() | Why thank you!!! We love our customers! ![]() Monday Bump!! Regards, Billy@importimageracing.com 804-690-2452 AIM: ImportImageBilly |
| | #24 |
| Zilvia.net Advertiser ![]() | A couple of weeks away ![]() Tuesday bump!! Come on in for great deals! Regards, Billy@importimageracing.com 804-690-2452 AIM: ImportImageBilly |
| | #26 | |
Wednesday Bump! Regards, Billy@importimageracing.com 804-690-2452 AIM: ImportImageBilly | |
| | #27 |
| | #28 |
| Zilvia.net Advertiser ![]() | TGIF!!!! Call us for great deals! Regards, Billy@importimageracing.com Direct Line: 804-690-2452 Shop Line: 239-540-6385 AIM: ImportImageBilly Import Image Racing Your Online Source for Aftermarket High Performance Car Parts and Accessories for Subaru WRX and STI, Nissan, Mazda, Misubishi Evolution and others. |
| | #29 |
| Zilvia.net Advertiser ![]() | Saturday bump! Regards, Billy@importimageracing.com Direct Line: 804-690-2452 Shop Line: 239-540-6385 AIM: ImportImageBilly Import Image Racing Your Online Source for Aftermarket High Performance Car Parts and Accessories for Subaru WRX and STI, Nissan, Mazda, Misubishi Evolution and others. |
| | #30 |
| Zilvia.net Advertiser ![]() | Monday Bump! Give us a call and we'll take care of you ![]() Regards, Billy@importimageracing.com Direct Line: 804-690-2452 Shop Line: 239-540-6385 AIM: ImportImageBilly Import Image Racing Your Online Source for Aftermarket High Performance Car Parts and Accessories for Subaru WRX and STI, Nissan, Mazda, Misubishi Evolution and others. |
| Sponsored Links | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
