Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Suspension
Old 06-16-2010, 04:50 PM   #1
IMPORTIMAGE's Avatar
Trader Rating: (63)
Feedback Score: 63 reviews
Send a message via AIM to IMPORTIMAGE
*/*/*/*/BC Racing Coilovers\*\*\*\* FREE SHIPPING! Only @ Import Image Racing!
Click the image to open in full size.
CALL 804-690-2452 and mention BILLY to receive special pricing ON ZILVIA!!!!!
We are the #1 Vendor in the nation for BC Racing coilovers!
**Buy BC and get a $50 gift certificate for ImportImageRacing.com!!!!!
BC Racing BR series Coilovers $999 Shipped!! Free Custom Spring Rates as well!!
Our BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
- Mono-tube shock design
- 30 levels of damping force adjustment, adjust compression/rebound
- Pillowball mounts and adjustable camber plates included (where applicable)
- Adjustable rear camber plates available
- Separate full length height adjustable
- One year warranty
- Rebuildable
Technical
- Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force.
- Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
- Patented concave lower locking ring, to prevent unseating.
- Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 tires with less than 5% deformation.
- T6061 Aluminum utilized in spring locks and seats for high strength and lightweight.
- Iron lower brackets on MacPherson struts to ensure rigidity.
- Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking.
- High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
- 2 step coating process utilizing nickel and chromium plating to prevent corrosion.
- Newly developed lubricant oil in shock cartridges minimizes aeration and cavitation.
- An additional bearing beneath each pillowball mount provides the smoothest action and prolongs the lifetime of the pillowball itself.
BC Racing RAM type (Inverted) $1225 Shipped!!!
BC Racings inverted RAM model includes all of the great BR features and then takes it a notch higher. By using an inverted coilover system we move the vital damper fluid away from the detrimental heat sources to avoid overheating the fluid and causing damper fatigue under extreme conditions. The inverted setup also handles high-g loads better and is much more durable under stress situations, such as a race track. Another advantage is reducing unsprung weight by moving the heavy parts to the chassis mounting points. This is a great coilover for those looking to attack a race track, hill climb or tarmac rally.
- Inverted Mono-tube shock design
- One year warranty
- Rebuildable
BC Racing ER series $1850 shipped!!
Our newest and most advanced model yet is the ER series coilover. It features large external reservoirs front and rear, separate rebound and compression adjustment and a twin piston design. The external reservoirs hold much more oil than the conventional coilover, allowing the coilover to operate for a much longer period of time before overheating. The external reservoirs also house the secondary piston, which allows for the fine tuning of compression. This is the perfect coilover system for the person who wants to fine tune there setup using the separate, 30-way, rebound and compression tuning dials.
- External Reservoir Mono-tube shock design
- 30 levels of damping force adjustment, adjusts both compression and rebound separately
- Twin piston design
- One year warranty
- Rebuildable
Questions: Billy (804)-690-2452
(email)billy@importimageracing.com
AIM- importimagebilly
Like us on Facebook!
IMPORTIMAGE is offline
Old 06-21-2010, 10:12 AM   #2
Trader Rating: (63)
Up to the top with BC racing coilovers. Get them on your car for track proven performance
$999 shipped to your door!
Regards,
Billy@importimageracing.com
804-690-2452
AIM: ImportImageBilly
Old 06-22-2010, 01:57 PM   #3
Trader Rating: (63)
BC coilovers have a great warranty and huge application list!
$999 shipped to your door!!!
They can even do custom extreme low kits for their coilovers with 2-3 week wait time
Regards,
Old 06-23-2010, 10:44 AM   #4
Trader Rating: (63)
BC racing coilovers are one of the best bang for your buck coilovers!
Fully adjustable and custom spring rates available.
Regards,
804-690-2452
Old 06-23-2010, 02:27 PM   #5
Trader Rating: (63)
Just got pics from BC... They go low!!! They even told me with a shorter spring they can go about a half inch lower in the front. I don't think any collars were removed either!
Come on in and get some BC on your car!!
Old 06-24-2010, 10:41 AM   #6
Trader Rating: (63)
Want to slam your car?? That's no problem with BC racing coilovers!!
Come on in and get the best deal around!
Combo parts with BC racing and get crazy deals
Regards,
Old 06-25-2010, 02:40 PM   #7
Trader Rating: (63)
Up to the toP!!!
Come on in!
We're fully stocked
Old 06-26-2010, 02:06 PM   #8
Trader Rating: (63)
Working weekends!!
Regards,
804-690-2452
Old 06-28-2010, 10:56 AM   #9
Trader Rating: (63)
Need more than one part and want better prices?!?!
That we can handle. the more you buy the lower your cost
PM/Call/Email us for best service and prices
Regards,
Old 06-29-2010, 10:34 AM   #10
Trader Rating: (63)
BC's DOING WORK!
Old 06-30-2010, 10:21 AM   #11
Trader Rating: (63)
Regards,
Old 07-01-2010, 11:49 AM   #12
Trader Rating: (63)
Regards,
Old 07-02-2010, 11:49 AM   #13
Trader Rating: (63)
To the top for great combo deals!
BC coilovers IN STOCK!
Regards,
Old 07-06-2010, 03:15 PM   #14
Trader Rating: (63)
Regards,
Old 07-11-2010, 11:33 AM   #15
Trader Rating: (63)
Regards,
Old 07-12-2010, 02:02 PM   #16
Trader Rating: (63)
Regards,
Old 07-13-2010, 12:24 PM   #17
Trader Rating: (63)
Regards,
Old 07-14-2010, 10:49 AM   #18
Trader Rating: (63)
Regards,
Old 07-15-2010, 08:59 AM   #19
Trader Rating: (63)
Combo ISIS parts with BC racing and get crazy deals
Regards,
Old 07-16-2010, 12:01 PM   #20
Trader Rating: (63)
Regards,
Old 07-17-2010, 07:02 PM   #21
Trader Rating: (63)
To the top!
Ask about our $50 gift certificate for ImportImageRacing.com when you buy BC racing coilovers!!
Regards,
804-690-2452
Old 07-18-2010, 02:22 PM   #22
Trader Rating: (63)
To the top!
Regards,
804-690-2452
Old 07-19-2010, 08:29 AM   #23
Trader Rating: (63)
Come get your BC coilovers!
For best deals and quickest response PM or email Billy@importimageracing.com
$999 shipped w/ $50 credit to ImportImageRacing.com!!!
Regards,
804-690-2452
AIM:ImportImageBilly
Old 07-20-2010, 11:59 AM   #24
Trader Rating: (63)
Get your sway bars with your BC coilovers for crazy good pricing combos!
Buy BC and get a $50 credit to ImportImageRacing.com!
Regards,
804-690-2452
Old 07-21-2010, 01:58 PM   #25
Trader Rating: (63)
Regards,
Old 07-22-2010, 02:01 PM   #26
Trader Rating: (63)
Regards,
Old 07-23-2010, 01:41 PM   #27
Trader Rating: (63)
Regards,
Old 07-24-2010, 11:45 PM   #28
Trader Rating: (63)
Do we ever stop working??????
NOPE!
PM US!
We'll get you the best deals 24/7
Regards,
804-690-2452
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.0
