| South Central States Arkansas, Kansas, Louisiana, Missouri, Oklahoma, and Texas. |
| | #1 |
| Zilvia Junkie ![]() | anyone know a good shop in the DFW area to do some machining and assembly of my motor? motor is sr20det, basically looking to get the head cleaned/hot-tanked, mild port-n-polish, machining of head surface, and assembly. for the block im looking for through cleaning, and inspection of rotating assembly, install new bearing, pistons, rings, pins etc...and decking, w/front cover etc... and a final assembly of head and block with arp hardware, new headgasket, new freeze plugs etc... THANKS in advance!! |
| Sponsored Links | |
| | #2 |
| Leaky Injector | if you wanna head over to phoenix with it...there is a bad ass guy did the vq swap in my sentra...his name is travis...website fi-r.net...you can shoot him a pm on myspecv.com or b15sentra.net sn is trav4011...he does afuckingmazing work |
| | #3 |
| Leaky Injector | go to my good man Tay, he had a shop in irving right off of o'connor, he moved to grand prarie though, and he's the best IMO as far as workin on 240s... text me if you want more info 682 553 8343 |
| | #4 |
| Zilvia Junkie ![]() | i've heard that name before, but i didnt know he had a shop, does he do machine work as well? |
| | #6 |
| Zilvia.net Advertiser ![]() | We are right here in Bridgeport, roughly 45 minutes from downtown Ft Worth. Regards, Robert
__________________ MVP Motorsports 940-683-8282 x20 Robert Del Angel Master Distributor for : RPS, Tein, Seibon, C's, HKS, Greddy, Cusco, Blitz, Koyo, AEM, Map ECU, Eibach, Tokiko, Power Enterprise, ARC, Volk, Fidanza, Defi, ....and so many more!!! |
| | #7 |
| Zilvia Junkie ![]() | Automotive Machine in Fort Worth is really good. The built "SpanishRicer's" engine after he dropped a valve due to a cracked valvespring. I'm using them to overbore and rework my VH45. I use Watts for B-series, 2jz's and Viper V10's... you might give him a call and see if he has any SR20 experience. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
