Old 12-24-2005, 01:07 AM   #1
kuramaya
kuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfection
Z32 MAF Install SR20DET (Pics)
Well here is my next addition. I have a shitload of parts I have to install, today I tackled the Z32 MAF. Easy right? In and out? Well not exactly so I made sure to document the Issues I had and the fixes. There are more than one way to install. This is myway and it worked:
Items Needed:
Z32 MAFS
Intake that fits the Z32 MAFS
80MM Grommet
2 80mm Hose Clamps
80MM to 60MM Aluminum Pipe
Wire Harness
Steel bar for support
Electrical Tape
Wire Connectors
Tools
This write up may help. If it does, give me some points please
**Disconnect your negative Battery Terminal**
Okay well getting started, I ran into an immediate problem. The Z32 MAFS intake side did no fit the APEXi Intake I had been usuing with my stock MAFS.
Fix was, I bought a new APEXi Intake.
Okay to attach the MAFS to the Intake depends on the intake itself..make sure you keep hold of the little rubber gasket ring that goes bewteen the MAFS and the Intake, it sits in a little valley type area on the MAFS. Then use a paper style gasket between the intake and the MAFS and use the 4 screws to secure it nice and tight.
Okay now pull out your old MAFS and Intake and you will see the next problem.
The Stock MAFS has an 60mm exit to the stock compressor pipe...your new Z32 MAFS has an 80mm one. I eventually plan on getting a full aluminum pipe made that will go all the way up from the compressor to the intake, but for now I had to improvise cause I hate to stop in the middle of sh1t unless it is for beer or good head from a hottie...so what I did was headed down to the speed shop and bought an 80mm to 60mm reducing pipe and a gromet...
See you can't just use a reducing grommet, becuase the stock compressor piping is rubber if you used a rubber style gromet it would collapse..you need something strong in there that wont collapse. Use two hose clamps and attach the MAFS with installed intake to the Reducing pipe using the grommet. Once your done it should look like this, mine looks like an F15 motor now:
Then put the pipe in. You can slide it down the stock rubber compressor tube and use the stock hode clamp to secure it on the 60mm end of the reducter. Push it in as far as you can, there isnt much room. It will look like this now, and yes I had just enough room...
it is time to cut the harness you are looking at in the picture above....make sure you cut it about 2 cm's from the tip. This way it can still be used again.
Then get your wire diagram and wire the stuff up:
Here is the breakdown using the Harness I bought for 20 Bucks..
From Right to Left:
White - to White on the stock Harness
Black - to Ground on the car
Black - to the Black on the Stock harness
Red - to the Black and White stripes wire on the Stock Harness
Attach all of the wires from the new Z32 Harness to your stock wire cluster...use the direction above. You can either solder the wires (preffered) or do what I did. I just used wire connectors and crimped them together, then wrapped the harness in black tape. I didnt wanna do it permanantly with solder yet since I am going to have an intake pipe made for me later and may have to reduce the harness length.
Then you will still have the ground wire to deal with...I extended the ground wire and set it right below my profec motor..but there are plenty of places to ground it at..
Okay now here is what the finish product will look Like installed...The only thing left to do is reconnect your battery cable and start up. If you have an SAFC II like me, you will have to make an adjustment in the ETC menu prior to startup. Go into ETC, choose Sensor Type, choose HW and In "2" and Out "6":
Next write up is 550's and AEM UEGO wideband install
Late
Daryl
ZEROYON WEBSITE IS HOMO
NEW SITE: blacklinux.com/innersanctum/index.php
kuramaya is offline
Old 12-24-2005, 01:35 AM   #2
HyperTek
I didnt know the Shocker was required for the install.. hehehe jk.. Nice write up
Keep it Classy
HyperTek is offline
Old 12-24-2005, 02:55 AM   #3
caall99
caall99's Avatar
caall99 is an unknown quantity at this point
Send a message via AIM to caall99
your write-ups are awesome! keep em comin'!
Signature over limits
http://www.zilvia.net/f/showthread.php?t=21036
caall99 is offline
Old 12-24-2005, 03:35 AM   #4
95zilvia
95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light
We should make your own section, you are the bomb diggity. +++++
95zilvia is offline
Old 12-24-2005, 03:47 AM   #5
kuramaya
Wow Thanks Guys! That means a lot..I have a few I havent posted...like the Acuator Install I did last weekend when I though mine was bad
you guys could always give me some rep points
J/K
Late
Daryl
kuramaya is offline
Old 12-24-2005, 07:05 PM   #6
kuramaya
Thanks for all the Rep's guys!
kuramaya is offline
Old 12-24-2005, 07:52 PM   #7
vutony
vutony's Avatar
Trader Rating: (143)
vutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfection
Feedback Score: 143 reviews
nicely done....this was gonna be my next mod and now made it much easier
vutony is offline
Old 12-24-2005, 08:33 PM   #8
kuramaya
Glad I could help!
kuramaya is offline
Old 12-25-2005, 10:23 AM   #9
vutony
vutony's Avatar
quick question...would the install with a R33 maf be the same...which is better the Q45 maf or Z32 maf...lmk....thanks
vutony is offline
Old 12-25-2005, 11:40 AM   #10
WILDACEX187
WILDACEX187's Avatar
WILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond repute
Send a message via AIM to WILDACEX187
awesome write up daryl. as stated before you are the BOMB lol
SR POWA COUPE LUVVV!!!
WILDACEX187 is offline
Old 12-25-2005, 04:17 PM   #11
kuramaya
Thanks WIldace!!!
Z32 Flows better than the Q45...There is not a better MAFS to use...Discussion came up locally and found out nothing beats the Z32...now are you saying you want to install an RB25DET or RB26DETT MAFS on an SR20DET? I wouldnt do it...The GTR MAFS have no where near the flow as the Z32..I can prove it if need be with a test done..but I would have to find the file to upload..
Late
Daryl
kuramaya is offline
