Old 06-20-2014, 02:01 PM   #1
boost infested
boost infested's Avatar
boost infested is on a distinguished road
Boosty - Street build LS# s13 coupe 5.7L
Power/current specs:
HP 384
TQ 370
Dyno Dynamics 450 DS
Engine:
- 5.7L LS1
- Fast 102mm intake
- Fast 102mm big mouth throttle body
- Holley EFI LS fuel rails
- 243 z06 heads with sodium filled valves
- 650" dual valve spring kit
- LS7 lifters
- Comp Cams trunnion upgrade kit
- Comp Cams 7.3" 5/16 push rods
- Comp Cams XFI XR277HR cam
- Forged Mahle pistons
- stock rods
Engine Dress up:
Holley LS valve covers
Chasebays - relocation brake lines
Plasti dipped intake
MSD wires
Suspension and handling:
s15 5 lug conversion
Stance GR+Pro LS swapped specific
Sikky front swaybar 32mm tubular
Tanabe rear swaybar 27.5mm
Wheels and tires:
Work VS-KF burning black
front: 18x9.5 +7mm (107mm Lip) 225/45
(needed 4mm spacers to clear the z32 caliper)
rear: 18x11 +20mm (120mm Lip) 265/35
(needed to bash rear inner tub, 8mm spacer to clear the inner wall)
Braking System:
front: s15 4 pistons
rear: stock
Exterior
s13 silvia front conversion
s13 silvia aero front bumper
s13 Chargespeed silvia aero front lip
s13 chuki 180sx side skirts
s13 Bomex Bonneville rear valance
s13 Dmax roof spoiler
s13 Circuit Sports taillights
Love these s15 seats
Rusty frame rails repair.
New metal!
Por15
On some ugly ass MRR 19x8 and 19x9
Temporary fix... Varrstoens. 18x9.5 18x10.5
Onto a face lift. Good bye number5 and hello silvia
Ugh.. don't like the fitment of these Origin fenders..
added Bomex Bonneville rear.... It's RARE!
I got a free jdm aero bumper for free but it was cracked and warped but I got it fixed! Like brand new again!
Back with the oem metal fenders
Very last order of these VSKF from Ravspec
So lucky to buy these brand new
18x11 +20(12)265/35 needed inner tub bashing and a 8mm spacer
18x9.5 +7 225/40 (needed a 4mm spacers to clear the z32 caliper)
18x11 +20(12) 265/35
Found a aero lip for sale.. not sure the brand.. Vanquish? Looks like the old school Chargespeed aero lip rep.
It's getting hard to find oem parts. Found this from a zilvia member in Thailand.
An impulse buy... should have gone with a crate engine instead...
She's going under the knife.
What a mess..
Can't decide on cutting the factory tubs out or not. F@ck it go big.. more work.
boost infested is offline   Reply With Quote
Old 06-23-2014, 08:33 PM   #2
boost infested
Don't judge too hard first time doing this lol. I don't have a plasma cutter everything was cut by a die grinder. This is also my first time doing this sort of work.
Ok, I am so sick of grinding. I cheated with seal sealer over welded area.
BNR34 white QM1
Old 06-23-2014, 10:50 PM   #3
boost infested
Mahle forged pistons with Comp cams XFI XR277HR cam 54-418-11
low mileage 243 heads from a LS6(z06) with sodium filled valves. Manley Valve dual spring kit with titanium collars .650" lift max.
a quick test fit..
Sikky LS swap parts bought with Wiring Specialties.
My stock intake came broken. So I replaced with the FAST 102 intake and throttle body.
ChaseBays z32 brake master hide away brake lines.
Tremec Magnum 6spd. The length from the bell housing to the shifter is 26.6" vs oem t56 is 29.5" The difference of 2.9". The oem t56 is already about 1.5" away from the center of the s13 shifter hole. To fix this you must use Sikky's 350z LS swap magnum shifter. Version 2 is ready to roll (June 22nd). You also have to get a Spicer slip yoke(1330 Series 31 spline) and YOU HAVE TO SHORTEN THE SIKKY DRIVE SHAFT.
A quick test fit with just the bell housing bolted up to the long block.
Monster Clutch Level 3 700 HP/TQ with light weight billet 18lbs flywheel.
Old 06-23-2014, 11:06 PM   #4
boost infested
Engine and trans bolted together and back into the engine bay.
1 7/8 headers install problem..
driver side: top view and bottom view
passenger side last runner is touching the frame rail: top view and bottom view
Old 06-24-2014, 12:27 AM   #5
speeddream
speeddream is an unknown quantity at this point
Sick build
speeddream is offline   Reply With Quote
Old 06-24-2014, 05:38 AM   #6
smokescreen240
smokescreen240's Avatar
smokescreen240 is an unknown quantity at this point
I can't say i like where this is going......because I LOVE it. clean! looking forward to seeing this finished.
smokescreen240 is offline   Reply With Quote
Old 06-24-2014, 07:48 AM   #7
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
Geez buddy you are not F-ing around. Amazing build for sure. I look forward to what comes of this build especially with your attention to detail. Subed!
2muchboost is offline   Reply With Quote
Old 06-24-2014, 07:54 AM   #8
turbo2nr
turbo2nr's Avatar
turbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enough
Send a message via AIM to turbo2nr
NIce choices in parts, cant wait to see it completed!
s14 kouki ka-t
turbo2nr is offline   Reply With Quote
Old 06-24-2014, 02:47 PM   #9
d_nice
d_nice's Avatar
Trader Rating: (39)
Feedback Score: 39 reviews
damn bro looking crazy
Old 06-25-2014, 03:42 PM   #10
1Day
1Day's Avatar
1Day is an unknown quantity at this point
Not sure about the S13's but watch your hood clearance with the 102. My dmax hood sits right on top of the intake.
1Day is offline   Reply With Quote
Old 06-25-2014, 04:57 PM   #11
bc.
bc.'s Avatar
bc. is an unknown quantity at this point
damn, already to the end
* S14SR22 * 9.0 c/r * GT3071R *
bc. is offline   Reply With Quote
Old 06-25-2014, 06:24 PM   #12
tricky_ab
tricky_ab's Avatar
Very nice build that you've got so far. I'm diggin' the quality parts
Instagram
Back for round two... 4 doors this time around...
Old 06-25-2014, 10:16 PM   #13
bova17
bova17's Avatar
bova17 is an unknown quantity at this point
Very clean and well done.
bova17 is offline   Reply With Quote
Old 06-25-2014, 10:42 PM   #14
boost infested
I added DEI fire sleeve to the brake lines. Body harness is 95% re-wrapped. Not sure where I am going to put the oil filter remote mount yet.
Waiting on
- Sikky Magnum shifter
- Sikky RH header
- shortening the driveshaft.
- battery relocation to the trunk
- brackets for the radiator fans
INSTAGRAM@boostinfested
http://zilvia.net/f/showthread.php?t=569294
Old 06-26-2014, 08:13 AM   #15
2muchboost
Trader Rating: (33)
Literally sitting here in my office drinking tea just envisioning this project once completed. I wish I had half the fabrication skills and 1/5 the attention to detail.
Old 06-26-2014, 09:33 AM   #16
KoukiMonsta
KoukiMonsta's Avatar
personally im having a coffee
but i like what i see!
Old 06-26-2014, 10:45 AM   #17
Mschiano.
Mschiano. is an unknown quantity at this point
In for more! Lookin super clean
Mschiano. is offline   Reply With Quote
Old 06-26-2014, 11:15 AM   #18
boost infested
Thanks guys, I can't wait to fire it up.
Old 06-27-2014, 05:38 PM   #19
niscur29
Location: Back IN FL, bring nice cars to the fail state!
niscur29 is an unknown quantity at this point
niscur29 is offline   Reply With Quote
Old 06-27-2014, 05:57 PM   #20
boost infested
#noclub #anticlub
Old 06-29-2014, 01:53 PM   #21
Royal_T
Royal_T's Avatar
Royal_T is an unknown quantity at this point
Man build is looking good.. Keep it up
http://zilvia.net/advertise.html
Royal_T is offline   Reply With Quote
Old 08-28-2014, 08:15 PM   #22
boost infested
First start
https://flic.kr/p/oNwhnu
Old 08-28-2014, 09:17 PM   #23
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
I can't wait to hear this ROAR!
REVIEW
killer240 is offline   Reply With Quote
Old 08-28-2014, 11:15 PM   #24
S14outlaw
S14outlaw's Avatar
S14outlaw is an unknown quantity at this point
Awesome build thus far! Love the attention to detail.
S14outlaw is offline   Reply With Quote
Old 09-01-2014, 08:33 PM   #25
boost infested
First world problem,I can't close my hood. After removing the underside bracing, the damn 4" elbow still in the way of the hood. Fast104 intake manifold, throttle body and a 4" elbow is just slightly too tall for the hood to close.
Second option, carbon creation hood. I personally don't like it but I made it some what closed for now.
5 hours later lol I still like the factory hood style better.
Old 09-02-2014, 05:38 AM   #26
smokescreen240
Once again, loving the build good sir. Keep em comin'!
Old 09-02-2014, 07:15 AM   #27
1Day
1Day's Avatar
Time for a Origin Type 2 hood. Its only hitting in the front at the elbow? I would almost bet it will hit on the intake, right where it says LSX, once you got the eblow/tb to clear. Thats where my 102 just kisses the hood.
Old 09-02-2014, 01:59 PM   #28
Royal_T
Royal_T's Avatar
Amazing so far..
Old 09-02-2014, 09:08 PM   #29
boost infested
I was just looking at the Origin hood.
The stock hood with the bracing removed the "LSXR" part will still touch the underside of the stock hood.
My carbon creation one will clear the "LSXR" part but the 4" elbow still touch the flat part of the under hood.
Old 09-02-2014, 10:29 PM   #30
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
We'll dam! Love everything so far but why not a dmax hood?
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
