Old 05-12-2014, 08:29 PM   #1
Noxy
Noxy's Avatar
Trader Rating: (18)
Noxy is an unknown quantity at this point
Feedback Score: 18 reviews
S13/CA/SR Garage Cleanup
Hello again, Zilvians. Summer break is here and tis the season for cleaning/clearing. Just have a a lot of parts from my 240 days cluttering up my house, and I need to make room for B-Chassis parts. Also, This is pretty much all I have left other than little bits, so you can ask if I have something, but not much chance that I do.
Contact Info:
Email (paypal): [email protected]
Shipping: Yes, on most things. I drive frequently to Minnesota, and I could drive within 3 hours from Omaha.
Phone: 402-215-8440
S13
1. Front Door Speaker Cowls has some extra screw holes but worked fine- $23 shipped for both
2. Rear seat belt brackets- $8 shipped both
3. Front seat rail trim (Driver/Passenger)- both for $21 shipped/ each $14 shipped
4. Front seat recliner handles (Driver/Passenger)-Both for $14 shipped/ Each $8 shipped
5. Rear seatbelt anchors- $9.00 shipped
6. Coupe Map/Dome light-$12.00 shipped
7. Auto trans shift plate- $5 shipped
8. Wiper cowls- $10 + shipping
9.Sunvisors (Driver/Passenger)- Both $20.00 shipped/ Each $12.00 Shipped
10. Trunk Carpet- A bit dirty, but should clean up well enough- $15.00+shipping
11. OEM Rear floormats (Driver/Passenger)-both $24 shipped/ each $13.00 shipped
12. Various under dash control boxes-Tell me what you need
13. B-pillar covers (faded, but decent condition)- $18.00 shipped for both
14. Front seat bolt covers (Driver/Passenger)-$15 shipped for both sets
38. KA24DE water pump pulley- $9.00 shipped
39. KADE alternator pulley- $8.00 shipped
40. Driveshaft carrier bearing (bracket)- $15.00 shipped
CA18
16. Auto Trans dust plate/trans-block sandwich plate- $Free
17. Coolant Lines/Metal manifold pipes- $9.00 shipped each
18. Metal AAC valve hardpipe-$8.00 shipped
19. Random heater/vacuum hoses- Tell me what you need
20. Coil pack bracket-$11.00 shipped
21. Ignitor chip Bracket+Bolts- $15.00 shipped
22. Cam gears and hardware- $25.00 shipped for both
23. Intake camshaft- $25.00 shipped
24. Water pump pulley-$12.00 shipped
26. Throttle body + Bolts- $25.00 shipped
27. Valve Covers + hardware-$35.00 shipped
28. Cam gear-head sandwich plate- $14.00 shipped
29. Intake side Tranny brace- $15.00 shipped
30. Oil Block/Cooler- $18.00 shipped
31. Secondary butterfly valve solenoid- $14.00 shipped
32. Throttle position sensor- A spare I had- $16.00 shipped
33. Valve covers- $30+shipping
42. CA18DET cam caps- Alittle dirty, but pulled from my running engine- $30.00 shipped
SR20
34. S13 turbo compressor outlet pipe + Bolts- $25.00 shipped
35. Turbo oil line/drain flange and hose- $15.00 shipped
36. O2/dump pipe-$20.00 shipped
New/Aftermarket/Special Interest
A1. Brown key light ring- Comes with pigtail and green bulb- $10.00 shipped
A2. Unorthodox Racing Vacuum Manifold- New. Bought this on NICO from 'EliteGTR' a while back, but never used it. comes with all fittings and mounting bracket. -$27.00 shipped
A3. Greddy Water Temp Sensor Adapter- Used. 34mm diameter. Blue 1/8" NPT. - $30 shipped
A4: OE KA24DE clutch- New. Bought a few years ago and never used. Comes with pressure plate, clutch disc and pilot tool, I also have a good TO bearing, and stainless braided clutch line if you need them.- $60.00 shipped
A4: OEM Maxima Cupholders- Had these for a bit, they are the spring loaded din pocket type (see pics below). The tray slides perfectly, and the cupholder overlay is in good condition, the tray is just a bit dirty. -$40.00 shipped
That should be it for now, I'll add more pictures later. PM/text/email is fine whenever and I'll try to respond within 12 hours. If you would like more than one thing I'll of course do a bit of a price drop.
Thanks,
Nox
1993 240sx- Parting out
2004 Spec V & 1993 NX2000- Daily 1&2
Noxy is offline   Reply With Quote
Old 05-12-2014, 08:40 PM   #2
coupesallday!
coupesallday!'s Avatar
coupesallday! is an unknown quantity at this point
Send a message via MSN to coupesallday!
Edit nvm it does. I'm interested in the clutch, do u have pics and what brand is it
Throw some glitter flake and crazy glue in there.
coupesallday! is offline   Reply With Quote
Old 05-12-2014, 09:53 PM   #3
Noxy
Noxy's Avatar
Trader Rating: (18)
PM sent, sir!
And for anyone else who could be interested. The friction disc is an Exedy, and the pressure plate is Valeo (?). The parts warehouse I worked at had a brand called Rhinopac and is an OE brand that generally makes kits using various brands for the different parts (I chose the one with an exedy disc).
Also, it was mounted, but the engine ended up getting repurposed before it was driven on. Thus the little bit of lube on the splines
Old 05-19-2014, 04:20 PM   #4
Noxy
Noxy's Avatar
Trader Rating: (18)
Bub-bump! Added some more pictures and a few things.
Old 05-25-2014, 10:20 PM   #5
Noxy
Noxy's Avatar
Trader Rating: (18)
Update bump! Added CA18 cam caps and Maxima cupholders!
Old 05-25-2014, 11:06 PM   #6
satal95
satal95's Avatar
Trader Rating: (24)
satal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud of
Feedback Score: 24 reviews
Interested in the ca valve covers for $35 shipped and would you have the house that goes from the intake vc to the intake manifold
Signature image exceeds allowable size.
satal95 is offline   Reply With Quote
Old 06-02-2014, 10:07 AM   #7
Jonathan76
Jonathan76 is an unknown quantity at this point
Do you or anyone have the injector resistor for the harness.
Jonathan76 is offline   Reply With Quote
Old 06-03-2014, 02:35 AM   #8
Noxy
Noxy's Avatar
Trader Rating: (18)
I do not, but you can use a DSM resistor if you rewire it. Easier to find than a OEM CA18 one. If you decide to go that route, I have the rewiring diagram.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
