Old 01-28-2014, 03:21 PM   #1
Jck240
Jck240 is an unknown quantity at this point
jgy fuel rail with 72lb msd injectors, plugs and resitors
up for sale is the fuel setup off my sr20, it is a JGY rail, msd 72lb injectors, the proper connectors for the injectors and the resistors required to run low impedance injectors on an sr20. the FPR is not included
the price for everything is $100
the price is so cheap because i am unsure about the condition of the injectors, so Im basically throwing them in for free. cylinder 2 in my engine leaned out last october and melted the piston and its possible the issue could have been caused by the injector. i never looked into it more than that because Im going with something different next year but ill throw them in with the rail so if the buyer wants to have them cleaned and tested its possible they can be used again. Im pretty sure the 3 other injectors are in prefect working condition, but i would at minimum have the second injector tested or jest replaced if you plan to use the others
if anyone has any more questions, you can text me at 860-237-1437
Jck240 is offline   Reply With Quote
Old 01-29-2014, 09:41 AM   #2
Jck240
Bump, dropped the price a bit.
Old 01-30-2014, 01:57 PM   #3
Jck240
Bump it up
