01-27-2014, 08:21 PM | #1 |
240sx Parts Sale EVERYTHING YOU CAN THINK OF!! GIANT LIST OF PARTS LOOK
ALL PURCHASES COME WITH INSURANCE, TRACKING INFORMATION, AND LEGITIMATE PACKAGING.
Some sellers are so terrible that is actually makes a difference to say that... Shitty isn't it? Text me for questions, info, or ask if I have something you need. TEXT ME PLEASE - 361-571-1026 DEAN NEW PARTS TO THE LIST: S13 Climate Control (Mint Condition) - $40 shipped S13 Rear Side Marker Lights - $20 shipped ea $30 shipped for both S13 Fuse Box Pigtails - $10 each shipped S13 OEM E-Brake Cables (GOOD Condition, not stretched) - $60 shipped S13 KA24DE Engine Harness Pigtails - PM me what you need $15 shipped each -S13 License plate light assembly - $25 shipped -S13 Window Amp - $25 shipped -S13 Ash Tray - $25 shipped -S13 Passenger Side Power Window Trim with switch - $25 shipped -KA24DE Oil Cap - $20 shpped -Driveshaft carrier bearing top half - $15 shipped -S13 Hatchback Trunk Light - $15 shipped -KA24DE Fuel Injector Caps - $15 shipped for 4 -S13 Door Handle Trim - $15 shipped -240sx Gas Cap - $15 shipped S13 Fuel Pump Harness Metal Cover - $15 shipped S13 Pop-Up Headlight Motor Covers - $10 shipped per pair S13 Gas Pedal Assembly - $20 shipped KA24DE/E Oil Filter Block - $20 shipped 240sx steering shaft U-Joint w/ bolts - $25 shipped 240sx Power Steering Rack Brackets w/ bolts - $25 shipped KA24DE Fuel Injector Bushings - $8 shipped for 4 KA24DE Cam Sprocket Bolts w/ washers - $10 shipped per pair 240sx Shock absorber cap - $5 shipped 240sx Hub Cap - $8 shipped S14 OEM Diff Bushings - $10 shipped KA24DE Oil Pump Drive, Key-way, and Bolt w/ washer - $15 shipped S13 Passenger Side Kick Panel - $18 shipped 240sx Shifter - $20 shipped 240sx Radiator Hold Down Brackets - $15 shipped per pair KA24DE Oil Filter Block Gasket OEM - $8 shipped KA24DE Throttle Body Gasket - $5 Shipped KA24DE Coolant Temp Sensor - $8 Shipped each S13 Radiator Bushings - $10 shipped per pair S13 89-90 Dash Connector Pigtail Chassis Side - $10 shipped KA24DE Flywheel Bolts - $20 shipped for 6 T25 Turbo Inlet Gasket - $5 Shipped KA24DE/E Throttle Position Sensor - $15 shipped KA24DE Spark Plug Clips Perfect Condition - $15 for all 4 shipped S13 Rear Side Marker Lights w/ harnesses - $15 shipped each S13 Hatchback Trunk Trim - $20 picked up S13 Front Crossmember - $60 picked up IMG_0728 by Dean Chinowith, on Flickr S13 Fusebox Bracket Engine Bay - $20 shipped IMG_0729 by Dean Chinowith, on Flickr S13 Power Window Glass - $20 Picked Up IMG_0731 by Dean Chinowith, on Flickr S13 Hatchback Tail Light Garnish - $20 picked up IMG_0732 by Dean Chinowith, on Flickr 91-94 S13 Dash Harness Pigtail (Chassis Side) - $15 shipped IMG_0733 by Dean Chinowith, on Flickr KA24DE 5-Spd Transmission Gussets - $35 shipped (Only because they're heavy) IMG_0737 by Dean Chinowith, on Flickr S13 Hatchback Tail Lights - $80 shipped IMG_0738 by Dean Chinowith, on Flickr S13 E-Brake Cables in good shape - $45 shipped 240sx Throttle Cable - $30 shipped S14 Auto Shifter Lock Cable - $15 shipped IMG_0740 by Dean Chinowith, on Flickr S13 Under Steering Wheel Dash Panel - $25 shipped S13 Hatchback B-Pillar Exterior Trim L + R - $20 shipped IMG_0747 by Dean Chinowith, on Flickr -S14 OEM Rear Sway Bar - $60 plus shipping -S14 OEM Suspension (great shape, 80,000 miles) - $40 plus shipping - S13 Headlights Brackets - 40 shipped IMG_0314 by Dean Chinowith, on Flickr Last edited by drifter92; 03-02-2014 at 07:53 PM.. |
