Old 01-08-2014, 10:06 PM   #1
s13 drifta
s13 drifta's Avatar
Trader Rating: (105)
s13 drifta is a glorious beacon of lights13 drifta is a glorious beacon of lights13 drifta is a glorious beacon of lights13 drifta is a glorious beacon of lights13 drifta is a glorious beacon of lights13 drifta is a glorious beacon of lights13 drifta is a glorious beacon of lights13 drifta is a glorious beacon of lights13 drifta is a glorious beacon of lights13 drifta is a glorious beacon of lights13 drifta is a glorious beacon of light
Feedback Score: 105 reviews
Arrow The Biggest SR20DET Parts Thread! Over 80 Pictures! OEM & Aftermarket! Must Look!!
Hi, I am listing all of the sr20det parts that I no longer need. If you see anything you are interested in, please post or send me a PM. I can take more pictures of any item upon request. Prices do not include shipping, please leave zip code for quote. I accept paypal and ship fast.
OEM head bolts w/ washers-$20
S13 cams-$70 for pair
S13 cam gears-$30 for pair
Oil feed tubes-$30 for pair
Rocker arms-$80 for set of 8
S13 redtop valve cover w/ T and PCV valve-$70
Valve cover T-SOLD
OEM oil cap-$10
OEM timing cover / oil pump-$70
Timing chain tensioner-$30
Crank / oil pump collar-$10
Crank pulley bolt w/ washer-$10
Lower timing chain gear-$10
S13 pulleys
P/S pulley-SOLD
Water pump pulley-$10
Alt. pulley-$10
Thermostat housing-$20
Temp sensor harness-$15
Water outlet-$30
Water inlet-$20
S13 intake manifold-$30
Intake manifold brackets-$20 for all 3
PCV valve to intake lines-$20
Coolant lines under intake manifold-SOLD
S13 throttle body w/ auto TPS-$60
Auto TPS-$30
SR20det injectors(great condition)-$80 for set
Injectors caps w/ bolts-$15 for set
S13 fuel rail-$30
FPR-$15
OEM exhaust manifold-$40
Blacktop rods-$80 for all 4
Crank girdle-$40
Girdle baffle-SOLD
Main bolts w/ washers-$20
Oil pickup / strainer-$25
Oil dip stick w/ housing-$25
Dip stick housing-$10
Knock sensor harness-$20
Rear seal housing (one tab broke)-$15
SR engine flex plate-$40
SR OEM flywheel (resurfaced then used for 5k miles)-$50
SR flywheel bolts-$20 for all 8
Throwout bearing sleeve-$10
S13 complete manual driveshaft non abs-$120
SR / KA engine brackets-$40 for pair
Skyline engine mounts (240sx upgrade, solid rubber)-$120
J4 type x blacktop engine harness (complete and uncut)-SOLD
S13 sr20det to s13 240sx plug n play engine harness-SOLD
Redtop sr20det ECU-SOLD
Sr20det ignitor chip (small chip underneath)-SOLD
Coil packs in great condition-SOLD
Coil pack harness-$30
T28/GT28 bottom mount turbo line kit (steel braided water lines, hard oil line, AN fittings, banjo bolts, and washers)-SOLD
T25 water inlet line-$10
T25 oil feed line-$10
Water line banjo bolts-$5 each
PM me for s13 or s14 parts!
s13 drifta is online now   Reply With Quote
Old 01-09-2014, 12:25 AM   #2
s13 drifta
s13 drifta's Avatar
DIF Goodridge T2 bottom mount return line-$40
Mishimoto radiator cap-$15
CAS (has chip on plug, harness plugs in)-SOLD
IACV (metal screw)-$70
Power steering pump complete with banjo bolts, bracket, and pulley-SOLD
S13 power steering bracket with bolts, tensioner, and tensioner bolts-SOLD
S13 high pressure power steering line-$50
S13 power steering hard line-$40
SR alternator-$70
Alternator bracket, bolts, tensioner bracket, and tensioner bolts-$40
S13 SR OEM water pump-$30
HKS 2 bolt compressor inlet-SOLD
OEM 2 bolt compressor inlet-SOLD
SR OEM upper radiator hose-$10
S13 OEM SR MAF-SOLD
Q45 MAF-$50
OEM intake-$30
HKS direct drive purple air filter-SOLD
S13 SR crank pulley-$50
Oil sandwich plate-$30
All bolts bagged and labeled (let me know what you need)
SR20 manual transmission-$290
S13 manual tranny bracket-$40
Greddy aluminum cold pipe for stock manifold (small wear spot)-$50
Greddy Type S BOV Proven Performance edition-$120
CX racing 1 piece dump and downpipe (flex section is a scraped on bottom, doesn't leak)-SOLD
240sx B&M short shifter-SOLD
Blitz Dual SBC electronic boost controller-$180
MSD coils P/N 8224, $44.95 each new-$20 each
Vortech FMU 12:1-$80
Billet BOV w/ pipe-$40
28x6.5x2.5 FMIC (little tweaked, still works good)-$30
Autometer fuel pressure gauge w/ steel braided line-$30
Thanks for looking!
Old 01-09-2014, 12:59 AM   #3
RalliartRsX
Trader Rating: (30)
Feedback Score: 30 reviews
Have any O2 sensor harness??
RalliartRsX is online now   Reply With Quote
Old 01-09-2014, 05:00 AM   #4
turboking
turboking is an unknown quantity at this point
ill take the crank girdle. PM youre paypal account
turboking is offline   Reply With Quote
Old 01-09-2014, 08:11 AM   #5
Rob_A
Rob_A is an unknown quantity at this point
Do you have the coolant hardlines under the intake manifold?
Rob_A is offline   Reply With Quote
Old 01-09-2014, 10:04 AM   #6
robinsone
robinsone is an unknown quantity at this point
wow I don't even have an sr and I want to buy from you because your pics are so nice and clear, lol
robinsone is offline   Reply With Quote
Old 01-09-2014, 12:33 PM   #7
Rob_A
Oops I did not see the coolant lines posted, great! I will take them granted the inner hardlines arent rusty
Old 01-09-2014, 01:04 PM   #8
slimjim46
slimjim46 is an unknown quantity at this point
I'll take the ps bracket ship to 60042 8152451084
slimjim46 is offline   Reply With Quote
Old 01-09-2014, 01:13 PM   #9
Edwin562
Edwin562's Avatar
Pm me price for HKS direct drive filter shipped to 90605? thanks!
Old 01-09-2014, 05:49 PM   #10
1gr8bar10der
1gr8bar10der's Avatar
Trader Rating: (77)
Feedback Score: 77 reviews
The Biggest SR20DET Parts Thread! Over 80 Pictures! OEM & Aftermarket! Must L...
Might hit you up for some parts. Free bump for one of the most organized FS threads.
Sent from my iPad using Tapatalk
Old 01-09-2014, 11:53 PM   #11
slider2828
slider2828's Avatar
Baffle plate in the head.... Do you have please??!?!?
Turn and Burn!
Old 01-10-2014, 12:42 AM   #12
BlackZenki14
BlackZenki14 is an unknown quantity at this point
fuel rail shipped to 85053?
BlackZenki14 is offline   Reply With Quote
Old 01-10-2014, 03:53 PM   #13
s13 drifta
s13 drifta's Avatar
I have to check my spare harness to see if it's still there.
Thank you, I have other parts besides sr stuff. Let me know what you need.
$45 shipped. Let me know if you want it.
Thank you, just let me know what you need.
Yes, I have one. Just have to find it.
$42 shipped. Let me know if you want it.
Old 02-03-2014, 02:22 PM   #14
s13 drifta
s13 drifta's Avatar
I have found the baffle plate for the cams. Do you still need it?
Old 02-03-2014, 02:26 PM   #15
Fuego
Fuego is an unknown quantity at this point
Might hit you up after I get home to look at pics.
Fuego is offline   Reply With Quote
Old 02-03-2014, 05:30 PM   #16
Zbythegods
Zbythegods is an unknown quantity at this point
Figure I give it a try...Willing to sell one injector?
Zbythegods is offline   Reply With Quote
Old 02-03-2014, 06:22 PM   #17
Fuego
Take $20 for the intake mani?
Old 02-06-2014, 11:55 AM   #18
s13 drifta
s13 drifta's Avatar
Selling them as a set.
$30 is already a good price. Let me know if you want it.
Old 02-07-2014, 02:47 PM   #19
240KAR
240KAR's Avatar
240KAR is an unknown quantity at this point
will you do $30 shipped for the HKS 2 bolt compressor inlet? 37130 paypal ready.
1989 Nissan Silvia Q's
240KAR is offline   Reply With Quote
Old 02-20-2014, 12:40 PM   #20
Tay187
Tay187's Avatar
Tay187 is an unknown quantity at this point
Interested in the SR injectors... would you do $75 shipped to 83401?
DD - 92 240sx Sil-Vert - KA24DET
Wife's DD - 2013 Ford Focus ST
Tay187 is offline   Reply With Quote
Old 02-21-2014, 12:02 AM   #21
fiascoelment
fiascoelment's Avatar
fiascoelment is an unknown quantity at this point
How much for dump/down pipe shipped to 07305
fiascoelment is offline   Reply With Quote
Old 02-26-2014, 09:01 AM   #22
enriquetc240
enriquetc240 is an unknown quantity at this point
Hey bud,
Do you have any Cam caps??
enriquetc240 is offline   Reply With Quote
Old 02-26-2014, 04:30 PM   #23
icypuck17
icypuck17 is an unknown quantity at this point
I am interested in turbo lines kit and fuel pressure gauge sensor
icypuck17 is offline   Reply With Quote
Old 02-26-2014, 04:34 PM   #24
icypuck17
Have a whole front mount intercooler piping set without intercooler and with bov?
Old 03-19-2014, 05:27 PM   #25
s13 drifta
s13 drifta's Avatar
I can do $90 shipped.
Shipping will be $30 to NJ, $100 shipped.
The kit is sold, I have the stock lines and Goodridge return line.
Yes, I can put together a whole complete kit for you.
Old 03-19-2014, 10:07 PM   #26
signals13
signals13's Avatar
signals13 is an unknown quantity at this point
I'll do 80 for the downpipe? Will it fit a t28 turbo?
signals13 is offline   Reply With Quote
Old 03-21-2014, 09:29 PM   #27
bmitchell_ga
bmitchell_ga's Avatar
bmitchell_ga is an unknown quantity at this point
Do you have a s14 sr20 a/c compressor bracket with the pensioner?
bmitchell_ga is offline   Reply With Quote
Old 03-25-2014, 11:47 PM   #28
signals13
signals13's Avatar
Do you still have the downpipe? Are the bolts easy to install from underneath?
Old 03-26-2014, 04:19 AM   #29
Slidewayz90
Slidewayz90's Avatar
Slidewayz90 is an unknown quantity at this point
Still have the oem compressor inlet? and how much to ship to 33634?
In Disguise
Slidewayz90 is offline   Reply With Quote
Old 04-23-2014, 01:56 PM   #30
s13 drifta
s13 drifta's Avatar
I don't have a s14 a/c bracket w/ tensioner. Let me know if you need anything else.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
