Old 08-23-2013, 03:33 PM   #1
Sliderintrainin
Sliderintrainin's Avatar
Sr20det downpipe to trannsmission bracket question!
Hello zilvia, I'm trying to find the bracket that bolts from the exhaust insulator to the transmission mount. Any help would be appreciated.
Btw the part number for the insulator is 20610-52F00
Thanks
Sliderintrainin is offline   Reply With Quote
Old 08-23-2013, 04:03 PM   #2
Kingtal0n
Kingtal0n's Avatar
I would fabricate your own. unless you are using an OEM downpipe it probably wont line up properly anyways.
Kingtal0n is online now   Reply With Quote
Old 08-23-2013, 05:36 PM   #3
Mikester
Mikester's Avatar
I ran my SR without the bracket connected (CA tranny)... No issues whatsoever... and a lot of aftermarket downpipes don't even come with it.
Old 08-23-2013, 05:38 PM   #4
e1_griego
e1_griego's Avatar
You should absolutely run that bracket. Takes the weight of the exhaust off the turbo which means your t2 gasket is less likely to blow. Also keeps t2 intact when your bro-low car is scraping exhaust everywhere
Old 08-24-2013, 07:14 AM   #5
So Make Like
So Make Like's Avatar
I would advise rigging up/welding a custom bracket if you're worried about stiff ride or low vehicle exhaust to ground contact backing your manifold or turbo bolts out and/or blowing turbo/manifold gaskets. It isn't needed, but is definitely helpful! PBM sells a cobra downpipe that eliminates the need for an elbow (less bolts to worry about) and uses a flex pipe in the downwards section to avoid scraping it on the ground and shaking off some vibrations to the manifold. It comes with a bracket that you can adjust to raise or lower the exhaust as well. That bracket will do the job. Well worth it in my opinion.
Otherwise, first suggestion: weld your own. Like others have said, there's a chance the stock bracket won't line up anymore...unless you're stock downpipe.
So Make Like is offline   Reply With Quote
Old 08-24-2013, 08:03 AM   #6
Sliderintrainin
My Isis downpipe has the bracket to bolt it to the tranny mount so I'm guessing they mounted it in the correct place to use oem pieces. I cracked my last manifold because I didn't have any flex pipe in my downpipe and this not connected.
Old 08-24-2013, 04:32 PM   #7
So Make Like
I see. The part of the bracket that bolts to the transmission is still on mine, but the rubber bushing that connects the exhaust side and the tranny side of the bracket is ripped in half, so it's no longer connected. I've searched around a few times and couldn't seem to locate if not even find the name of the whole replacement part. That's why I just resorted to making a custom one. It was a hell of a lot cheaper than I'd imagine ordering a genuine nissan part or something of the like. But since you have the bracket, why not just bolt it on? Or is it only part of it?
Old 08-27-2013, 08:01 PM   #8
Sliderintrainin
For those who are also looking for the bracket, I was able to locate the part number for it. It is
20712-S13002. It can be bought at courtesy nissan along with the insulator(P/N in OP)
Old 09-17-2013, 06:40 AM   #9
Mikester
Mikester's Avatar
Thanks for the PN#
Old thread... but there is a reason I'm bringing this back...
Short story time...
Back in 2005, I bought a $50 SS Autochrome Ebay ezpeciale outlet elbow. The welds failed right at the 5-bolt flange. Figured I had gotten exactly what I payed for; so I payed the big bucks for an HKS outlet... Fast forward to recently; when I looked under my hood to locate/fix an exhaust leak and found this:
^^Yup, that's my 'no longer procurable' HKS outlet!
I had thought the failure at the flange was a quality issue. As you can all see, quality wasn't the issue... The issue at hand was not utilizing that bracket.
Bottom line- I was dead wrong in my previous post.
Anyone who may stumble across this thread- Use that bracket, fab one up... whatever you need to do; or something resembling the pic above will be in your future
Old 12-19-2013, 12:27 PM   #10
95zenki man
what he said ^^
i didnt have it on for the longest time and could never figure out why bolts would keep coming lose all the time... shortly after the manifold cracked.
95zenki man is offline   Reply With Quote
Old 12-19-2013, 02:58 PM   #11
Mikester
Mikester's Avatar
^^See those two holes in the lowest pic? Your manifold cracked because you (or whoever installed it) didn't have the manifold brace installed. It's a brace that goes from the 4-bolt flange to the exhaust port flange and keeps ir rigid; precluding cracking there or at the runners. HOWEVER, I am certain that not having the tranny to DP bracket didn't help lol
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright © 1998 - 2014, Zilvia.net™
