Old 08-23-2013, 03:19 PM   #1
revenn
revenn's Avatar
s13 s13 5 lug hub bearings
Hey guys I have been searching for this for a while and I cant seem to find an answer and the ones I have found confuse me. So I have a 90 s13 just went 5 lug with s14 hubs but the bearings are a bit loose and Id like to change them. What bearings should I get and how can I get them in there. I read something that said I was fucked if I didn't have the s14 control arms and that I would just have to buy new hubs? But that doesn't seem right.
Sorry If I did miss this. Thanks for the help!
revenn is offline   Reply With Quote
Old 08-23-2013, 03:35 PM   #2
blackrms13
blackrms13's Avatar
so you have s14 5 lug hub all around, but no s14 FLCA and etc?
91' 240sx Fastback LE
blackrms13 is online now   Reply With Quote
Old 08-23-2013, 03:38 PM   #3
revenn
revenn's Avatar
correct all stuff is just s13 stock stuff
Old 08-23-2013, 03:44 PM   #4
Rich260z
So someone just sent you s14 hubs? no spindle? and is it mostly loose in the front?
Rich260z is offline   Reply With Quote
Old 08-23-2013, 03:46 PM   #5
revenn
revenn's Avatar
the rears have spindles but the fronts dont need them? right?
Old 08-23-2013, 03:47 PM   #6
revenn
revenn's Avatar
and yes the front ones are loose rears are good
Old 08-23-2013, 03:50 PM   #7
Rich260z
The rears are knuckles, the the spindles are in the front. You need s14 spindles since they have the correct diameter for the s14 hubs. Also if you use the s14 spindle you have to use an s14 flca because the balljoint taper is different.
So whoever sold it to you either withheld info, lied to you, or assumed you just needed the hubs.
Old 08-23-2013, 03:52 PM   #8
revenn
revenn's Avatar
I mean the hubs fit over the axle and it spins freely?
Old 08-23-2013, 04:00 PM   #9
blackrms13
blackrms13's Avatar
rear s14 hubs you can just slap on
front s14 hubs you need all the spindle/FLCA etc to fit properly...
that's why lots of manufacture makes s13 conversion hubs for the front only...
Old 08-23-2013, 04:02 PM   #10
revenn
revenn's Avatar
god damn it....what is a good kit to get for front hubs
Old 08-23-2013, 04:05 PM   #11
Rich260z
Contano, they are in the forsale section and are fairly cheap and quality. $125 for the front pair. Maybe more now.
I used them in the front and have put about 7k miles on them, they work great. Most of the mileage was from FL to CA and there wasn't a single issue.
Old 08-23-2013, 04:06 PM   #12
revenn
revenn's Avatar
and I dont need anything else besides rotors correct?
Old 08-23-2013, 06:06 PM   #13
blackrms13
blackrms13's Avatar
do some research...
Old 08-23-2013, 06:34 PM   #14
revenn
revenn's Avatar
yup just looked em up not bad good price pretty solid reviews.
Thanks for the help guys really appreciate it!
5 lug, bearings, hub, s13, s14
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright © 1998 - 2014, Zilvia.net™
