Old 04-25-2004, 10:34 AM   #1
kcolyer27
kcolyer27's Avatar
kcolyer27 is an unknown quantity at this point
SR How much psi on sr20?
Got stock sr20det, greddy fmic, apexi n1 ehxuast, downpipe, few other things. What psi should i use at the track that would be totally safe? Ive heard 14 is totally safe so let me know waht u think.
kcolyer27 is offline   Reply With Quote
Old 04-25-2004, 01:05 PM   #2
AlexAtPerformanceNissan
AlexAtPerformanceNissan is an unknown quantity at this point
Send a message via AIM to AlexAtPerformanceNissan
Talking
I would feel safer staying between 11-12psi. IIRC, the turbo is pretty much being maxed out at 14psi as well as the load on the injectors. Just my opinion, not stating a fact.
-Alex B.
DETONATION
PERFORMANCE NISSAN
AIM: NeedsMoSpeed
MyNismo.com
AlexAtPerformanceNissan is offline   Reply With Quote
Old 04-25-2004, 09:38 PM   #3
philbro
philbro is an unknown quantity at this point
With out injectors or at least something to tune your fuel, i would not run much more than 12. With injectors and at least a safc you could run 1 bar not prob.
philbro is offline   Reply With Quote
Old 05-17-2004, 08:27 PM   #4
sr20thug428
sr20thug428 is an unknown quantity at this point
Send a message via AIM to sr20thug428 Send a message via Yahoo to sr20thug428
15
an sr20det comes stock with 7psi as you already probably know, and the stock turbo is safe up until 15 psi, but that is max until power falls off, with much pressure, you would need better injectors and a better blowoff probably
sr20thug428 is offline   Reply With Quote
Old 05-18-2004, 07:11 AM   #5
gsracer
gsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond repute
i have walboro fuel pump, nismo regulator, fmic,exhuast, blow off and i run 14 psi well actuall 14.5 everysingle day, no problems at all
ANTI-STRETCH NAZI
Vortech Supercharged Vh45de S14 V8nissans.com
gsracer is offline   Reply With Quote
Old 12-23-2004, 05:26 AM   #6
kuramaya
kuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfection
what PSI is your FPR set at?
ZEROYON WEBSITE IS HOMO
NEW SITE: blacklinux.com/innersanctum/index.php
kuramaya is offline   Reply With Quote
Old 12-23-2004, 09:47 AM   #7
mr_240sx
mr_240sx's Avatar
i got the same setup as your but i got a greddy type s BOV and ive been runnning 13lbs since july and everything is still good!
mr_240sx is offline   Reply With Quote
Old 12-23-2004, 01:15 PM   #8
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
i think you would want 45psi not sure though,
sepulchral is offline   Reply With Quote
Old 12-23-2004, 02:36 PM   #9
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
whats the advatnage of an adjustable FPR?
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 12-23-2004, 03:30 PM   #10
kuramaya
If you are running an aftermarket Pump (walbro, HKS,ETC) it may be pumping more fuel than you want to run..with an adjustable FPR you can set the Pressure to your taste and capabilities...for instance, now I am running 370cc injectors and only 11 PSI of boost, when I upgrade my Turbine and want to run 15 PSI and have 550cc Injectors I will want more fuel, so I can turn up the fuel pressure with the FPR.
late
daryl
Old 12-23-2004, 04:08 PM   #11
msaskin
msaskin is an unknown quantity at this point
Send a message via AIM to msaskin
Daryl...you're a bit wrong. You will have no need to pump up the base fuel pressure with larger injectors and/or more boost.
I ran the stock FPR with my stock setup, and I also ran the stock FPR with a walbro, 740cc injectors, and a GT2871 @ 21psi.
An adjustable FPR is used on some cars with upgraded fuel pumps (such as DSM's) since the stock FPR can't bypass enough fuel back to the tank, therefore the fuel will build up excess pressure in the rail, and cause you to run rich regardless. In these cases the aftermarket FPR is being used more for the excess flow out the return port than to adjust base FPR.
On most other cars there really is no need to increase base fuel pressure unless you're using it to artificially increase injector size (real sketchy) or for other reasons, which are rare enough that you probably have your own idea (right or not) as to why you're doing it.
~matt
it's not turbo lag...it's foreplay
'01 Ford Excursion Limited.
Powerstroke Diesel
Coming in spring: ???
msaskin is offline   Reply With Quote
Old 12-23-2004, 04:55 PM   #12
kuramaya
~matt
damn maybe I wasted 12000 Yen on this FPR then...I was told to get itto keep my PSI at 4 bar...so I can take it off and just use my SAFC II to adjust my fuel? Without even needing the FPR?
Thanks
Oh and I am from albany
Old 12-23-2004, 04:57 PM   #13
msaskin
100% correct. You'll be good with just an S-AFC and 550's. Sell the FPR
Where in albany? I'm in Troy for school (go to RPI). I'm actually back in las vegas (home) for the time being, but go back east in january. I take it you're overseas military?
~matt
Powerstroke Diesel
Old 12-23-2004, 05:02 PM   #14
kuramaya
~matt
Funny I have (2) NISMO FPR's..EBAY Time...
I am from Downtown Albany, down by the Pepsi Arena, went to Bishop Maginn H.S., I know RPI, you must be a smart one eh? Engineer? Yeah 13 years Marines...will retire in 7, staying in Japan for evar..
late
Daryl
