Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Suspension
Old 04-25-2013, 11:45 AM   #1
IMPORTIMAGE
IMPORTIMAGE's Avatar
Trader Rating: (77)
Feedback Score: 77 reviews
Send a message via AIM to IMPORTIMAGE
Arrow Fortune Auto Coilovers Series 4 (BRAND NEW!) @ Import Image Racing!******************
CALL 941-257-9618 and mention BILLY to receive special pricing ON ZILVIA!!!!!
+ COMBO WITH ANY SPL PRODUCTS!
Click here to see Fortune's for your Nissan!
Now with brake line brackets!
DIGRESSIVE* All Fortune Auto shock absorbers use Digressive piston technology. This technology allows for stiff low speed rebound force which helps give better control of driver inputs such as roll, dive and squat. However, at fast stroke speeds (i.e. high speed bumps) the suspension is kept supple in response to bumps and irregularities in the road.
- Dyno tested
- Mono-Tube damper with high pressure nitrogen
- 24-step rebound adjustable dampers
- Spherical Bearings
- IP synthetic 5w or 10w shock oil (prevents cavitation and promotes superior heat dissipation)
- 6061 Forged & Anodized aluminum mounts and camber plates**
- Height adjustment independent of pre-load
- 5 year Manufacturer's Warranty
- Swift springs upgrade available
- Rebuild-able in the USA
- Revalve-able in the USA
OPTIONAL SWIFT SPRING UPGRADE!
Optional Sealed Radial Bearing Mounts Upgrade!
Recently only available on race applications and mega dollar suspension systems. Fortune Auto now makes spring noise and spring "twang" a thing of the past. Needle Thrust Roller Bearings are essential for noise-free operation on vehicles with front strut configurations. Vehicles with front struts tend to turn the front springs on coilover applications. This results in the spring dragging on the spring perches and making an annoying "boing" or "twang" sound. This sound is harmless but can get annoying at times. This noise is more prevelant in low speed occurances such as turning into a parking spot or when temperatures are below 60 degrees Fahrenheit. We have also noticed that heavier cars benefit greatly from this solution (Evolutions & WRX/STi platforms.)
Fortune Auto now offers a solution to this common problem! Bearings come in a set of 4 for the front struts (with 8 thrust washer plates). The washer plates sandwich the roller bearings and sit at both ends of the spring / spring perch. This offers silky smooth operation and is truly a noise-free solution for any 60mm ID coilover! Our roller bearings are designed to be lubricated with white lithium grease before install. These bearings can also be installed at our facility on all new coilover purchases.
Fortune Auto 510 series coilovers
- Incorporate a "ULTRA" DIGRESSIVE" piston, 24-way damping, custom rates & a one year warranty
- 510 Series coilovers are CUSTOM built to order in the USA.
Featuring our new "Ultra" Double Digressive Piston (UDDP) with revised shim stacks, this "Ultra" Digressive piston allows for massive amounts of low speed rebound force that helps with driver inputs such as dive, pitch and roll. Furthermore, the rebound force greatly tapers off to provide the driver with a supple and compliant ride while maintaining superior mechanical grip over rough surfaces. After countless hours on the shock dyno and testing on the track, we are proud to offer these high performance coilovers that rival many high end European shocks that cost several thousand dollars more.
- Assembled in the USA
- Dyno tested
- Dyno graph supplied with all 4 shocks
- Amsoil synthetic shock oil (the ultimate in shock oil technology)
- "Ultra" Digressive piston
- Compliant track suspension solution
- Rebuild-able
- Revalve-able
DREADNOUGHT PRO 2-WAY SERIES COILOVERS
Regards,
Billy@importimageracing.com
AIM: ImportImageBilly
ImportImageRacing | Discount Performance Parts | Subaru, Mitsubishi, Nissan, Mazda Import Image Racing
Phone#: 941-257-9618
Visa/Mastercard/Discover/Paypal and (amex) Google checkout!
www.facebook.com/officialimportimageracing
IMPORTIMAGE is offline
Old 04-26-2013, 09:14 AM   #2
RD_240
Price for Fortune Auto 500 with 9k/7k with and without swift spring upgrade shipped to 60077 please?
Thank you
RD_240 is offline
Old 04-29-2013, 02:26 PM   #3
SidewayzAsFck
Price for Fortune Auto 500 with 9k/7k with and without swift spring upgrade shipped to 07062 pretty please?
SidewayzAsFck is offline
Old 04-29-2013, 03:08 PM   #4
Anhell_ito
s14 fortune auto 500 shipped to 92882?
Anhell_ito is offline
Old 05-06-2013, 01:03 PM   #5
IMPORTIMAGE
Trader Rating: (77)
Thank you
PMed!
Monday Bump!
Regards,
Old 05-08-2013, 12:33 PM   #6
IMPORTIMAGE
Trader Rating: (77)
Wednesday Bump!
Regards,
Old 05-09-2013, 01:41 PM   #7
IMPORTIMAGE
Trader Rating: (77)
Thursday Bump!
Regards,
Old 05-10-2013, 11:47 AM   #8
Morphious
Price of FA 500 for S13 shipped to 70131.
Morphious is offline
Old 05-12-2013, 03:11 PM   #9
DomChan
DomChan's Avatar
Price of FA 500 standard springs shipped to 92126 please! Thanks
Instagram: @domvillain
DomChan is online now
Old 05-14-2013, 11:56 AM   #10
Sheldon Rozon
Send a message via MSN to Sheldon Rozon
Price for s14 500's 8/6kg to victoria, bc, canada, v8t 3n4
Sheldon Rozon is offline
Old 05-17-2013, 01:46 PM   #11
IMPORTIMAGE
Trader Rating: (77)
Friday Bump!
Regards,
Old 05-20-2013, 05:46 AM   #12
Chl_drifter
s14 fortune 500 shipped to 75078
Chl_drifter is offline
Old 05-21-2013, 05:15 PM   #13
sandeezy
sandeezy's Avatar
s13 fortune 500 shipped to 91355
sandeezy is offline
Old 05-24-2013, 01:25 PM   #14
IMPORTIMAGE
Trader Rating: (77)
PMed!
Friday Bump!
Regards,
Old 05-24-2013, 02:32 PM   #15
str4g63
str4g63's Avatar
Send a message via AIM to str4g63 Send a message via MSN to str4g63
Price for s14 500 series with and without helper springs and 10k/8k shipped to 77084 thanks
str4g63 is offline
Old 05-24-2013, 03:53 PM   #16
240loco
240loco's Avatar
s14 Fortune 500 shipped to 60639
240loco is offline
Old 05-25-2013, 02:22 AM   #17
navans14
s14 Fortune 500's shipped to 92501
navans14 is offline
Old 05-25-2013, 05:19 PM   #18
harangatang
harangatang's Avatar
500 and 510 series for a 350z 14/10k spring rates (separate pricing) shipped to 75243
Thanks!
Tyler
harangatang is offline
Old 05-25-2013, 05:27 PM   #19
RB180sxChris
RB180sxChris's Avatar
sooo tempting!!!!ahhhhhhh
TO LEGIT TO QUIT.....
RB180sxChris is offline
Old 05-27-2013, 01:21 PM   #20
Marcyo
Prices on 500 and 510 series for s13 with swift 12/10k spring rates and radial bearings shipped to 98281
Marcyo is offline
Old 05-28-2013, 05:49 PM   #21
PureRush
350z Fortune 500's shipped to 92604
PureRush is offline
Old 05-29-2013, 11:35 PM   #22
tub53025
S14 FA 500 shipped to 19111
tub53025 is offline
Old 05-30-2013, 01:33 PM   #23
IMPORTIMAGE
Trader Rating: (77)
Thanks!
Everyone has PM or I spoke to you on the phone today!
Regards,
Old 05-30-2013, 02:11 PM   #24
PureRush
Also S13 510's shipped to 92604 What are the options for spring rates?
PureRush is offline
Old 06-04-2013, 12:41 PM   #25
IMPORTIMAGE
Trader Rating: (77)
Tuesday Bump!
Regards,
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright © 1998 - 2014, Zilvia.net™
