Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Forced Induction
Old 03-12-2013, 01:27 PM   #1
468POWER
468POWER is an unknown quantity at this point
Exclamation DOC RACE TURBO MANIFOLDS SPRING FLING Sale w/ FREE Shipping!!!
DOC RACE TURBO MANIFOLDS Blowout SPRING FLING Sale & FREE Shipping!!!
WE ARE CELEBRATING THE COMING OF SPRING WITH FREE SHIPPING ON TOP - LEAVING US WITH NO PROFITS ON THESE QUALITY GOOD 'OL USA MADE DOC RACE TURBO MANIFOLDS AND INTERCOOLERS!!! CONSIDER IT A PRESENT TO ALL OUR FELLOW ZILVIA NISSAN FANS FROM THE BESTEST DOC RACE AUTHORIZED DEALER - 468POWER / PERFORMANCE AUTOWORKS!!!
POST YOUR INQUIRIES HERE, PM, OR EMAIL US FOR OUR SPECIAL PRICES.
HERE ARE THE DETAILS AND PICS OF EACH MANIFOLD. WE ALSO HAVE MANIFOLDS FOR 350Z TURBO, Toyota 2JZ, 1JZ, Mazda 93+ RX7, Mazda Miata, Honda and more! We carry every item DOC Race manufactures. See their website for further details...
DOC Race Store, Turbocharging Components
For SR20DET...
Nissan SR20DET T3 Top Mount Manifold
Application notes:
-T3 flange
-Option for 2-bolt 38mm, Tial MVS or MVR/44mm wastegate flange
-Retains AC
Stainless downpipes are also available upon request for $350 in 3" Stainless with 4-bolt, 5-bolt or V-band flange.
The DOC Race Topmount Turbo manifold is for the more extreme setup looking for the potential limit of the vehicles engine. The DOC Topmount manifold can still be used for “streetable” vehicles, but is solely designed to make maximum horsepower and allow you to fit much larger frame turbo’s then our traditional ramhorn. D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds.
Nissan SR20DET T25 Bottom Mount
The DOC Race SR20DET T25 Bottom mount turbo manifold places your t25/28 framed turbocharger in the factory location. Made from sch 40 stainless steel and a true merge collector this manifold will maximize the output of any turbo that will fit on it.
Nissan SR20DET T4 Front Facing Manifold
Application notes:
-Open T4 flange (T3 option available below)
-Single Tial MVR or Dual MVS gate option
-Retains Powersteering and Air Conditioning on S Chassis
The DOC Race T4 Topmount Turbo manifold is for the more extreme setup looking for the potential limit of the vehicles engine. This manifold is capable of well over 1000hp in our Twinscroll version and is designed for peak-power situations. The DOC Topmount manifold can still be used for “streetable” vehicles, but is solely designed to make maximum horsepower and allow you to fit much larger frame turbo’s then our traditional T3 Center set manifold. D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds.
Nissan SR20DET V-Band Top Mount Manifold
Application notes:
Tial V-band Inlet flange
Option for MVS or MVR V-band wastegate flange
Retains AC
The DOC Race Topmount Turbo manifold is for the more extreme setup looking for the potential limit of the vehicles engine. The DOC Topmount manifold can still be used for “streetable” vehicles, but is solely designed to make maximum horsepower and allow you to fit much larger frame turbo’s then our traditional T25 Bottom-mount. D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds.
SR20DET High Port Billet Intake Manifold
DOC Race Billet SR20DET Intake Manifold. Works with most throttle bodies including the Ross Machine 90mm.
DOC Race Intake Manifolds are designed for extreme boost applications with increased plenum size and calculated runner length for optimum power delivery. These intake manifolds have CNC intake ports for proper airflow through the plenum. Intake manifolds are standard with a billet flange and an array of throttle body possibilities such as the sought after 90mm in the Mustang bolt pattern. DOC still applies our elaborate porting process to complement maximum flow within ALL of our manifolds.
This Intake Manifold is designed for maximum output of your SR20DET engine. ECU tuning will be necessary to gain all the possible torque that comes with this High Volume Intake Manifold.
-Will also work with factory-medium sized cams and smaller frame turbo's for mid-range gains.
For KA24DE Turbo...
KA24DE T3 Topmount Manifold
DOC Race Nissan KA24DE Topmount Manifold
-Fits ALL Twincam KA24DE Engines, 91-98 240SX
-Powersteering pump bracket modifications necessary
Available with a MVS or MVR wastegate flange, this T3 turbo manifold is for the more extreme setup looking for the potential limit of the vehicles engine. The DOC KA Topmount turbo manifold can still be used for “streetable” vehicles, but is solely designed to make maximum horsepower and allow you to fit much larger frame turbo’s then our traditional bottom-mount T25 manifold. D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds.
KA24DE T25 Bottom-Mount
The DOC Race Nissan KA24DE T25 Bottom-mount Turbo Manifold was designed to be a bolt-on manifold that will support most Internally Gated T2 frame turbo's. This manifold is able to use the SR20DET T25 Turbo outlet and retains A/C and Powersteering.
Made with 304 sch 40 Stainless steel and a true merge collector, this hand-built piece will take your T28 frame to the maximum!
For RB20/25/26...
RB20/25/26 Openscroll Topmount
DOC Race Open T4 Topmount available for RB20/25/26
-T4 Open Inlet Flange
-Single MVR Wastegate flange standard
The DOC Race RB Topmount Turbo manifold is for the more extreme setup looking for the potential limit of the vehicles engine. The DOC Topmount manifold can still be used for “streetable” vehicles, but is solely designed to make maximum horsepower and allow you to fit Larger Frame Turbo's. D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds.
RB20/25/26 Twinscroll Topmount
Application Notes:
-Standard with Dual Tial MVS V-band wastegate outlets
-Up to 4" downpipe
Tubing specs: 1.660" OD, 1.380" ID, 0.140" wall rated for 1300hp
The DOC Race Twinscroll Turbo manifold is similar to our Topmount manifold application. Our Twinscroll manifold is for maximum flow of your engine and turbo including the best possible spool and no limitations of the maximum output of your combination. DOC Race Twinscroll manifolds have had years of development in order to utilize the proper exhaust pulses to eliminate unwanted exhaust backpressure and vale overlap, in-turn giving you maximum airflow. This manifold is simply the most efficient available on the market! D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds.
POST YOUR INQUIRIES HERE, PM, OR EMAIL US FOR OUR SALE PRICES. And FREE SHIPPING!
So everyone can start getting their rides ready for the warmer weather!!!
468POWER is offline   Reply With Quote
Old 03-12-2013, 08:14 PM   #2
240sxfan6882
240sxfan6882's Avatar
240sxfan6882 is an unknown quantity at this point
Price on KA24DE Bottom mount please
240sxfan6882 is offline   Reply With Quote
Old 03-12-2013, 10:22 PM   #3
Treize
Treize's Avatar
Treize is an unknown quantity at this point
and
KA24DE T28 bottommount manifold
separate prices shipped to 91504 !
please and thank you
Treize is offline   Reply With Quote
Old 03-12-2013, 11:14 PM   #4
Dsmtuner
Dsmtuner is an unknown quantity at this point
price on SR20 Topmount T3, 44mm v band WG please
Dsmtuner is offline   Reply With Quote
Old 03-13-2013, 05:12 PM   #5
Team DET
Team DET's Avatar
Team DET is on a distinguished road
price on bottom mount sr20 shipped to 92410
(OΞO/- -\OΞO)
Team DET is offline   Reply With Quote
Old 03-16-2013, 09:10 AM   #6
468POWER
All inquiries replied to!
Old 03-21-2013, 04:14 PM   #7
Alan_405
Alan_405's Avatar
Alan_405 is an unknown quantity at this point
SR20DET T25 Bottom mount turbo to 73135 please
Alan_405 is offline   Reply With Quote
Old 03-21-2013, 04:46 PM   #8
DRFT180
DRFT180 is a glorious beacon of lightDRFT180 is a glorious beacon of lightDRFT180 is a glorious beacon of lightDRFT180 is a glorious beacon of lightDRFT180 is a glorious beacon of lightDRFT180 is a glorious beacon of lightDRFT180 is a glorious beacon of lightDRFT180 is a glorious beacon of lightDRFT180 is a glorious beacon of lightDRFT180 is a glorious beacon of lightDRFT180 is a glorious beacon of light
KA Bottom Mount T2
Thanks
S14 Build
DRFT180 is offline   Reply With Quote
Old 03-22-2013, 03:55 PM   #9
newboost
newboost is an unknown quantity at this point
looking for a topmount manifold and downpipe for a sr20det going into a s14 shiped to 06902 please pm with a price
newboost is offline   Reply With Quote
Old 03-23-2013, 10:11 AM   #10
468POWER
Newboost - you have PM for a pretty sweet set up. DocRace Manifold and downpipe = SEXY
Old 04-14-2013, 11:59 PM   #11
HPR
HPR is an unknown quantity at this point
Shipping to Canada available? If so, price quote for T3 top mount and downpipe to T1Y7A2 please
edit: for S14 SR20DET going into S14
HPR is offline   Reply With Quote
Old 04-16-2013, 12:18 PM   #12
devinlang89
devinlang89's Avatar
devinlang89 is an unknown quantity at this point
rb25 twin scroll and undivided manifold would like to know the price on both.
devinlang89 is offline   Reply With Quote
Old 05-23-2013, 06:28 PM   #13
PWND3r
PWND3r is an unknown quantity at this point
Please PM me a price for the SR20 T4 top mount. Thanks!
PWND3r is offline   Reply With Quote
Old 06-28-2013, 08:50 PM   #14
key0saMa
key0saMa is an unknown quantity at this point
price on ka24de t3 top mount shipped 60608
key0saMa is offline   Reply With Quote
Old 03-09-2014, 09:01 PM   #15
Artsaves666
Artsaves666 is an unknown quantity at this point
Price for topmount t3 for a ka24de. 38mm wg shipped to 36206
Artsaves666 is offline   Reply With Quote
Old 03-10-2014, 08:43 AM   #16
richmond82
richmond82's Avatar
Trader Rating: (29)
richmond82 is an unknown quantity at this point
Feedback Score: 29 reviews
Price for Topmount t3/t4 ( or just T3 is fine) 38mm Wastegate shipped to 97501
Drake: 95 Swapped S15SR Z32 Swapped TT 1991Vert
richmond82 is offline   Reply With Quote
Old 03-12-2014, 08:37 AM   #17
468POWER
Working on pricing for you gents - stay tuned.
Old 03-12-2014, 08:45 AM   #18
K_style
K_style's Avatar
Trader Rating: (63)
Feedback Score: 63 reviews
Can I have price for
1.SR20 Bottom mount
2.SR20 T3 Top mount
3.SR20 T3 Twin Scroll top mount
4.SR20 Bottom mount with MVS v-band.
Old 03-12-2014, 09:15 AM   #19
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
Saw you guys were making JZ manifolds too... super sexy work
BiG MiKE86 is offline   Reply With Quote
Old 04-16-2014, 01:42 PM   #20
Rezlo
Rezlo is an unknown quantity at this point
Send a message via AIM to Rezlo
A few more pics of GREAT quality Doc Race products, the type that gets delivered to your door after paying $1200.
Rezlo is offline   Reply With Quote
Old 04-16-2014, 03:31 PM   #21
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
man theres alot of slag in there.... i always heard pretty good things from these guys.
1989 240sx SE Coupe, 19k Original miles, 2JZ-GTE, PT6266,Fuel System, AEM V2, Sound Performance Tuned
www.Wi240sx.com | http://flicktitty.tumblr.com
WTB: CLEAN STOCKish AUTOMATIC 240SX PM ME
Flicktitty is offline   Reply With Quote
Old 04-16-2014, 10:11 PM   #22
TheRealSy90
TheRealSy90's Avatar
TheRealSy90 is a name known to allTheRealSy90 is a name known to allTheRealSy90 is a name known to allTheRealSy90 is a name known to allTheRealSy90 is a name known to allTheRealSy90 is a name known to allTheRealSy90 is a name known to allTheRealSy90 is a name known to allTheRealSy90 is a name known to allTheRealSy90 is a name known to allTheRealSy90 is a name known to all
Wow that was a let down. Was just considering a new manifold as well.
Originally Posted by dizzariot View Post
So god damn Japanese, your sweat probably smells like udon.
Old 04-16-2014, 10:39 PM   #23
Rezlo
Well I can only but presume this is their regular level of quality because when the issue was raised and they replied weeks later I was told if I want anything done about it I must return it at my cost so they can "clean it up". I haven't even seen $100 ebay manifolds with this level of workmanship...
Old 04-16-2014, 10:51 PM   #24
801nismo104
801nismo104 is an unknown quantity at this point
wow that is shitty man. definitely changed my view point on doc racing. i thought they were legit. i was also considering a manifold from them but never mind. ill spend my money elsewhere.
801nismo104 is offline   Reply With Quote
