Old 03-10-2013, 06:45 AM   #1
mattysr20
mattysr20 is an unknown quantity at this point
CAS issue
ok well I've searched and can't find the answer I'm looking for. my car has been broke down for months I've made other threads for other issues wich I fixed but still don't have car running. Last night I tested the power sources again I turned key on and had no power to my CAS. Why would I have 0 power? I have changed relays fuses and ecu so I dunno what else would cause this. Maybe I'm not testing it right I just used a test light I have a multimeter but have no clue how to use it lol. any help would be great thanx!
Posted from Zilvia.net App for Android
mattysr20 is offline   Reply With Quote
Old 03-10-2013, 11:57 AM   #2
mattysr20
I guess I should add I'm not getting spark or fuel
redtop Sr - stock
91 s13
Old 03-11-2013, 11:33 AM   #3
KoukiMonsta
KoukiMonsta's Avatar
Trader Rating: (22)
KoukiMonsta is an unknown quantity at this point
Feedback Score: 22 reviews
does the ecu light up? is it known to be a good ecu?
power to CAS is the black/white stripe wire. should get 12 volts to that one
S13 Build
Old 03-11-2013, 11:59 AM   #4
mattysr20
got the ecu used not 100% sure its good just figured the odds of getting another ecu with same problem was slim I checked that wire and all others and got nothing with key turned on
Old 03-11-2013, 12:00 PM   #5
mattysr20
and no it doesn't light up neither one does
Old 03-11-2013, 08:19 PM   #6
Con-city_s13
Con-city_s13's Avatar
Con-city_s13 is an unknown quantity at this point
Is your ECU properly grounded?
Con-city_s13 is offline   Reply With Quote
Old 03-11-2013, 10:15 PM   #7
mattysr20
I would say yes but how would I know exactly? how does it ground? where is the ground
Old 03-12-2013, 09:05 PM   #8
KoukiMonsta
Trader Rating: (22)
It grounds via bunch of pins.. But I believe it goes to the intake mani. Or near battery. I haven't messed with oem harness in a while.
S13 Build
Old 03-12-2013, 09:12 PM   #9
OrangeVirus1
OrangeVirus1 is an unknown quantity at this point
Check your Relays, Check grounds, Check power to the ecu.
OrangeVirus1 is offline   Reply With Quote
Old 03-12-2013, 09:42 PM   #10
mattysr20
I dunno how to check power to ecu relays are good
Old 03-15-2013, 10:44 PM   #11
mattysr20
ok I cleaned up all the grounds I could find I also took the top off of the ecu and poked around with a tests light I got power to a few of the pins but I'm not sure what they were also when I touched one of them it made a noise and the red light flashed for like a second but after that when I touched it it didn't do anything still no spark or power to cas so I dunno should I just change all my relays I changed 2 of them the egi and egi pump all fuses are good under hood.
