Old 02-26-2013, 09:16 AM   #1
240 GTR
240 GTR is an unknown quantity at this point
SR20 Swap, HKS 3037s Turbo, Full-Race, Tial, Exedy, ID 1000's, SARD Rail
Selling the redtop sr20 setup from my pro-am car. I bought it from JDM-online.com back in 06 or 07. It was used for multiple events up until the end of 2010. It's been a really solid motor...never had any issues with it. I used to run it with an s15 t28 on 16 psi, power fc, sti injectors, and z32 maf. Oil was changed religiously after every event with 10w-40 Rotella T, filters changed every other event. I've had really good luck with this motor, but it's time to move on. Hopefully somebody else can put it to good use.
What you're getting:
-Redtop s13 SR20 Longblock
-s13 SR trans with B&M shifter (no grinds or blown gears. shifts really well, had MT-90 in it.)
-Exedy Stage 2 Clutch (about 14 events on it. still grabs hard)
-Exedy lightweight flywheel
-Engine harness, trans harness, and ignitor (setup to go into SOHC ka s13. has also been modified for a power fc d-jetro, but all maf wiring is still in tact. ignitor gets relocated inside of the car).
-New starter
-Koyo Radiator with Altima dual electric fans and auto fan controller
-Nismo 65C thermostat
-6AN PS Lines, cooler, reservoir
What it needs:
-Turbo, manifold, lines (I have a good t25, gt28rs, hy35, stock manifolds, and lines available for extra.)
-ECU
-MAF
-Injectors
-Alternator needs rebuild soon
-IC and intake setup
-Front and rear main seals leak a little
Price: $2000
Available Separately:
Turbo setup shown above: $1700
-Made 370 whp @15 psi on my stock internal SR
-HKS 3037s (no blown seals, normal shaft play for BB turbo, no bent fins, aluminum elbow welded onto comp. outlet)
-Full Race bottom mount manifold
-Tial 40mm v-band wastegate with dump tube
-4 bolt turbo elbow/downpipe
-SS braided oil and water lines
Injector Dynamics 1000cc w/ Sard Rail: $500
-Installed, but never ran. These are basically brand new.
-Intake manifold not included
-Fuel rail has 8AN inlet and outlet fittings
Mid-mount Intercooler setup: $500
-Spearco core
-Custom aluminum piping (made specifically for the turbo setup above, but should work with others with small modification to hot pipe)
-Tial 50mm BOV on cold side
Take the engine, HKS turbo setup, injectors, and IC setup for $4300
240 GTR is offline   Reply With Quote
Old 02-26-2013, 06:13 PM   #2
sil15yaz
sil15yaz is an unknown quantity at this point
send email to me. [email protected]. interested in your id injectors and sard fuel rail
sil15yaz is offline   Reply With Quote
Old 03-11-2013, 10:37 AM   #3
240 GTR
bump it uppp
Old 03-13-2013, 01:12 PM   #4
Turbo Nismo
Turbo Nismo's Avatar
Trader Rating: (18)
Turbo Nismo is an unknown quantity at this point
Feedback Score: 18 reviews
Are you willing to sold separately the Tial 40mm v-band wastegate? If yes, pm how much you want for it shipped to Puerto Rico, 00745?
Turbo Nismo is offline   Reply With Quote
Old 03-13-2013, 01:33 PM   #5
RocketBUNNY
RocketBUNNY's Avatar
RocketBUNNY is an unknown quantity at this point
Part out just full race bottom mount mani? How much if so?
RocketBUNNY is offline   Reply With Quote
Old 03-13-2013, 01:36 PM   #6
Rb26kouki
Rb26kouki's Avatar
Trader Rating: (60)
Rb26kouki is an unknown quantity at this point
Feedback Score: 60 reviews
Does the manifold have a hole in it?
Also how many miles on the 3037S
Rb26kouki is offline   Reply With Quote
Old 03-13-2013, 01:46 PM   #7
nOaAAa
nOaAAa's Avatar
nOaAAa can only hope to improve
Send a message via AIM to nOaAAa
pm'd you... send me your contact info
nOaAAa is offline   Reply With Quote
Old 03-13-2013, 07:31 PM   #8
Wegs
Wegs is an unknown quantity at this point
http://zilvia.net/f/sale-items/506030-vh45-swap.html
trade?
Wegs is offline   Reply With Quote
Old 03-14-2013, 11:04 AM   #9
240 GTR
In the above picture, the tube off the manifold for the wastegate had broken off. It has since been rewelded in it's original position. I drove the car afterwards with no issues.
The 3037s came on a car that I bought that was built in '06. It was driven on track 2 times, then parked until I bought it in '10. I used the turbo for about 10 events since I've owned it.
Everyone else has been pm'd!
