Old 02-02-2013, 02:22 AM   #1
Cruz_240sx
Cruz_240sx's Avatar
Cruz_240sx is an unknown quantity at this point
s14 transmisson to s13 Ka24e
seems everyones doing the opposite of what im doing after searching
so ive got a single cam KA and i swapped to a S14 tranny. but my s13 driveshaft is to short. i think i need an s14 DS but not sure can anyone shed light on the subject?
not sure if the car was abs or not. so which DS do i need or do i have to just swap the front section out of my s13 DS to get the extra Length?
Cruz_240sx is offline   Reply With Quote
Old 02-02-2013, 02:41 AM   #2
DennisC
DennisC's Avatar
DennisC is an unknown quantity at this point
You should be using a s13 manual driveshaft. A s14 driveshaft will not work in a s13.
DennisC is offline   Reply With Quote
Old 02-02-2013, 02:51 AM   #3
Cruz_240sx
Cruz_240sx's Avatar
The stock 5 speed driveshaft is to short. I'm not doing an auto to manual swap I just replacing the 5speed with an s14 cause I had a spare my stock tranny blew
Old 02-02-2013, 03:37 AM   #4
Torq_Meister
Torq_Meister's Avatar
Torq_Meister is an unknown quantity at this point
When I did my swap I had to mate together a s14 and s13 driveshaft. I did a s13 trans to s14 so I had to use upper half s13 and lower half s14. So I'm assuming it would be the other way around use upper half s14 and lower half s13. The upper half of the driveshaft is the side that goes into the transmission.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Torq_Meister is offline   Reply With Quote
Old 02-02-2013, 09:23 AM   #5
Cruz_240sx
Cruz_240sx's Avatar
Thanks ill have to see if I can track down a front part of an s14 ds
Old 02-05-2013, 12:40 PM   #6
Spaz882
Spaz882's Avatar
Spaz882 is an unknown quantity at this point
What is the point of swapping to the S14 tranny?
Spaz882 is offline   Reply With Quote
Old 02-05-2013, 06:51 PM   #7
tobroketobuildarealcar
tobroketobuildarealcar is an unknown quantity at this point
I have went from s13 twin cam to s14 trans both 5 speed and used the s13 drive shaft on both with no problems it must be that you are going from a sohc to s14
tobroketobuildarealcar is offline   Reply With Quote
