Old 01-29-2013, 10:20 PM   #1
brentjj
brentjj is an unknown quantity at this point
Question Lengthening Half Shafts
Hey all.
I'm in a predicament where I need to lengthen both my rear shafts coming out of my diff to the rear wheels. I'm running about a 6 inch wide body done by moving control arms but now have the problem of shafts too short. The original plan was to make some dolt in spacers that bolted on but I feel they won't hold to the 550+ foot pounds of torque my engine is putting out.
Is there any way I could lengthen the shafts? I was thinking about cutting splicing and sleeving but I still don't think that will hold. Does any one know of a place that could make a new shaft at a longer length?
Thanks for reading,
Brent.
brentjj is offline   Reply With Quote
Old 01-30-2013, 01:28 AM   #2
redsx13
redsx13's Avatar
redsx13 is an unknown quantity at this point
Three words Driveshaftshop.com, that's the number one place for aftermarket half shafts and drive shafts for 240s, I'd love to see that project of yours.
Driveshaft shop is gonna be expensive tho. I honestly feel that you can sleeve the stock ones. If you notice at one end the cv joint comes apart and you can remove the bearings (I'm almost positive it's the outside joint) . There is an Alan screw that holds it together on the inside.
I'd cut the shaft, get a piece of round stock about the thickness of the shaft, cut to desired length, and weld in. Set it on a flat table tho to get it straight. Then sleeve it. If your welds are good it will hold. Much easier than a spacer, cheaper than a custom one/ones
Good luck,
Brandon
redsx13 is offline   Reply With Quote
Old 01-30-2013, 09:54 AM   #3
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
lengthening drive shafts might work if you don`t have sticky rear tires and does not encounter hard launches or shock.
rcdad123 is offline   Reply With Quote
Old 01-30-2013, 09:58 AM   #4
Mikester
Mikester's Avatar
Originally Posted by redsx13 View Post
Driveshaftshop.com
^^This^^
They are a bit expensive, but their workmanship is worth every penny.
Old 01-30-2013, 10:03 AM   #5
Supergoji
Supergoji's Avatar
Supergoji is an unknown quantity at this point
Send a message via AIM to Supergoji
wider wheels??????
save you all the headache
www.NYZC.net
Supergoji is offline   Reply With Quote
Old 01-30-2013, 10:25 AM   #6
Mikester
Mikester's Avatar
Originally Posted by Supergoji View Post
wider wheels??????
Doesn't matter- he moved his arms out, which means the hubs, spindles etc went with them... From the sound of it, the shafts are physically too short to safely reach the hubs. Only options are to find compatible shafts or have some custom-made. Splicing in a length of shaft would be okay for stock torque- but definitely not for a 550ft/lb load.
Old 02-02-2013, 08:51 AM   #7
brentjj
Thanks for the input guys. I'll give the driveshaft shop a call on Monday. Right now I have a set of nitto drags for the rear so not sticky tires isn't an option at this point. Haha I'll probably give splicing and welding a try and see if they hold. If not it would be good to know that the shop could make a solid set for me.
Old 02-02-2013, 01:57 PM   #8
jr_ss
Trader Rating: (33)
jr_ss is a jewel in the roughjr_ss is a jewel in the roughjr_ss is a jewel in the roughjr_ss is a jewel in the roughjr_ss is a jewel in the roughjr_ss is a jewel in the roughjr_ss is a jewel in the roughjr_ss is a jewel in the rough
Feedback Score: 33 reviews
Splicing and welding is not going to hold and is a stupid idea. You're asking to fuck shit up doing that. Most shafts are hardened or tempered steel. Once you heat them up, you remove their hardness/temper and you'll twist/snap a shaft in no time.
My SR20VET
Old 02-02-2013, 06:32 PM   #9
dawagarage
dawagarage's Avatar
dawagarage is an unknown quantity at this point
hit up your local drive shaft shops, dude
formerly known as "hotboiblaze"
ratsun: dawa (73 datsun 620)
clublexus: properD (97 sc300)
back from sea
dawagarage is offline   Reply With Quote
Old 02-03-2013, 12:30 AM   #10
Bink Industries
Bink Industries's Avatar
Bink Industries is an unknown quantity at this point
i have seen cars making over 600HP with billet aluminum spacers and aircraft grade bolts with no problem. spacer goes bettween the diff and the axles.
Bink Industries is offline   Reply With Quote
Old 02-03-2013, 10:01 AM   #11
Mikester
Mikester's Avatar
Billet spacers & burly bolts is a helluva lot better than cutting/welding. Even so, driveshaft shop is the best option.
