Old 12-23-2012, 04:11 AM   #1
S14_BOSS
S14_BOSS's Avatar
SoCal: SAFC Tuner - Knowledgable/Reliable ?
Looking to tune my RB25.
Basic bolt ons, FMIC, Intake, Greddy IM, boost @ 10psi, stock injectors. Looking for a good reliable daily driven tune.
Anyone know of any good shops around the OC area that tune SAFC? I'd like someone that knows what they are doing so i can get it done right the 1st time. Also, about how much do they charge.
Thank you
S14_BOSS is offline   Reply With Quote
Old 12-25-2012, 02:51 AM   #2
S14_BOSS
S14_BOSS's Avatar
Nobody knows?!
Old 12-25-2012, 08:24 AM   #3
fliprayzin240sx
I </3 VA
fliprayzin240sx's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
Nobody wants to touch a SAFC since its garbage. You're gonna try to run it on a finicky RB25 ECU too? Ooooh boy, goodluck on that one. The stock ECU will pull timing out the moment it sensed your fucking with it with the SAFC, car will run like pooopies.
CLICK HERE!!!
Old 12-25-2012, 11:51 AM   #4
S14_BOSS
S14_BOSS's Avatar
I've seen plenty of other post's on skylineaus that state otherwise. The SAFC neo also has knock sensor inputs for this very reason. As for the car running poopies, i don't think it can run anymore poopies than it does with a stock ECU; I have seen nothing but good things with people running safc on rb25 ecu. Gas mileage improvements, power gains, overall performance. That is what im going for, i don't need NIStune or a PFC for a stock motor.
Please, if anyone knows of any tuners that tune a SAFC in the socal/OC area please let me know.
Old 12-25-2012, 02:35 PM   #5
snags
snags's Avatar
first of all, get a wideband. no way you can tune without it.
second, tune it yourself with your wideband. its easy
snags is offline   Reply With Quote
Old 12-25-2012, 04:38 PM   #6
S14_BOSS
S14_BOSS's Avatar
I have an AEM Uego wideband. I just don't want to blow my engine as I've never tried messing with AFRs.
Old 12-25-2012, 09:39 PM   #7
2.5T_/<ouki
2.5T_/<ouki's Avatar
I've heard good things from Church Automotive Tuning. The website even lists AFC-neo as something they tune: $200. Check them out
2.5T_/<ouki is offline   Reply With Quote
Old 12-27-2012, 07:53 PM   #8
Nissan_Alex
Nissan_Alex's Avatar
I've worked with them before ive done about 2 sr20de+t and 2 Rb(20/25) tunes with em. They are ok to get the car driveable.
My opinion is they are horrible in the long run.
Im located in the South bay if you interested text or ring me.
Ill be cheaper than any tune shop, but how much depends on how much time I have to spend.
(I ran my own shop in New Zealand, so I've been around the block for this sort of stuff)
562-896-6344
Nissan_Alex is offline   Reply With Quote
Old 12-27-2012, 10:55 PM   #9
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (45)
Feedback Score: 45 reviews
but your motor isn't stock... greddy intake manifold is a pretty big upgrade. good reliable dd tune, it sounds like what you want is MPG. SAFC should be able to do that as that's mostly just AFR tuning but I think you want a lot more than something DDable.
Old 12-27-2012, 11:11 PM   #10
S14_BOSS
S14_BOSS's Avatar
I guess you can say an IM is a big upgrade but I still considerate it a stock motor. Yes you are right I wasn't more MPG and the SAFC should be able to do that. What did to mean by you think I want more than something DDable? This is my DD.
Old 12-28-2012, 05:40 PM   #11
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (45)
Your English is nearly incomprehensible. I meant that if you just wanted to DD a car then you would not want to turn up the boost and all that extra stuff that you're doing. It's more than just a dd, its modded for more power.
Old 12-28-2012, 07:42 PM   #12
S14_BOSS
S14_BOSS's Avatar
Hahah! Sorry about that, damn iPhone texting with my big hands isn't the best.
Well, it is my DD and that's really all i want it for. I enjoy the 3 extra psi from 7 to 10spi as it feels more responsive.
Old 12-30-2012, 01:18 PM   #13
buku_points
buku_points's Avatar
Any luck on this? I'm kinda in the same boat. I recently acquired a 93 coupe with a red top sr20det. S15 turbo. Freddy intake, Fmic and I believe it has 750cc injectors. Came with a safcII installed but pops and runs like shit. Was told the block was replaced and the tune the car had saved on file would not work. Any help in the IE?
buku_points is offline   Reply With Quote
Old 12-30-2012, 03:39 PM   #14
bardabe
bardabe's Avatar
Send a message via AIM to bardabe Send a message via MSN to bardabe
^^^ in the IE? shoot me a PM.
bardabe is offline   Reply With Quote
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright © 1998 - 2014, Zilvia.net™
