06-05-2012, 10:46 AM | #1 |
Trader Rating: (313)
Feedback Score: 313 reviews
Many parts for sale
PM me for the fastest response.
I have more stuff I'll add later when I take pics. Z32 TT speed sensor-$60 OEM driver side S13 chuki side skirt-$50 picked up Was pretty beat but I fixed the damage. Still needs some work(mostly sanding), Rear side markers-$10 Both are in good condition. Sockets and harnesses are included. Fronts are sold S13 chuki bumper center bracket-$20 S13 chuki bumper vents-$15 White Bunny clutch setup-$80 Setup is used but in good condition. Lots of life left on the disk. It's an OEM Nissan Z32 clutch with a D21 flywheel. Includes the throwout bearing and clutch bolts. Will fit both SOHC and DOHC KA motors. Part of the trans backing plate needs to be trimmed so the flywheel doesn't rub(see the last 2 pics). Before After Z32 1 piece drive shaft-$140 This is for a 5spd non-turbo 2 seater model. Made by Drivelines Inc. It's 40in from u-joint to u-joint and 48in overall. Z32 ignitor-$25 Lower subframe collars-$20 These go on the bottom of the subframe mounts. 440cc top feed injectors-$50 These are low impedance from a mk3 Supra turbo. Should work with CA18 and KA-E motors. Z31 turbo hood scoop-$20 Z32 dash mat-$20 FC RX7 oil cooler-$50 Couple dents but no leaks. Has a built in thermostat. K&N drop in filter-$20 Cleaned and re oiled with the K&N cleaning kit. Key ring light-$12 Has a green bulb. Last edited by MrMcgarrett; 06-12-2012 at 08:40 PM.. |
