05-15-2012, 12:07 PM | #1 | |
Trader Rating: (145)
Feedback Score: 145 reviews
HIGH-End SH!T *** SR20 Parts *** Blitz - ARC - Power FC - KOYO - Built Head - JWT S3
Check out my Feedback or Trader Rating
Located in Garden Grove, CA. 92843. Email - [email protected] Call/Text - 7I4-four89-three789 My other threads: Price does NOT include shipping and shipping is not free. Please add 3% for PayPal or send as gift. NO trades b/c CASH is KING. * For instant respond, reply to this thread since it will forward to my cell. UPDATED on 11/08/12. All parts and photos are listed on page one. Here are the last of my 240 parts I have left. The majority of the performance parts were purchased new from either phase2motortrend.com or frsport.com. Some parts looks dirty but still in great shape with minimal miles on them. I will clean them prior to shipping. This is a rough draft of my for sale thread. I will update this ad frequently and will be adding more parts. Now onto the parts... S14 SR20DET Haltech E8 EMS. Its a direct plug and play kit. Buyer will receive everything shown below: E8 Haltech, PNP harness kit, and map sensor and harness. It was removed from a working car. The previous owner switched to AME since that was the only tuners in his area (Bahamas lol). Asking $900 (price dropped again) This same kit sells for 1365 at phase2motortrend.com. Quote:
S13 2-Way Tomei LSD - $700 Price lowered again and also FIRM - Professionally installed - Correctly broken in - No diff cover - Less than 5,000 miles Full Race Pro Stock Manifold - $700 Price lowered and also FIRM ($1000 @ fullrace.com but now discontinued so RARE piece) - The best bottom mount turbo for SR - Used but in great shape w/ about 5,000 miles - Its thermal coated at Olympics coating in San Diego (cost $140)
i have engine hoist for rent i do SR wiring Last edited by vutony; 11-08-2012 at 02:30 AM.. |
05-15-2012, 12:11 PM | #2 |
I have one left that grinds to second gear. Also a spare SR bellhousing (swap it out with ka trans) Make offer Second, the far left trans sold as parts, lmk what you need from it....shifter plate, bell housing, sensors, etc. Sorry I sold all the speed sensors. SR dust cover - $30 - Its cut at the top (12 o'clock) b/c I didnt want to remove the flywheel which does not affect anything. 350Z G35 Brembo Slotted Rotors Front Set $250 (Purchased new at FR @ $389.95 plus tax) - In great shape with less than 2,000 miles. - Has a minor defect from the calipers rubbing on the rotors. - Its about 30.16mm thick, min thickness is 28.4. - Rotors are 12.75 in diameter Z32 Front conversion brackets to use 350Z rotors I can get these for you if needed $100 extra. The brackets below are sold. OEM Rear Brake Dust Shield Z32 w/ hardware - $130 - I bought this used online but it is 100% functional. - It does have minor surface rust which can be sanded and repainted. - The dust shield cost $100 each and doesn't include the hardware. S13 Brembo rear drilled rotors - 100 ($250 @ frsport.com) - Used but in good shape with alot left to use - Drilled and cadmium coated
i have engine hoist for rent i do SR wiring Last edited by vutony; 10-18-2012 at 11:23 AM.. |
05-15-2012, 12:14 PM | #3 |
Nismo radiator cap - $25 ($55 @ frsport.com)
Mishimoto radiator cap - $10 ($19 @ frsport.com) OEM S13 SR20DET Fuel Rail w/ injector caps - $40 FPR fitting - $30 - Used but in great shape w/ about 3,000 miles - Comes with fitting for universal FPR
i have engine hoist for rent i do SR wiring Last edited by vutony; 10-22-2012 at 11:24 AM.. |
05-15-2012, 12:15 PM | #4 | |
Apexi Power FC Commander - $170
- In great shape and 100% functional - Part # FCC2FN000-00180 - Compatible with GC8 98-00 part# 414 F013 and Nissan part# 414N10-18 Nismo Stainless Steel License Plate Frame - $20 RB20/25/26 Motor and Transmission Bracket "Stencils" - $25 - You are buying the trace out to make these mounts - NOT actual mounts shown below - Its a lot cheaper route *You can still use oem mounts with these brackets for RB20/25/26 swap into S13's Blitz Z32 Intake - $90 ($200 new) - Its in great shape and 100%functional - It has one small tear as shown Quote:
Intake hose from SR Greddy - $10 Early '90 civic universal generic hub - $10
i have engine hoist for rent i do SR wiring Last edited by vutony; 10-18-2012 at 11:25 AM.. |
05-15-2012, 12:20 PM | #5 |
OEM SR headstuds - $50
- In excellent shape - Has about 5,000 miles on them JWT S3 camshafts -$SOLD Cam gears - $30 Cam gear hardware - $30 Candy Red Valve Cover (TRG coating zilvia's sponsor) - $80 Nismo oil cap - $40 S13/S14/S15 SR20DET Valve Cover & Spark Plug Well Gaskets - $40 SR20DET Exhaust Manifold Inlet Gasket - $10 each shipped OEM SR20DET 5 Hole Turbo Outlet Gasket - $10 each shipped - Gaskets are used but still in good shape - I have reused them before and had no problems with leaks SR exhaust manifold studs and nuts - $15 Nissan SR T25 Turbo Locking Plate - $10 both shipped SR20 Turbo Oil Return Tube - $20 SR20 5 speed flywheel bolts (8) - $30 - bolts are in good shape, not stripped S13 SR20DET CAS - $110 - Used but 100% functional S13 SR20DET dipstick w/ tube - $30 SR20DET coolant sensors - $20 Pipe and hose - $sold SR20DET Timing Chain Tensioner - $40 Crank pulley bolt and washer - $40
i have engine hoist for rent i do SR wiring Last edited by vutony; 11-28-2012 at 12:47 PM.. |
05-15-2012, 12:22 PM | #6 |
SOLD
S13 SR20DET knock sensor w harness S13 SR20DET coil pack harness S13/S14 SR20DET 7 Layers Metal Exhaust Manifold Gasket S13 SR20DET motor mount brackets S13 SR20DET Megan Racing Pulley Set S13 SR20DET starter Garrett GT2871R Ball Bearing Turbo w/ HKS actuator S13 SR20DET TAKA Turbo Lines S13 SR20DET alternator S13 SR20DET AAC Valve S13 SR20DET PS pump S13 SR20DET PS bracket and hardware S13 SR20DET Greddy Intake Manifold OEM S13/S14/S15 SR20DET O2 Sensor Intial D toy cars DIF Dual Electric Fan Controller 3" custom aluminum cold pipe FRS Polished Aluminum Hotpipe S13 SR20DET S13 SR20DET coil pack harness S13 SR20DET coil packs S13 stock motor mounts Tomei/N15 TB 70mm throttle body Nismo/Tomei 740cc Fuel Injectors Nismo Fuel Pressure Regulator Type-B S13 SR20DET water inlet Toda Flywheel RPS Max Street Clutch S13 SR20DET water outlet S13 H4 Hella Headlight Housings Power Enterprise 4PK865 V-Belt S13 SR20DET Tomei 3" elbow S13/14/15 ARC Oversize Oil Pan S13 SR Koyo radiator S13 SR20DET Pro Fab Design Intake Manifold Gasket S14 SR20DET TPS Redtop head DPI Rocker Arm Stopper Valve cover hardware (rubber grommets, washers, SS nuts Walboro fuel pump Nismo SR13 thermostat S14 SR20DET engine harness
07-23-2012, 12:17 AM | #26 |
Bandwagon.
lmk if you have a stock sr maf laying around.
