Old 02-23-2012, 02:48 PM   #1
jefferz
jefferz's Avatar
jefferz is an unknown quantity at this point
4.90 Differential gears. $120
I have 4.90 diff gears for s13-s14. Will def help with those under powered. Would not suggest it for a car with an sr or ka-t or anythign of that nature.
looking for $120
the gears are still in the differential you need to remove the ring gear and pinion from the diff and have the pinion installed in your differentail and bolt on the ring gear
More local pick up then anything shipping is like 70+ because of the weight of the item.
S13 Coupe, S14 Kouki
Crew Chief jeff Jones Racing
jefferz is offline   Reply With Quote
Old 02-23-2012, 09:36 PM   #2
jefferz
jefferz's Avatar
nobody wants 4.90 gears?
