Old 11-20-2011, 11:26 PM   #1
Imarvin240
Trader Rating: (18)
Imarvin240 is an unknown quantity at this point
Feedback Score: 18 reviews
Imarvin240's SR22VE-T 350z time attack car build
Okay so I want to explain beforehand, why I’m doing the build this way. The build was originally going to be done on my rhd S14.5 but do to a shop screwing me over (selling the parts off the car and sending the rest of the shell to a recycling yard even though they were supposed to be just doing the cage hah) I no longer had that car to build. The reason I had no idea that this was happening, was because back on December 7th 2010, my house burned down which had me a bit distracted from my car. Don't worry, everyone survived! it was just the house that needed to be dealt with. Also, the fire destroyed about 15k in parts that I was going to be placing on the S14.
At that point, I was basically building a car from scratch (except I already had money sent out for the new engine). I went through a long search, looking for a car, but I wanted to build on a chassis that I haven’t built yet. So, I looked for r32, S15, m3 e30, but I ended up finding a well-priced and 100% problem free 350z that I was able to pick up.
As for this car build, it is doing to be my modified class time attack car…and maybe see the street on an absolutely perfect day. NO CHEAP PARTS and NO CUT CORNERS will be done on this build. DON'T bother saying any negative comments about the engine/chassis combination. An SR is lighter than a VQ and is able to sit further back/lower in the engine bay giving it a better center of gravity along with a better 50/50 weight distribution. also, this car will not have any power issues (i will show you with some of the future updates) should have plenty of power for the car. I plan to have the car finished within a few years from the start of this thread…since there's a lot of work that needs to be done. one of the big things im trying to do with this build, is to be a bit different then everyone else. im trying to pick parts and do things to the car that most people dont do...that will possibly explain why I'm doing what im doing LETS GET STARTED!
This is how the car looked the day I got it!
It was also a turbo 350z at the time when i bought it but i sold all of that right when i bought it.
well, shes jacked up and ready to start getting ripped apart.
time for the engine setup to come out and go bye bye! (VINs got cut off since we are ripping the tubbing out of the engine bay, will weld VINs back onto the firewall before paint)
The Mazworx SR22VE-T is in!
Engine Specs:
Head!
Mazworx Fully Built p11 sr20ve head
CNC ported combustion chambers
Competion race 5 angle valve job
Supertech everything:
Supertech 116lb dual valve springs
Supertech Titanium retainers
Supertech valve guides
Supertech Inner valve spring seats
Supertech +1mm oversized valves.
Gasket matched and opened up exhaust ports to match intake ports
P12 cams
Greddy Adjustable Cam Gears
P12 valve cover
P12 cam angle sencor
New OEM guides
Mazworx 1/2" headstuds
Block!
CP Piston 90mm 9.0:1
CROWER I-Beam Rods
Power Enterprise 90mm head gasket with fire ring
Calico Coated ACL Bearings for Main, Rods, and Thrust Washers
ARP Main Studs
New OEM Nissan Oil Pump
Darton Ductile Iron Sleeves
New OEM Nissan SR20 Crankshaft
Nismo Pilot Roller Bearing
Oil Groove Machining
19mm Rod Bearing Machining
Check, Polish, Balance Crank
All new OEM Nissan freeze/block plugs.
ATI Damper Pulley
Greddy Oil Pan (depending on the budget, I may end up going to a dry sump system this year instead of next year)
Extended oil pickup
Mazworx intake manifold
I'll add more updates in a bit
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 11-20-2011, 11:37 PM   #2
anthonyr sil8ty
anthonyr sil8ty is an unknown quantity at this point
def something new, best of luck with your build. sorry to hear about your unfortunate setback.
anthonyr sil8ty is offline   Reply With Quote
Old 11-20-2011, 11:54 PM   #3
Imarvin240
Trader Rating: (18)
A bit more of an update, but its mostly just pics of the parts that have come in for the build.
New Coil Pack cover from Nissan for the P12 Valve Cover
Q45 90mm throttle body...most likely replacing with a billet one...it will look cleaner
tilton hydrolic release bearing
AEM coils
Full Spec Moto splined quick release
SR to VG Transmission Conversion Plate
MY FAVORITE PART OF THIS UPDATE JUST BECAUSE OF THE BACK STORY
Tomei 2-way differential with a 1.5-way conversion kit
the back story to this is that the U.S. branch of Tomei had no idea that they even sold a 1.5-way conversion kit of it so they had to call the Japan branch to ask if they even sold a kit to make it a 1.5-way...turns out they do
Old 11-21-2011, 12:12 AM   #4
Buriantsu
Buriantsu's Avatar
Buriantsu has a reputation beyond reputeBuriantsu has a reputation beyond reputeBuriantsu has a reputation beyond reputeBuriantsu has a reputation beyond reputeBuriantsu has a reputation beyond reputeBuriantsu has a reputation beyond reputeBuriantsu has a reputation beyond reputeBuriantsu has a reputation beyond reputeBuriantsu has a reputation beyond reputeBuriantsu has a reputation beyond reputeBuriantsu has a reputation beyond repute
Send a message via AIM to Buriantsu
Sickness! Stay positive and do work!
Hialeah EditionHialeah Edtion
Buriantsu is offline   Reply With Quote
Old 11-21-2011, 12:16 AM   #5
Imarvin240
Trader Rating: (18)
SUSPENSION UPDATE TIME!
I bought almost everything from SPL
front upper arms V3
front lower arm bushings
front compression rod bushings
front outer tie rod ends
front stabilizer end links
rear toe arms
rear camber links
rear traction links
rear knuckle bushing kit
rear stabilizer end links
solid differential bushing set
tein inner tie rods
Stance XR coilovers with Swift springs
car came with hochkis stabilizer bars already.
Old 11-21-2011, 12:50 AM   #6
Imarvin240
Trader Rating: (18)
KEEPING IT COOL UPDATE!
so, like i said in the first post, im going for being a bit different witht his build...trying to do things a lot of people don't do. so i decided to go with a liquid to air intercooler setup to be a bit different but to also try it out since i have never personaly tried this type of cooling before. This setup is rated for 1200hp, so im sure it will work fine.
heat exchanger (radiator for the intercooler) 26 X 7 X 3.5
Liquid to Air Intercooler 15 X 6.5 X 6
Ice Box (for track days)
Bosch Cobra Pump
dual fans for the heat exchanger
Electronic water pump setup (this is replacing the pulley driven pump on the engine...a plate will be placed instead of the original pump)
Full Spec Moto is currently Custom building a Radiator for the build (pics/specs up when its finished)
Old 11-21-2011, 01:01 AM   #7
azndan2
azndan2 has a spectacular aura aboutazndan2 has a spectacular aura aboutazndan2 has a spectacular aura aboutazndan2 has a spectacular aura aboutazndan2 has a spectacular aura aboutazndan2 has a spectacular aura about
You are insane! I like it.
azndan2 is offline   Reply With Quote
Old 11-21-2011, 01:03 AM   #8
Imarvin240
Trader Rating: (18)
Full-Race SR20VE-T Turbo Manifold FINALLY came in
What it looks like on the engine
Unfortunatly, the BW EFR 8374 is on extreme back order till who knows when...i ordered it back in April. if its not here by the end of January, I'll probably just switch to the Garret GTX series turbo...
Old 11-21-2011, 01:19 AM   #9
Shift n Drift
Shift n Drift is an unknown quantity at this point
cot damn, keep it up
Shift n Drift is offline   Reply With Quote
Old 11-21-2011, 01:23 AM   #10
ShakotanGazelle
ShakotanGazelle is an unknown quantity at this point
WOW! my favorite engine going into my favorite Z
love it! keep it coming man. VE-T's gonna be a fucking blast!!!
ShakotanGazelle is offline   Reply With Quote
Old 11-21-2011, 01:31 AM   #11
Imarvin240
Trader Rating: (18)
stripping the Z down to nothing this week. Then next week, drilling out hundreds of spot welds to remove the engine tubbing, speaker/storage area behind the seats, and any brackets that aren't needed (glad Vince is willing to help me out with that hah)...then she leaves for Fab work (cage, stitch weld, bracing, motor/trans mounts, unboltable radiator support, bash bars, ect) (may be a break in updates till she gets back from that but hopefully not)
- all the electronics have been ordered through Touge Factory and will hopefully be here in the next couple weeks.
- driveline setup has all been ordered through Full Spec Moto.
Old 11-21-2011, 01:46 AM   #12
Pinggg
Pinggg's Avatar
Trader Rating: (22)
Pinggg is an unknown quantity at this point
Feedback Score: 22 reviews
more updates please!
Pinggg is offline   Reply With Quote
Old 11-21-2011, 01:49 AM   #13
Pray And Spray
Pray And Spray is an unknown quantity at this point
Woww man awesome choice! Definetely interesting!
Pray And Spray is offline   Reply With Quote
Old 11-21-2011, 02:11 AM   #14
bc.
bc.'s Avatar
bc. is an unknown quantity at this point
subscribed
* S14SR22 * 9.0 c/r * GT3071R *
bc. is offline   Reply With Quote
Old 11-21-2011, 02:54 AM   #15
Yellow4g63
Nice love the VVL.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Old 11-21-2011, 03:03 AM   #16
nujabe
nujabe's Avatar
nujabe can only hope to improve
yeah this shit is crazy. i really like how your just changing stuff up !!! keep it up !! marvin !!
nujabe is offline   Reply With Quote
Old 11-21-2011, 03:13 AM   #17
C-unit
C-unit's Avatar
C-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to all
sexy!!!! I love build like this!!!
C-unit is offline   Reply With Quote
Old 11-21-2011, 03:41 AM   #18
R4Race
R4Race's Avatar
R4Race is an unknown quantity at this point
Mate welcome to the club, all the best with it. How come you didn't opted for the kelford cams?
R4Race is offline   Reply With Quote
Old 11-21-2011, 08:55 AM   #19
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
Sorry to hear about all the bad luck, I actually remember the thread of your house burning down. I hope everything works out in the end for you.
Old 11-21-2011, 09:05 AM   #20
Imarvin240
Trader Rating: (18)
thanks for all the comments guys!
no real reason why i didn't, but i figure that i can always change to them in the future if its needed.
Old 11-21-2011, 09:22 AM   #21
GUNMETALV35
GUNMETALV35's Avatar
GUNMETALV35 is an unknown quantity at this point
The P12 Cams should do the trick. They say, they have a smooth mid-range with lots of top end power too.
That's the route I'm going, at least, for my VET build.
GUNMETALV35 is offline   Reply With Quote
Old 11-21-2011, 02:51 PM   #22
GideonD1025
GideonD1025 is an unknown quantity at this point
Love the idea good luck with the build. Subscribed for udates. Sorry to hear about your loss. That was a really messed up shop
GideonD1025 is offline   Reply With Quote
Old 11-21-2011, 06:50 PM   #23
sexcii-zenki
sexcii-zenki's Avatar
sexcii-zenki is an unknown quantity at this point
great build def will stand out from the rest1 good luck on build & sorry 2hear about ur unfortunate loss...
sexcii-zenki is offline   Reply With Quote
Old 11-21-2011, 07:05 PM   #24
Enrique909
Enrique909's Avatar
Enrique909 is an unknown quantity at this point
Subscribed!
Enrique909 is offline   Reply With Quote
Old 11-21-2011, 07:19 PM   #25
lovdrifting52
lovdrifting52's Avatar
Trader Rating: (34)
lovdrifting52 is making a name for him/her selflovdrifting52 is making a name for him/her self
Feedback Score: 34 reviews
this looks good so far cant wait to c this done
lovdrifting52 is offline   Reply With Quote
Old 11-21-2011, 07:31 PM   #26
bikrman2
bikrman2's Avatar
bikrman2 is an unknown quantity at this point
Send a message via AIM to bikrman2
Subscribed! I can see big things coming out of this build. Also by chance do you still have the VQ harness or any of that stuff?
Originally Posted by wangan_cruiser View Post
if you dont have any valuable information GTFO.
bikrman2 is offline   Reply With Quote
Old 11-21-2011, 07:42 PM   #27
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
yahhhhhhhh more VET's so subscribe..........
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 11-21-2011, 07:47 PM   #28
dub40sx
dub40sx is an unknown quantity at this point
This is such a STUPID....
.....LY awesome swap!!! Im excited for the finished product.
dub40sx is offline   Reply With Quote
Old 11-21-2011, 08:11 PM   #29
alexanderig
alexanderig is an unknown quantity at this point
just wondering why you would go from a turbo vq to an sr? why not put in another motor in which its alot easier to make power? goodluck with the build
alexanderig is offline   Reply With Quote
Old 11-21-2011, 08:18 PM   #30
[email protected]
Scott@FontanaNissan's Avatar
Scott@FontanaNissan is an unknown quantity at this point
Send a message via AIM to Scott@FontanaNissan
Whoa!!!! Keep up with the updates...you got my attention!
Juan Vargas - Motorsports Specialist Fontana Nissan/Nissanraceshop.com
email: [email protected]
Scott's Personal Website/Blog: http://www.scottandkerryann.com
Scott@FontanaNissan is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
