Old 10-30-2011, 03:20 AM   #1
besTint
Trader Rating: (81)
besTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the rough
Feedback Score: 81 reviews
Send a message via AIM to besTint
Arrow LOTS of SR/KA TOMEI SARD AEM TRUST OEM 240SX Parts
All aftermarket parts are in great to almost new condition, mostly under 500 miles. OEM parts are old as most SR's/240's. I don't sell junk, all parts are clean and in good working order but in used condition. Everything is sold AS-IS in good working condition. Feel free to ask any questions via PM or AIM. Buyer pays shipping and is optional on all parts.
THIS IS A "FOR SALE" THREAD NOT "FOR TRADES"
#1 complete thermostat assy. with new OEM Nissan thermostat less than 500 miles - $60 SOLD
#2 S13 SR20DET coolant upper water neck w/screws - $50
#3 S13 SR20DET turbo compressor outlet neck w/ screws - $30 SOLD
#4 OEM T25 oil drain return tube $15
#5 OEM S13 SR20DET dipstick tube and stick $40
#6 OEM Nissan slave cylinder bought new less than 500 miles w/SS braided line fits SR/KA/RB - $40 SOLD
#7 Greddy T25 turbo outlet elbow w/ divider plate - $140 SOLD
#8 OEM Nissan S14 power steering reservoir assy. - $60
#9 Stance ST9 oil block adaptor for SR20DET w/ new oil pressure sensor replaced less than 500 miles - $120
#10 AEM 3.5bar MAP sensor w/ pigtail and mounting clip - $100
#11 SARD fuel pressure regulator (FPR) with FRSport NOSHOK 0-160psi gauge kit and new fuel lines, clamps and mounting bracket - $200 SOLD
#12 OEM Z32 MAF connector harness pigtail - $10
#13 complete lower harness (alt, battery, starter, ground, fuse box) off S14 chassis - $50 SOLD
#14 AEM boost control solenoid - $50 SOLD
#15 OEM Nissan oil filler cap - $5
#16 OEM Nissan stock intake tube with intact spring coil - $10 SOLD
#17 OEM Nissan throttle body coupler hose - $5 SOLD
#18 stock sr20det valve springs 16pcs - $10
#19 stock sr20det cam gear set with nut and washer - $50 SOLD
#20 stock sr20det valve springs 16pcs - $10
#21 stock sr20det cam gears only - $20 SOLD
#22 ATI dual 52mm gauge pod for S14 240SX - $20 SOLD
#23 complete AEM 52mm serial data stream gauge for EMS - $140
#24 AEM 52mm wideband uego controller gauge - $150 SOLD
#25 Greddy/Trust 3" SR20DET steel downpipe w/ gaskets, nuts, bolts O2 sensor bung - $140 SOLD
HAD TO ADD SOME MORE SINCE THREAD IS DOING SO WELL. NEW ITEMS ADDED 11/02/11 2PM
#26 S13 SR blacktop IACV used, stripped plastic screw. was replaced with new one because of idle issues but can be cleaned and used - $40
#27 ACT 600225 XACT StreetLite Lightweight Flywheel 14.1lb 89-98 SR20DET barely used for less than 500 miles - $180 SOLD SOLD SOLD
#28 OEM Nissan SR20DET exhaust gasket unused from a OEM gasket kit / single layer - $10 SOLD
#29 Nismo slave cylinder for S13/S14 used in perfect condition - $100 SOLD
#30 OEM Nissan oil squirters (under pistons) 4pcs with screws - $80
#31 OEM Nissan coil packs in good working order 3pc (sold 1) - $50
#32 Stock S13 SR20DET throttle body with S14 throttle pulley, will include stock throttle pulley and working tps sensor - $80
#33 OEM Nissan knock sensor off a S13 SR20DET (harness sold) - $30 SOLD
#34 Custom made throttle cable bracket for S13 SR Greddy/ISIS intake manifold w/ N15 throttle body - $40
#35 Stock OEM Nissan lifters 12pcs - $20 SOLD
#36 S13 SR timing chain guide with screws - $10
#37 OEM S14 drivers side switch housing for SE models - $5 SOLD
#38 OEM S14 passenger side switch housing - $5 SOLD
#39 OEM S14 passenger side switch housing - $5 SOLD
(all switch housings have broken mounting points that are commonly broken)
#39b (oops) OEM Nissan AAC IACV was bought new about 3 years ago for $400. Perfect working condition, not as dirty and clogged as most of the older iacv's that come with motorsets from japan and has the metal screw that wont strip like the older plastic ones - $180 SOLD
#40 S13 SR20DET stock MAFS (Mass Air Flow Sensor) works - $45 (not sold but currently missing from my last move)
#41 OEM Nissan gasket for T25 turbo compressor inlet - $10
#42 OEM Nissan SR20DET alternator rebuilt to 90amps and only used for about a year. Comes with all brackets and bolts - $150
#43 OEM S13 SR20DET turbo manifold with heat shield. Comes with used T2 gaskets, nuts, bolts, washers, locking tabs (will include #28 if not sold before this purchase) - $50 SOLD
#44 OEM Nissan Valve Cut 17065-05U00 for fuel pump system. If you dont know what it is, you probably dont need it. Brand new unused - $10
#45 KA24DE starter USED condition - $45
#46 Stance oversized water pump pulley - Used in mint condition with belt in almost new condition - $60 SOLD
#47 OEM Nissan 11810-86G01 valve control / PCV valve BRAND NEW - $12 SOLD
#48 Used stock OEM shifter - $10
#49 Used OEM Nissan S13 SR20DET starter of a blacktop motor - $120
***NEWLY ADDED 11/09/2011 ***
#50 Brand New Signal Auto Aluminum Cooling panel for S13 (fits silvia and 180 fronts) - $50 picked up or $65 shipped
#51 OEM shifter boot and ring bracket - $50 shipped
#52 OEM shifter boot and ring bracket painted black - $50 shipped
#53 OEM upper rubber shifter hole boot - $50 shipped
ADDED 11/14/2011
#54 S13 SR20DET Blacktop head, OEM valves, cleaned and decked with new supertech valve seals. Nothing stripped or broken but missing cam caps. Put a machine shop to work or just use it as a mock up - $60 SOLD SOLD SOLD
#55 OEM S13 SR20DET crank with 1 bearing damage - $60
#56 OEM S13 SR20DET flywheel - $20
#57 OEM S13 SR20DET transmission bellhousing alignment plate - $50 SOLD
http://squarespokes.com/
besTint is offline   Reply With Quote
Old 10-30-2011, 03:43 AM   #2
psychos13
psychos13's Avatar
psychos13 is an unknown quantity at this point
good deals glws
UNDER DESTRUCTION!: 91 s13 Top Secret Build
psychos13 is offline   Reply With Quote
Old 10-30-2011, 04:20 AM   #3
D1S13
D1S13's Avatar
D1S13 can only hope to improve
organized for sale thread FTW
BUMP
www.teamtopflight.blogspot.com
D1S13 is offline   Reply With Quote
Old 11-01-2011, 01:01 PM   #4
s14newb
s14newb is an unknown quantity at this point
Very fast shipping. Thanks again
s14newb is offline   Reply With Quote
Old 11-01-2011, 01:44 PM   #5
jeremyuhh
Trader Rating: (51)
jeremyuhh is an unknown quantity at this point
Feedback Score: 51 reviews
nice FS thread. bump
jeremyuhh is offline   Reply With Quote
Old 11-01-2011, 02:20 PM   #6
nujabe
nujabe's Avatar
nujabe can only hope to improve
payment sent for wide band.
Some black guy who lurks zilvia.
nujabe is offline   Reply With Quote
Old 11-01-2011, 02:27 PM   #7
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
PM'ed you sir
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
Old 11-01-2011, 03:34 PM   #8
jdmlivin
jdmlivin's Avatar
Trader Rating: (48)
jdmlivin is making a name for him/her selfjdmlivin is making a name for him/her self
Feedback Score: 48 reviews
Send a message via AIM to jdmlivin
Nice stuff GLWS
jdmlivin is offline   Reply With Quote
Old 11-02-2011, 03:36 PM   #9
besTint
Trader Rating: (81)
lowball PM's are being ignored.
all other PM's replied. Sold items are being updated hourly.
added more item> BUMP
Old 11-02-2011, 03:57 PM   #10
slydin240sx
slydin240sx is an unknown quantity at this point
Nice FS thread. All organized PROPER like. Bumpity bump!
slydin240sx is offline   Reply With Quote
Old 11-02-2011, 05:09 PM   #11
Seraphim38
Seraphim38's Avatar
Seraphim38 is an unknown quantity at this point
Send a message via ICQ to Seraphim38
PM sent for Stance water pump pulley, Nismo OEM slave cylinder and stainless line. I can paypal for them tonight.
Seraphim38 is offline   Reply With Quote
Old 11-02-2011, 11:51 PM   #12
Seraphim38
Seraphim38's Avatar
payment sent for stance water pump pulley, nissan slave cylinder and braided line.
Old 11-08-2011, 10:19 AM   #13
nujabe
nujabe's Avatar
got my wide band legit guys!! thanks ! bumpty
Old 11-08-2011, 10:37 AM   #14
Seraphim38
Seraphim38's Avatar
fast shipping, great seller.
Tempted to buy the stance block adapter...
Old 11-08-2011, 11:06 AM   #15
zz_kouki_zz
zz_kouki_zz's Avatar
zz_kouki_zz is an unknown quantity at this point
Hook me up with the knock sensor and turbo compressor elbow shipped to Orlando florida? pm me pls
Thanks!
1997 KOUKI SR'D SKEPTRON POWER!
zz_kouki_zz is offline   Reply With Quote
Old 11-08-2011, 05:20 PM   #16
besTint
Trader Rating: (81)
Thumbs up
Thanks for the bump! enjoy.
ty for the feedback =) pleasure doing business
Thanks!
HOOKUP sent via PM
Old 11-08-2011, 07:22 PM   #17
1slicktwo4oh
Trader Rating: (45)
1slicktwo4oh is an unknown quantity at this point
Feedback Score: 45 reviews
Free bump for a great seller^^^^
1slicktwo4oh is offline   Reply With Quote
Old 11-09-2011, 04:55 AM   #18
Q.Smooth127
Q.Smooth127 is an unknown quantity at this point
hook me up on the greddy dp shipped to 96825?
Q.Smooth127 is offline   Reply With Quote
Old 11-09-2011, 05:03 PM   #19
Fullboost99
Fullboost99's Avatar
Fullboost99 is an unknown quantity at this point
Bump!!! Nice FS Thread!
84 S12 GAZELLE COUPE: RB26 POWERED
81 Toyota Corolla Liftback SR Powered
Fullboost99 is offline   Reply With Quote
Old 11-12-2011, 11:50 AM   #20
besTint
Trader Rating: (81)
Thumbs up
Thank you, hope you get to enjoy everything =)
Thank you for the bump.
PM'd you price shipped to Hawaii. Sorry but shipping is too much, dont think it'll be worth it.
weekend bump!
Old 11-14-2011, 06:44 PM   #21
Noxy
Noxy's Avatar
Trader Rating: (18)
Noxy is an unknown quantity at this point
Bump for great seller! Buy his stuff!
Noxy is offline   Reply With Quote
Old 11-15-2011, 09:22 AM   #22
nismo racer
nismo racer's Avatar
nismo racer is making a name for him/her selfnismo racer is making a name for him/her self
Ill take the aem boost solenoid. Pm me since my phone won't let me pm you for some reason....
PEGASUS
nismo racer is offline   Reply With Quote
Old 11-15-2011, 09:31 AM   #23
97nismo
97nismo's Avatar
Trader Rating: (53)
97nismo is an unknown quantity at this point
Feedback Score: 53 reviews
item #43 shipped to 29630
Feedback:
http://zilvia.net/f/itrader.php?u=78978
97nismo is offline   Reply With Quote
Old 11-15-2011, 10:29 AM   #24
besTint
Trader Rating: (81)
$58 shipped - usps priority mail - paypal [email protected]
PM SENT
are you sure? shipping is $29.61 @ 18lbs
i would love to sell it but i think you'd be better off finding it local and avoid shipping on something like this.
Old 11-17-2011, 12:56 PM   #25
97nismo
97nismo's Avatar
Trader Rating: (53)
Would u separate the shield ?
Feedback:
Old 11-17-2011, 05:31 PM   #26
besTint
Trader Rating: (81)
Thumbs up
sorry, it'll make it harder to sell. but if someone wants to pick up just the manifold i'll let you know.
Old 11-17-2011, 06:26 PM   #27
Socal_sil80
Socal_sil80's Avatar
Trader Rating: (39)
Socal_sil80 is an unknown quantity at this point
Feedback Score: 39 reviews
bump for you! thanks again!
1993 240sx Hatchback
Socal_sil80 is offline   Reply With Quote
Old 11-18-2011, 03:18 AM   #28
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
i love your for sale thread. bump for u
Old 11-18-2011, 09:58 AM   #29
JDGrimReaper666
JDGrimReaper666's Avatar
JDGrimReaper666 is an unknown quantity at this point
PM me if youre taking trades for #11.
"Show no compassion, like having a straight face orgasm"
JDGrimReaper666 is offline   Reply With Quote
Old 11-18-2011, 10:58 AM   #30
T40sx
T40sx is an unknown quantity at this point
you don't have the stock sr cams with those sprockets, do you?
T40sx is offline   Reply With Quote
