Old 09-24-2011, 07:11 PM   #1
AlexSR
AlexSR is an unknown quantity at this point
auto to manual on S14 w/ABS/VLSD - Driveshaft?
Im doing a 5 speed swap on my S14 SE that came with ABS and VLSD from the factory, and I was wondering what options I had for the driveshaft since its impossible of finding a manual ABS s14 driveshaft...
I happen to have a S13 5 speed driveshaft laying around, I was told that I could cut the rear portion on my auto driveshaft and tig weld it onto the front portion of the S13 driveshaft, is this true?
AlexSR is offline   Reply With Quote
Old 09-24-2011, 07:36 PM   #2
AutechKouki
AutechKouki's Avatar
Trader Rating: (39)
AutechKouki is an unknown quantity at this point
Feedback Score: 39 reviews
If you want serious vibrations because you welded your driveshaft then do it, other than that DON'T DO IT.
I suggest you just get the front shaft from a manual s14 and replace your auto front shaft with the manual one. Easy.
AutechKouki is offline   Reply With Quote
Old 09-24-2011, 07:54 PM   #3
AlexSR
Cant I just do that with the front shaft from the S13 driveshaft then? I believe there is not difference between the s13 and s14 front shafts, only the rears are different
Old 09-24-2011, 07:55 PM   #4
skysilvias13
skysilvias13's Avatar
skysilvias13 is an unknown quantity at this point
drive shaft shop one piece in my personal opinion. OR you can do the auto front piece and manual rear piece.... It is one of the two....
Sorry just saw where your from.....
skysilvias13 is offline   Reply With Quote
Old 09-24-2011, 08:00 PM   #5
Ekin_s13
Ekin_s13 is an unknown quantity at this point
i just recently did a atuo to manual on my s14
S13-1st section (no difference for ABS/non-ABS):
M/T: 395.0mm (15.55")
A/T: 432.0mm (17.01")
S13 2nd section (no difference for MT/AT)
non-ABS: 605.0mm (23.82")
ABS: 590.0mm (23.23")
S14-A/T 1st section = 421.0mm (16.57")
M/T 1st section = 441.0mm (17.37")
S14-ABS Rear Section = 636.0mm (25.04")
non-ABS Rear Section = 650.0mm (25.59")
if you would of google i got this from
S13/S14 driveshaft (manual) - Nissan 240SX Forums
Ekin_s13 is offline   Reply With Quote
Old 09-24-2011, 08:01 PM   #6
Sileighty_85
Sileighty_85's Avatar
Driveshaft Shop NISH4 Aluminum Driveshaft S14 240SX ABS/VLSD
Problem Solved
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 09-24-2011, 08:15 PM   #7
AlexSR
Yeah..I'm kind of trying to avoid spending 500 bucks for a fucking driveshaft..
Old 09-24-2011, 08:35 PM   #8
Sileighty_85
Gotta pay to play, its on sale for $410 right now
後輪駆動車1番
1986 SR86 - 200ish
Old 09-25-2011, 02:59 PM   #9
WacingWandy's240
WacingWandy's240 is an unknown quantity at this point
Shaft Master's. They have excellent stuff and a little bit cheaper than Driveshaft shop. Aluminum or steel. I run an aluminum one and my friend has one also. VERY nice piece and had no problems with it at all.
WacingWandy's240 is offline   Reply With Quote
