Old 08-17-2011, 10:34 PM   #1
MyblackS13
MyblackS13's Avatar
MyblackS13 is an unknown quantity at this point
s13 Lots of Redtop SR20DET parts, Swap, FMIC, Transmissions,Free Shipping UPDATE 12-01-11
UPDATE 12-01-11 I'm covering the shipping to the lower 48 on everything but the transmissions. I want to get this stuff out of my garage.
I'm changing the set-up of my car so I'm selling a bunch of parts. All of the aftermarket parts have between 5-7,000 miles on them and the engine was rebuilt at that time as well, so most of the parts are in like new condition or with minimal wear. All Garage Kept, the donor car hasn't even seen rain in over 6 years. I keep my stuff super clean.
I am parting instead of selling as a whole because there was some scoring in the cylinders so it was going to need another rebuild and I decided to go LS1 instead.
All Parts are Red Top SR20DET unless otherwise noted.
All prices are obo, but no low ridiculous balls please.
Anything that isn't in red and marked as sold is still for sale
Here is the list.
-Block (bored at 86.5mm, scored bores and damage at bottom of #4, good candidate for sleeves,Includes Main Girdle, Caps, Piston Squirters) -$ Sold
-Crankshaft (Balanced, Polished, Ready to Go, 2,000 miles since polish) -$100.00
-86.5mm Wiseco Forged Pistons, mild scuffing on skirts but appear to be otherwise good -$ sold
-86mm stock pistons -$ sold
-Oil Pump (Disassembled, Checked Clearances 2,000 miles ago) -$ sold
-SR20DET rods (I have 3) -$ 25.00 each
-SR20DE rod (Only One, Sentra SE-R, Infiniti G20) -$ 15.00
-Lower Oil Pan (2,000 miles, still has the factory sticker, looks new) -$ 45.00
-Upper Oil Pan (Cast Aluminum, good condition, clean, no cracks) -$ 65.00
-Oil Strainer (s13) -$ 15.00
-Windage trays -$ 15.00
-OEM intake manifold with Throttle Body, TPS, and IACV -$ sold
-Built Cylinder Head -$ Sold
(Low Mileage Valve Job, Crower Ti Retainers, Comp Cams Springs, Shimmed, New Guides, Extra Set of Supertech Seals, Stock Cams, Caps, Gears, Oil Squirters included)
-Greddy Rocker Arm Stopper -$ Sold
-Used ARP Head Studs (2 Torque Cycles) -$ Sold
non-undercut style
-New ARP Head Studs -$ sold
under cut style
-Used ARP Main Studs (2 Torque Cycles) -$ 45.00
-Coil Packs (1 Set left With Coil Harnesses) -$ 80.00
-JDM SR20DET Rwd Starter - $85.00
-JDM SR20DET Alternator and Brackets - $90.00
-JDM SR20DET Power Steering Pump - $85.00
-Engine Wiring Harness (Converted to 240sx Chassis plugs and dash plugs, Plug & Play) -$149.00
-Cam Angle Sensor (works perfectly, clean OEM part) -$sold
-Knock Sensor -$ 30.00
-Ignitor Chip (JDM SR20DET) -$ sold
-Oil Pressure Switch -$ 7.00
-Exedy Lightened Chromoly Steel Flywheel ($380.00 new) -$289.00
-Unknown make performance clutch, very grippy held the GT28RS torque well, w/ pressure plate -$ 75.00
A little blurry but the center says unisia, dunno if that makes it identifiable for anyone.
-SR20DET Transmission -$100.00 as is $350.00 re-shimmed
(includes speed sensor, rebuild 2,000 miles ago grinds into 5th needs shimmed, includes the S14 Reverse synchro's)
-2 KA24 Transmissions -$100.00 ea
Sorry I can't do free shipping on the transmissions, but if you're not too far away I might be able to deliver or meet part way.
-B&M Shifter (The best available for a 240, nice solid, short, positive throws) - sold
-Low Mileage Timing Set (under 2,000 miles like new Slides, Improved Metal Slack Slide, Chain -$ sold
-Timing Chain Tensioner (New Fine Tooth Style under 2,000 miles) -$ 49.00
-Timing Chain Tensioner (Old Style 3-5,000 miles) -$ 25.00
-Timing Chain (3-5,000 miles) -$ 15.00
-Turbo Set-Up (5-7,000 miles on set-up, exceptional conditon, bolt in) -Sold
-Genuine Garrett Disco Potato, GT28RS, GT2860RS Ball Bearing Turbo
-Custom intake for turbo
-JWT ECU
-Mustang Cobra MAF Sensor
-MSD 50# injectors (will include new crimp on connectors)
-JGY fuel rail
-SS Autochrome/Ebay manifold, stainless steel, thick, no cracks, good condition
-Megan Single, turbo outlet, I think it would be considered greddy style
-Enjuku Exhaust Manifold Stud Kit
-New Copper Gasket
-good for approximately 300-320whp with a huge mid range punch, it comes on fast and strong
-Custom under intake waterlines and turbo lines -Sold
-Blitz LM FMIC, Greddy Hot Pipe -$300.00 Shipped to the lower 48!!!
(This is the real deal, last I checked these were over $600 new, and in '02 when I bought it it was over $900, I'm taking a pretty big hit on this one. It is in great working condition, but cosmetically is less than perfect, it has a dent and is bowed slightly from a raccoon hit, but holds pressure, no oil inside)
-Greddy Hot Pipe, Go Fast Bits RFL bov (sounds like air brakes when it opens) -$100.00
-Knock-off Greddy style hot pipe, never used -$ 30.00
-Greddy Style Down Pipe - $ sold
-Power Seat Belt Controller - $7.00
PM me if you have any questions or need to see any additional pics.
Lots of pics of the car and set-up on my website Sinister Silvia - Main Page
Also, photobucket of the parts pics.
Pictures by redsand481 - Photobucket
For my feedback since I haven't bought or sold on here, check my ebay score, Redsand481.
Loved the set-up, hate to see it go, but its time to switch it up.
Dustin - S13 Build
LS1 Inside
Last edited by MyblackS13; 11-30-2011 at 11:00 PM.. Reason: added pictures and extra info
MyblackS13 is offline   Reply With Quote
Old 08-18-2011, 09:13 AM   #2
SilEightyRHD
SilEightyRHD is an unknown quantity at this point
would you sell the silvia corner lamps...as long as there are no broken tabs and all sockets are there...shipped to 23455
SilEightyRHD is offline   Reply With Quote
Old 08-18-2011, 11:43 AM   #3
MyblackS13
MyblackS13's Avatar
Sorry man, keeping the car, just changing the drivetrain, so I'll need the lights. But I am selling the front fiberglass fenders, side skirts and rear overs in another older listing.
Dustin - S13 Build
LS1 Inside
Old 08-18-2011, 07:28 PM   #4
2fast4y0u
2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore
where in indy are you?
2fast4y0u is offline   Reply With Quote
Old 08-18-2011, 07:47 PM   #5
TrustS13
TrustS13's Avatar
TrustS13 is an unknown quantity at this point
Pics of the B&M? Shipped price to 27310?
TrustS13 is offline   Reply With Quote
Old 08-19-2011, 07:54 AM   #6
camaro379ss
camaro379ss's Avatar
camaro379ss is an unknown quantity at this point
I also would like to know where in indy are you? As well as were the seals replaced when the head was built?
1991 Nissan B13 Sentra sr20det 300whp/1991 Nissan S13 240sx sr20det ~260whp
camaro379ss is offline   Reply With Quote
Old 08-19-2011, 08:26 AM   #7
MyblackS13
MyblackS13's Avatar
I'm in Fort Wayne, not Indy, sorry if there was any confusion. The seals were replaced when the head was built and should be in good shape. I tore the engine down because it was smoking a little on hard acceleration, I thought it might be valve seals so I bought a set, but I figured out that it was blow by when I took the head off.
Also, for those of you wanting pics I will have them up either tonight or tomorrow morning.
Dustin - S13 Build
LS1 Inside
Old 08-25-2011, 09:17 AM   #8
MyblackS13
MyblackS13's Avatar
Bump - dropped some prices and I'm throwing in a MLS HG with the head if someone hurry's up and buys it.
Dustin - S13 Build
LS1 Inside
Old 08-25-2011, 02:18 PM   #9
sqeezin
sqeezin is an unknown quantity at this point
ill take 1 set of the coils can u email me at [email protected]. i also have a brand new nos plate kit for a ls1 if your interested or u can call me at 4242474423
sqeezin is offline   Reply With Quote
Old 08-25-2011, 08:46 PM   #10
chaos240sx
chaos240sx's Avatar
chaos240sx is an unknown quantity at this point
still got the Wiseco pistons?
chaos240sx is offline   Reply With Quote
Old 08-25-2011, 10:29 PM   #11
MyblackS13
MyblackS13's Avatar
Chaos - Still have the pistons, I can pop them off the rods, put them in the original box and send them out priority mail this weekend if you want them. Send me a PM and let me know.
Dustin - S13 Build
LS1 Inside
Old 09-07-2011, 09:58 AM   #12
MyblackS13
MyblackS13's Avatar
Bump #2. Dropped some more prices.
Dustin - S13 Build
LS1 Inside
Old 09-07-2011, 12:11 PM   #13
s14k
s14k is an unknown quantity at this point
head
still have the head for sale very interested in head and rocker stops shipped to 29456
brian
s14k is offline   Reply With Quote
Old 09-07-2011, 01:10 PM   #14
MyblackS13
MyblackS13's Avatar
Brian,
The head and rocker arm stoppers shipped to 29456, ups ground, insured at $500 is a total of $561.00
Dustin - S13 Build
LS1 Inside
Old 09-07-2011, 05:37 PM   #15
NIZzS13
NIZzS13 is an unknown quantity at this point
Would you be willing to sell all 8 rocker arms, iacv, and the brass coolant tube. let me know asap im lookin for a quick sale shipped to 10469.
NIZzS13 is offline   Reply With Quote
Old 09-07-2011, 11:07 PM   #16
MyblackS13
MyblackS13's Avatar
Sorry man, the rocker arms need to stay with the head, unless I end up stripping it, because if I take them off it defeats the purpose of it being shimmed. I'm selling the manifold cheap, so the IACV can come with a TPS and all the other goodies for $55.00 and the zinc plated under manifold coolant tube, is modified to fit the custom turbo lines and won't work with any other braided lines unless you make them custom to fit it. That set-up is $185.00. If you want the two, shipping will be $15.00.
Dustin - S13 Build
LS1 Inside
Old 09-08-2011, 01:00 AM   #17
Volcom887
Volcom887's Avatar
Volcom887 is an unknown quantity at this point
how much for just the disco turbo ? pm me a price please all i need is turbo and lines
Volcom887 is offline   Reply With Quote
Old 09-09-2011, 01:10 PM   #18
vw203
vw203's Avatar
vw203 is an unknown quantity at this point
Send a message via AIM to vw203
do you have everything to bolt the intercooler to bolt on?
スカイライン
vw203 is offline   Reply With Quote
Old 09-09-2011, 01:37 PM   #19
MyblackS13
MyblackS13's Avatar
You mean the L-brackets to the car, and piping, right? I have those, they're included. Also, all of the clamps are upgraded stainless T-bolt clamps, aside for maybe one or two where I didn't have enough room. Also, if I look through some of my extra hardware, I think I still have the washer fluid reservoir brackets if you want them, never used those.
Here's how it looked on my car, with the bumper cover off.
Dustin - S13 Build
LS1 Inside
Old 09-11-2011, 02:34 AM   #20
Tae-Hyun
Tae-Hyun's Avatar
Tae-Hyun is an unknown quantity at this point
I'll take that starter sir.
thanks.
I only like you when you give me cookies.
Tae-Hyun is offline   Reply With Quote
Old 09-12-2011, 06:11 PM   #21
240agsx
240agsx's Avatar
240agsx is an unknown quantity at this point
Do u have a stock redtop ecu
Sent from my DROIDX using Tapatalk
240agsx is offline   Reply With Quote
Old 09-12-2011, 07:04 PM   #22
Bushido
Bushido's Avatar
downpipe shipped to 32605?
Old 09-12-2011, 07:48 PM   #23
tibby12
tibby12 is an unknown quantity at this point
downpipe shipped to 27529. Have money ready...
tibby12 is offline   Reply With Quote
Old 09-12-2011, 10:34 PM   #24
MyblackS13
MyblackS13's Avatar
Sorry man, no stock ecu.
Also, it looks like I have a run on the downpipe, so to be fair, I'll go down the list in the order received.
Dustin - S13 Build
LS1 Inside
Old 09-14-2011, 06:18 PM   #25
Bushido
Bushido's Avatar
payment sent. thx
Old 09-14-2011, 07:44 PM   #26
boms
boms's Avatar
boms is an unknown quantity at this point
ill get the rocker arm stopper if not sold. pm me.. work out payment
boms is offline   Reply With Quote
Old 09-17-2011, 11:58 AM   #27
supra_speed
supra_speed's Avatar
supra_speed is a well-known jackass
pm sent for arp head studs non-undercut
supra_speed is offline   Reply With Quote
Old 09-17-2011, 01:50 PM   #28
stevecorrado88
stevecorrado88 is an unknown quantity at this point
Sent pm about a throttle body and cable bracket in the beginning of the week no replay and I really need it if u have them.
stevecorrado88 is offline   Reply With Quote
Old 09-29-2011, 01:58 AM   #29
drftx
drftx's Avatar
Trader Rating: (42)
drftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant future
Feedback Score: 42 reviews
Send a message via AIM to drftx
selling the valve stem seals?
drftx is offline   Reply With Quote
Old 09-29-2011, 06:45 PM   #30
MyblackS13
MyblackS13's Avatar
I was planning them as a bonus on the head even though it doesn't need them, but surprisingly to me I haven't had too many bites on it. PM me an offer on the seals and I'll give it consideration, keep in mind, I just bought them from Touge Factory in June so I don't want to take much of a loss on them by themselves.
Dustin - S13 Build
LS1 Inside
complete swap, disco potato, gt28rs, ret top, sr20det
