Old 05-27-2011, 10:23 PM   #1
sw20>>s14
sw20>>s14's Avatar
why do i keep breaking clock springs?!?!?!?!?
i installed a steering wheel and hub on my last s14 YEARS ago with no problems...no airbag light (with resistor) and working horn...
when transferring the same parts to my next s14, i installed it and broke the clock spring after installing everything and driving...i heard a lot of tension and something distinctly breaking...i figured i must have messed with the position or something...
installed another one, broke (tension/sound)...installed another one, broke (tension/sound)...finally installed my third one last week, with a different position...worked fine and today airbag light flashes again...
so my question is, what is the correct position of the clock spring? from what i remember (its been a while since the first install) and from what i see online, the proper/oem position should be like this:
big circle=clock spring
square=wiring for airbag/horn
small circle=peg/nub
with this position, i noticed that you only have half a turn to the right, and 1.5 turns to the left...ALL my breaks were right turns with the feeling of "not having enough slack" so i figured i was making the same mistake each time, but i could have swore this is the correct position from factory...
so this last time, i installed it like this:
in this position, i counted exactly one turn to the left and one turn to the right so it was even...worked perfect for about a week until today when my srs light started randomly flashing...no tension, no breaking sounds...
i even read the instructions on the clock spring itself and they dont make sense...it tells you to go all the way to the right and turn 2.5 turns until the triangles are lined up...the thing doesnt even make 2.5 turns...it maxes out at 2 full turns each direction, at which point the triangles dont line up...
sorry for the simple and noob question, but im really getting tired of buying clock springs!
95 s14| 03 y34| 07 exige s| 99 nb| 07 600rr| 09 250r| 85 girlfriend
sw20>>s14 is offline   Reply With Quote
Old 05-31-2011, 04:17 PM   #2
sw20>>s14
sw20>>s14's Avatar
tips anyone?
Old 05-31-2011, 06:46 PM   #3
!Zar!
!Zar!'s Avatar
I just took my clock spring out.
This helps you in no way at all.
I know.
hahaha
Old 05-31-2011, 07:00 PM   #4
naw_speed
naw_speed's Avatar
naw_speed is an unknown quantity at this point
I know.
hahaha
funny.... i was gona say pull the light bulb
))-> sil front on.. time for rocket bunny kit<-((
naw_speed is offline   Reply With Quote
Old 06-01-2011, 09:47 AM   #5
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Originally Posted by sw20>>s14 View Post
tips anyone?
I never really knew of a guide or a certain spot for all of th stuff, I always 'centered' the clock spring on the hub and went from there. I know it doesn't help 100% but just another opinion.
Old 06-01-2011, 05:43 PM   #6
sw20>>s14
sw20>>s14's Avatar
thanks for the tips guys, but it just bothers me that i have everything to make this work correctly...for some reason or another, it never does...any other pointers i may be missing on this trivial "install?"
Old 06-05-2011, 11:57 AM   #7
idlafie
idlafie's Avatar
idlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to behold
You probably installed the clock spring correctly, but the "brain" for your airbag system may be crapping out. There's a method for putting the Airbag "brain" into diagnostic mode that involves putting the key in the ignition, turning it to the "ON" position, (but NOT starting the car), and clicking the driver side door pin switch three or seven times...sorry I don't remember the procedure anymore...it's been too long.
Anyhow, you need to figure out why the "brain" is flashing the code. Chances are I think the "brain" may be fried. They have been known to crap out. Only way to know for sure is to get your hands on a Factory Service Manual and diagnose the problem.
I had the flashing Airbag Light with my S14 years ago, (before I sold it). Luckily for me, the car was still under warranty when it went out...turns out the "brain" died..... The Airbag ECU can be found underneath the rear bench seats...you'll see it once you pull the rear bench seat out...just look for the wiring harness wrapped with YELLOW tape....that's the airbag system wiring harness...
Hope this helps.
ID
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies....
idlafie is offline   Reply With Quote
