Old 02-21-2011, 06:57 PM   #1
2_Liter_Turbo
2_Liter_Turbo's Avatar
Trader Rating: (28)
2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough
Feedback Score: 28 reviews
Exclamation My Epic Garage Sale "Pt. 2"- S13/S14/KA24DE/SR20DET/OEM/Aftermarket - Over 200 Parts!
Welcome to my highly organized, and epically long, "for sale" thread; part 2. This is my entire stockpile of parts that I have in my garage that are up for sale! Most of this stuff is all OEM, but there are some aftermarket parts in the list. All prices are WITHOUT SHIPPING!!!!. Some prices are obo, some aren't. If there is an item that weighs 60 lbs and I'm only asking $10; don't offer $15 shipped for it. I will not ship a part and lose money for nothing. Use common sense when estimating an offer price shipped. The larger items I will get a quote for you, but due to the magnitude of this for sale thread, it may take me some time! If you do not see a part on this list that you are looking for, I DON'T HAVE IT! Also, when you are making an offer or asking for a shipping quote, include the part list number. If you do not, I will ignore your inquiry. This is a LONG LIST! If you do not wish to read through the list, you can look through the pics, and the list number is referenced next to each part. You can then look at the list and see how much I'm asking as well as a small description.
Well, enjoy:
001 Bare S13 SR20DET Intake Manifold $30.00
002 SR20DET Oil Pump Drive Collar $10.00
003 S13 SR20DET Main Bolts $10.00
004 S13 SR20DET Main Caps $10.00
005 S13 SR20DET Water Pump Pulley $15.00
006 S13 SR20DET T25 - Bad Bearings ***SOLD***
007 S13 SR20DET Alternator Bracket and Adjuster ***SOLD***
008 S13 SR20DET Crank Pulley and Bolt ***SOLD***
009 S13 SR20DET Power Steering Bracket ***SOLD***
010 S13 SR20DET Turbo Manifold Heat Shield ***SOLD***
011 S13 SR20DET T25 Hard Lines $15.00
012 S13 SR20DET Turbo Manifold $30.00 ***SOLD***
013 S13 SR20DET Turbo Elbow - Not Modified $20.00 ***SOLD***
014 S13 SR20DET T25 Compressor Inlet ***SOLD***
015 S13 SR20DET T25 Actuator $15.00
016 S13 SR20DET T25 Compressor Outlet ***SOLD***
017 S13 SR/KA Engine Mount - Great Shape ***SOLD***
018 3" Hole K&N Filter $15.00
019 S13 SR20DET (and KA) Clutch Fan (New Clutch) ***SOLD***
020 S13 SR20DET Oil Separator $10.00 ***SOLD***
021 S13 SR20DET Upper Oil Pan $25.00
022 S13 180SX Front Right Hub Assembly $20.00
023 Pair of 180SX Front Brake Line Brackets $10.00
024 S13 180SX Front Endlink (Slightly Bent) $5.00
025 S13 180SX Tension Rod ***SOLD***
026 S13 180SX Charcoal Canister ***SOLD***
027 S13 180SX Charcoal Canister Bracket ***SOLD***
028 S13 180SX Right Front Lower Control Arm $15.00
029 S13 KA24DE/SR20DET Transmission Mount ***SOLD***
030 S13 KA24DE Crank Pulley ***SOLD***
031 S13 USDM Upper Chassis Cat Shield $10.00
032 Pair of S13 Rear Upper Control Arms $20.00
033 Pair of S13 Rear Toe Rods $20.00
034 Pair of S13 USDM Front Brake Rotors $15.00
035 Pair of S13 USDM Front Brake Calipers $30.00
036 Pair of S13 USDM Rear Brake Hoses $7.00
037 Pair of S13 USDM Front Brake Hoses $7.00
038 Pair of Z32 USDM Front Brake Hoses $7.00
039 Pair of S13 Front 4-Lug Hubs ***SOLD***
040 Pair of S13 Battery Tie Downs $15.00
041 Q45 Igniter Chip with Pigtails ***SOLD***
042 S13 Coupe Back Seat Pad $10.00
043 S13 USDM Center Console With Power Mirror $25.00
044 S13 USDM Ash Tray ***SOLD***
045 Pair of S13 Front Speaker Pods $15.00
046 S14 KA24DE Intake Inlet Tube $15.00
047 S13 USDM Lower Cat Shield ***SOLD***
048 S14 KA24DE Intake Filter Box (No Filter) $20.00
049 S14 KA24DE Throttle Body Intake Coupler ***SOLD***
050 R33 RB25DET Throttle Body w/ TPS $40.00 ***SOLD***
051 S13 USDM Sun Visors $15.00
052 S13 USDM Rear Sway Bar Endlink (Strait) $5.00
053 S13 USDM Rear Sway Bar Bushings & Brackets $7.00
054 S14 KA24DE Water Pump Pulley ***SOLD***
055 S14 KA24DE Upper Radiator Hose $7.00
056 KA24DE Exhaust Manifold Heat Shield $10.00
057 S14 KA24DE EGR BPT Control Valve $15.00
058 S14 KA24DE EGR Valve $30.00
059 S14 KA24DE AICV ***SOLD***
060 S14 KA24DE Air Valve ***SOLD***
061 S14 KA24DE Intake Manifold ***SOLD***
062 Was Told S13 Convertible Rear View Mirror $25.00
063 S14 KA24DE Fuel Pressure Regulator $20.00
064 S13 Rear Firewall Vibration Damper $5.00
065 S13 USDM Rear Seat Belt Latches $10.00
066 S13 USDM Coupe Rear Right Side Trunk Cover $10.00
067 S13 180SX Gas Pedal $10.00
068 Assorted (a-f) S13 Seat Mounting Covers $15.00
069 S14 OBDII 5 Speed Engine Harness (Cut) $40.00
070 S14 OBDII 5 Speed Misc Sub Harness $5.00
071 S14 USDM Cruise Control Cable ***SOLD***
072 S13 KA24DE Water Pump Pulley $15.00
073 S13 SR20DET Intake Manifold $30.00
074 S13 SR20DET AICV ***SOLD***
075 S14 KA24DE Intake Tube $20.00
076 S13/S14 KA24DE EGR Tube ***SOLD***
077 S14 USDM Cruise Control Bracket ***SOLD***
078 S14 KA24DE Intake Box Parts $10.00
079 S13 Speed Sensor (Not sure what motor) Fits SR Trans $25.00
080 S14 KA24DE Radiator Support Brackets $10.00
081 S14 USDM Cruise Control Module ***SOLD***
082 S13/S14 KA24DE Oil Cap $5.00
083 S14 KA24DE Shifter $15.00
084 S14 OBDII Misc Control Solenoids $15.00
085 S14 OBDII Evap Valve w/ Hoses $5.00
086 S13 5 Speed Shifter (Torn Boot) ***SOLD***
087 S14 KA24DE Exhaust Manifold ***SOLD***
088 S13/S14 KA24DE EGR Tube $10.00
089 S13 SR20DET Oil Pump Drive Collar $10.00
090 S13 SR20DET Pistons and Rods ***SOLD***
091 S13 SR20DET Oil Dipstick and Tube $20.00
092 S13 USDM Front Sway Bar Bushings $5.00
093 S13 USDM Rear Sway Bar Bushings $5.00
094 S13 SR20DET Lower Oil Pan (Only Dent Shown) $20.00
095 S13 180SX Tension Rod $10.00
096 S13 SR20DET Valve Springs and Retainers $40.00
097 S14 KA24DE Air Valve $20.00
098 S14 KA24DE AICV ***SOLD***
099 S14 KA24DE Intake Manifold $30.00
100 S14 KA24DE Intake Resonator Box $5.00
101 S14 KA24DE A/C Compressor $50.00
102 S14 KA24DE A/C Compressor Bracket w/ Adjuster ***SOLD***
103 S14 KA24DE Fuel Rail $15.00
104 S14 KA24DE Fuel Pressure Regulator $20.00
105 S14 KA24DE Distributor w/ Wires ***SOLD***
106 S14 KA24DE Alternator ***SOLD***
107 S13 KA24E 5 Speed ECU - CA Emissions $70.00
108 S13 KA24E 5 Speed ECU - Federal Emissions ***SOLD***
109 S13 KA24DE Water Pump ***SOLD***
110 S13 KA24DE Auto Speed Sensor $10.00
111 S13/S14 KA24DE Oil Cap $5.00
112 S13 KA24DE Valve Cover (White) $40.00
113 KA24DE Exhaust Manifold Heat Shield $10.00
114 S14 USDM Cruise Control Module $15.00
115 S13 USDM Automatic Brake Pedal $10.00
116 S13 USDM Automatic Shifter $15.00
117 S13 USDM Automatic Shifter Trim $5.00
118 S13 KA24DE Power Steering Pump Bracket ***SOLD***
119 KA24DE Intake Manifold Bracket $5.00
120 KA24DE Upper Timing Chain (Great Shape) $10.00
121 KA24DE Intake Manifold Bracket $5.00
122 S13 SR20DET Boost Solenoid Setup $5.00
123 S13 Air Intake Temp Sensor $10.00
124 Misc Nissan Resistor Box (S14 Auto Tranny?) $5.00
125 KA24DE Head Bolts $10.00
126 S13 HICAS PS Fluid Reservoir $20.00
127 S13 USDM Rear Seat Belt Latches $10.00
128 S13 B-Pillar Exterior Trim Pieces $15.00
129 S13 KA24E PS Fluid Reservoir $10.00
130 Q45 Igniter Chip with Pigtails ***SOLD***
131 S13 Rear Red Side Marker ***SOLD***
132 S13 Right Side Manual Mirror Housing $10.00
133 S13 USDM Lap Belts $15.00
134 S13 Rear Strut Caps $10.00
135 S13 Radiator Bracket $5.00
136 S13 Manual Mirror Covers (Some broken tabs) $5.00
137 Home Made 240SX Test Pipe ***SOLD***
138 S13 180SX (RHD) Under Dash Trim Piece $20.00
139 S13 180SX (RHD) Glove Box Support Bracket $10.00
140 S13 180SX (RHD) Under Dash Wiring Harness ***SOLD***
141 S13 KA24DE MAF (Works on S13 SR20DET Swaps) $50.00
142 S13 KA24DE MAF (Works on S13 SR20DET Swaps) ***SOLD***
143 S Chassis MAF (Part #: 22680 53F00_A36-000 G60) $50.00
144 S13 SR20DET Alternator Pulley $10.00
145 S13 USDM Trunk Cover Holder $10.00
146 S13 Speed Sensor (Not sure what motor) Fits SR Trans $25.00
147 S13 KA/SR Exhaust Side Engine Mount $15.00
148 KA24DE Intake Box Plastic Coupler $5.00
149 KA24DE Alternator Adj Bracket ***SOLD***
150 S13 KA24DE Power Steering Pump (Can use for SR) ***SOLD***
151 S13 KA24DE EGR BPT Control Valve $10.00
152 S13 KA/SR Intake Side Engine Mount $15.00
153 S13 KA24DE A/C Compressor Bracket w/ Adjuster $15.00
154 S13 Drive Shaft Carrier Bearing Bracket $5.00
155 S13 KA24DE Center Timing Chain Sprocket/Bolt $20.00
156 S13 5 Speed Tranny Clutch Fork $10.00
157 S13 Exhaust Mount ***SOLD***
158 S13 SR 5 Speed Tranny Rear Dust Cover $5.00
159 240SX Exhaust Side Emissions Bracket $5.00
160 KA24DE Power Steering Pump Pulley ***SOLD***
161 S13 Exhaust Mount Hanger $10.00
162 S13 Exhaust Mount ***SOLD***
163 S13 SR20DET Coolant Temp Sensor Housing ***SOLD***
164 SR20DET Power Steering Pump Pulley ***SOLD***
165 240SX 5 Speed Throw Out Bearing and Carrier $15.00
166 S13 SR20DET Rear Main Seal Housing $15.00
167 S13 SR20DET OEM Fuel Rail $30.00
168 S13 SR20DET Oil Pickup Baffle $20.00
169 S13 SR20DET Oil Pickup $15.00 ***SOLD***
170 S13 KA24DE EGR Valve $25.00
171 S13 240SX Trunk Emergency Jack ***SOLD***
172 S14 SR20DET Oil Pickup $25.00 ***SOLD***
173 S13 SR20DET OEM Flywheel $30.00 ***SOLD***
174 240SX KA24DE Water Outlet $15.00
175 S14 USDM Cruise Control Cable $10.00
176 240SX Battery Tie Down $7.50
177 240SX Battery Tie Down ***SOLD***
178 S13 240SX Brake Master Cylinder Reservoir $10.00
179 S13 Exhaust Mount Hanger $10.00
180 S13 SR20DET Alternator Bracket and Adjuster $25.00
181 S13 SR20DET Intake Cam Sprocket $15.00
182 S13 SR20DET Exhaust Cam Sprocket $15.00
183 S13 KA24DE Crank Pulley ***SOLD***
184 S13 SR20DET Oil Filter Block $15.00
185 S13 SR20DET Alternator Bracket Lower Brace $5.00
186 S14 KA24DE Exhaust Manifold $15.00
187 S13 SR20DET Turbo Manifold $30.00 ***SOLD***
188 S13 KA24DE Starter ***SOLD***
189 S13 KA24DE Alternator $50.00
190 S13 SR20DET Turbo Elbow - Modified $25.00 ***SOLD***
191 S14 KA24DE Auto ECU (C6: A18-E28 G77) $70.00
192 Pair of S13 Front Speaker Pods $15.00
193 S13 Dash Center Vents (Trim Painted White) $10.00
194 S13 180SX (RHD) Gas Pedal Stop $15.00
195 S13 Seat Back Support Spring (front seat) $5.00
196 S13 KA24DE Intake Box Inlet Tube $15.00
197 S13 USDM Right Side Shoulder Belt $15.00
198 S13 USDM Rear View Mirror $20.00
199 S13 USDM Power Seat Belt ECU $15.00
200 S13 180SX (RHD) Center Inside Dash Vent Coupler $15.00
201 S13 180SX (RHD) Lower Steering Column Trim ***SOLD***
202 S13 180SX (RHD) Upper Steering Column Trim ***SOLD***
203 S13 180SX (RHD) Center Inside Dash Vent Piece $25.00
204 S13 USDM A-Pillar Mounting Bracket $5.00
205 S13 USDM Steering Wheel ***SOLD***
206 Assorted (a-f) S13 Seat Mounting Covers $15.00
207 S13 USDM Pair of A-Pillar Mounting Brackets $10.00
208 S13 180SX (RHD) Dead Pedal ***SOLD***
209 S13 180SX (RHD) Gauge Surround Buttons (a-c) $45.00
210 S13 Manual Engine Bay Fuse Box Cover ***SOLD***
211 S14 MAF (Flange Cut For Cone Filter) ***SOLD***
212 S13 Unknown Interior Bracket $5.00
213 S13 Pop-Up Headlight Harness $5.00
214 S13 180SX (RHD) Dual Bumper Blinker Harness ***SOLD***
215 S13 180SX (RHD) Horn $20.00
216 S13 Pop-Up Headlight Harness Cups $5.00
217 S14 USDM Automatic Brake Pedal $10.00
218 S13 USDM Pop-Up Headlight Bucket $10.00
219 S13 USDM Plastic Battery Tray $10.00
220 S13 240SX Driver Side Lower Bumper Vent $10.00
221 S13 USDM Windshield Squirter Motor and Reservoir $35.00
222 S13 240SX Gas Pedal $10.00
223 S13 240SX Charcoal Canister $10.00
224 S13 240SX Exhaust Side Recirc Valve (Emissions) $40.00
225 S13 USDM A-Pillar Mounting Bracket $5.00
226 S13 USDM Bumper Mounting Brackets $15.00
227 KA24DE Exhaust Manifold Heat Shield $10.00
228 S13 USDM Lower Cat Shield $10.00
229 S13 USDM Passenger Side Headlight Cover $15.00
230 S13 USDM Passenger Side Headlight Cover ***SOLD***
231 S13 180SX (RHD) Steering Column ***SOLD***
232 S13 180SX (RHD) Radiator Bracket (I think) $10.00
233 S13 180SX (RHD) Emissions Pipe (Bolts to Rear of SR Head) $10.00
234 S13 180SX (RHD) SR Emissions Bracket $5.00
235 S13 180SX (RHD) SR Emissions Solenoid $5.00
236 S13 SR20DET T25 - Shaft Play ***SOLD***
237 S13 SR20DET T25 Hard Line $5.00
238 S13 180SX (RHD) SR Emissions Solenoid $5.00
239 S13 180SX (RHD) SR Emissions Device $10.00
240 S13 Speed Sensor (Not sure what motor) Fits SR Trans $25.00
241 S13 SR20DET Intake Manifold Bracket $5.00
242 240SX Battery Tie Down $7.50
243 S13 SR20DET Water Pump (Lower Miles) $20.00
244 S13 SR20DET Turbo Manifold $30.00 ***SOLD***
245 S13 SR20DET Turbo Manifold Heat Shield $20.00 ***SOLD***
246 S13 KA24DE MAF (Works on S13 SR20DET Swaps) $50.00
247 S13 180SX HICAS PS Fluid Reservoir $20.00
248 S13 180SX (RHD) Brake Pedal $10.00
249 GTIR SR20DET Individual Throttle Body Manifold Setup ***SOLD***
250 S13 SR20DET OEM Injector ***SOLD***
251 S13 SR20DET OEM Injector ***SOLD***
252 S13 SR20DET OEM Injector ***SOLD***
253 S13 KA24DE OEM Injector ***SOLD***
254 S13 SR20DET OEM Injector ***SOLD***
255 S13 SR20DET OEM Injector ***SOLD***
256 S13 SR20DET OEM Injector ***SOLD***
257 S13 KA24DE OEM Injector ***SOLD***
258 S13 LHD Black Dash (Good Condition) - Small Flaws Pictured ***SOLD***
259 S13 LHD Black Door Panels (Passenger Side Flaw Pictured) ***SOLD***
260 Used Circuit Sports Oil Catch Can ***SOLD***
261 Fake Ebay Greddy Blow Off Valve with Pipe/Flange ***SOLD***
262 Electric Fan $15.00
263 B13 SE-R Sentra Momo Steering Hub (Not sure if it fits S13) $45.00
264 Momo Steering Wheel Horn Button $15.00
265 S13 Silvia Ks Front Bumper/Foam/Bumper Support ***SOLD***
266 S14 KA24DE Auto Tranny Radiator ***SOLD***
267 S14 KA24DE Radiator Shroud ***SOLD***
268 S14 KA24DE A/C Condenser Fan ***SOLD***
269 S13 240SX Convertible Rear Sway Bar $15.00
270 S13 180SX (RHD) HICAS Steering Rack ***SOLD***
271 S13 KA24DE Radiator Shroud $20.00
272 S13 A/C Condenser ***SOLD***
273 S13 180SX Front Sway Bar $25.00
274 S14 KA24DE Auto Tranny Radiator $40.00
275 S14 KA24DE Radiator Shroud ***SOLD***
276 S14 KA24DE A/C Condenser Fan $15.00
277 S14 KA24DE Lower Radiator Hose $10.00
278 S13 Redtop SR20DET Assembled Cylinder Head $140.00 ***SOLD***
279 S13 HKS 3" JASMA Catback with Resonator Cut Out ***SOLD***
280 S13 SR20DET Redtop/Blacktop Cylinder Head (Machined for MLS HG, Oil passages cleaned, perfect cam bearing surfaces, a little pitting from detonation, new exhaust side guides, intake side checked out good, and it has been hot tanked. Newish valve seals included. Great overall shape!) $200
281 S13 SR20DET Oil Pump with only 600 miles on it. Machined .004" to match block for sale $80
282 S13 SR20DET Block with ACL Race Bearings sized for stock (600 miles). Needs to be either bored to 87mm or sleeved. Was bored to 86.5mm, then detonation killed the pistons. Some slight pitting on the edge/top of cylinder 1. Sleeves will for sure fix, not sure about boring. $80
283 S13 SR20DET Cams ***SOLD*** - Not Pictured Yet
284 S13 SR20DET Timing Set (Used, bought new 5 years ago) $60 - Not Pictured Yet
285 S13 SR20DET Used Water Pump (Bought new 5 years ago) $20 - Not Pictured Yet
286 S13 SR20DET Used Oil Pump (Bought new 5 years ago) $80 - Not Pictured Yet
96 S14: Grip Track Car
90 R32: Bucket List Car
92 S13: Just for Fun Car
Instagram: @SS.Maxey
Last edited by 2_Liter_Turbo; 01-02-2012 at 08:03 PM.. Reason: Updated - Sold More Parts
2_Liter_Turbo is offline   Reply With Quote
Old 02-21-2011, 07:02 PM   #2
2_Liter_Turbo
Trader Rating: (28)
Cam Caps and Cam Bolts are included!!! They were labeled when removed, and are installed now!
Old 02-21-2011, 07:12 PM   #3
xnissan240sx
xnissan240sx is an unknown quantity at this point
Hands down most organized for sale thread i have ever seen! Bump for you!
xnissan240sx is offline   Reply With Quote
Old 02-21-2011, 08:24 PM   #4
aceof07
aceof07 is an unknown quantity at this point
088 S13/S14 KA24DE EGR Tube $10.00, price shipped to 28314?
aceof07 is offline   Reply With Quote
Old 02-22-2011, 12:18 AM   #5
240sxdriftrat
240sxdriftrat is an unknown quantity at this point
Great thread post! Do u happen to have s14 5 speed speed sensor?
240sxdriftrat is offline   Reply With Quote
Old 02-22-2011, 06:28 PM   #6
2_Liter_Turbo
Trader Rating: (28)
Not sure honestly. I know I did at one point, but I think I used it on my convertible 5 speed swap. If I didn't, then one of the various speed sensors I have up is it, but I'm not sure on how to tell the difference!
$17 Shipped. PM me for paypal. Thanks!
Thanks! lol
Old 02-23-2011, 12:00 AM   #7
drb930
drb930 is an unknown quantity at this point
Do you have an S14 Auto Shifter?
drb930 is offline   Reply With Quote
Old 02-23-2011, 12:20 AM   #8
jdmjap808
jdmjap808's Avatar
jdmjap808 is an unknown quantity at this point
bump for you bro! super organized sale thread...
jdmjap808 is offline   Reply With Quote
Old 02-23-2011, 12:31 AM   #9
Wookie384
Wookie384's Avatar
Wookie384 is just really niceWookie384 is just really niceWookie384 is just really niceWookie384 is just really niceWookie384 is just really niceWookie384 is just really niceWookie384 is just really niceWookie384 is just really nice
Send a message via AIM to Wookie384
Damn, you are one organized OCD sonofabitch! haha lol
Wookie384 is offline   Reply With Quote
Old 02-23-2011, 12:38 AM   #10
murderrsirenss
murderrsirenss will become famous soon enoughmurderrsirenss will become famous soon enoughmurderrsirenss will become famous soon enoughmurderrsirenss will become famous soon enoughmurderrsirenss will become famous soon enough
Send a message via ICQ to murderrsirenss Send a message via AIM to murderrsirenss Send a message via Yahoo to murderrsirenss
Holy fucking shit. This is the most amazing thread ever.
murderrsirenss is offline   Reply With Quote
Old 02-23-2011, 12:49 AM   #11
Inland180
Inland180's Avatar
Inland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant future
Send a message via AIM to Inland180
BUMP for your time put into the thread!
PTE6262 Full-Race Twin Scroll FTW!
Feedback LINK
Inland180 is offline   Reply With Quote
Old 02-24-2011, 06:24 PM   #12
2_Liter_Turbo
Trader Rating: (28)
I do not.
Ha ha, you have no idea...
Lol, Thanks!
Old 02-24-2011, 06:56 PM   #13
nxt774
nxt774's Avatar
nxt774 is making a name for him/her selfnxt774 is making a name for him/her selfnxt774 is making a name for him/her self
already been said but its worth repeating, GREAT THREAD!!
would venture to say that if all post were like this one we'd have alot less BS on the site.
keep up the greatness
nxt774 is offline   Reply With Quote
Old 02-24-2011, 09:38 PM   #14
Fancy
Fancy is an unknown quantity at this point
Epic, enough said. Makes never want to look at another for sale thread.
Fancy is offline   Reply With Quote
Old 02-24-2011, 11:53 PM   #15
S13_ADDICT
S13_ADDICT's Avatar
S13_ADDICT is an unknown quantity at this point
I wish two things: 1) I was as half as organized as you. and 2) You had parts I actually need. GLWS
S13_ADDICT is offline   Reply With Quote
Old 02-26-2011, 09:17 PM   #16
1slicktwo4oh
Trader Rating: (45)
1slicktwo4oh is an unknown quantity at this point
Feedback Score: 45 reviews
Item #91 shipped to 90602
1slicktwo4oh is offline   Reply With Quote
Old 03-03-2011, 09:56 AM   #17
2_Liter_Turbo
Trader Rating: (28)
$25 Shipped
Ha ha, sorry I didn't have anything for ya!
Old 03-08-2011, 05:57 PM   #18
Shaftplay
Shaftplay is an unknown quantity at this point
Dang, now this is how you make a for sale thread! Nice work man! You have a PM!
Shaftplay is offline   Reply With Quote
Old 03-20-2011, 09:09 PM   #19
JDS Performance
JDS Performance's Avatar
Trader Rating: (53)
JDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of light
Feedback Score: 53 reviews
I need thealternatoer belt tensioner set-up - bolt/washer/nut that hold the alternator to the bracket - basically I need all the bolts/washers/nuts/hardware minus the brackets - I already have them
I also need the (2) turbo inlet pipe nuts/washers as well as the (3) bolts/washers for the turbo outlet pipe T25 turbo. I also need (2) turbo banjo bolts and crush washers for them.
The stock catch can "black box" and mounting bolts and hose.
A/C bracket with mounting bolts
LMK what all you got and prices. Thanks!
JDS Performance is offline   Reply With Quote
Old 03-20-2011, 11:10 PM   #20
ka-turbo
ka-turbo is making his/her stupidity well-knownka-turbo is making his/her stupidity well-knownka-turbo is making his/her stupidity well-knownka-turbo is making his/her stupidity well-known
i know its not on here buuut maybe youll conisder it...ill tkae your automatic brake booster only????
ka-turbo is offline   Reply With Quote
Old 03-27-2011, 09:52 PM   #21
2_Liter_Turbo
Trader Rating: (28)
Sorry, I do not have the hardware you need. The stock catch can is sold, and the KA24DE adj bracket stuff is pending.
I do not have one for sale, sorry.
Old 03-27-2011, 10:31 PM   #22
Seabass
Seabass's Avatar
Seabass is an unknown quantity at this point
sick sale! glwith it!
Seabass is offline   Reply With Quote
Old 03-28-2011, 08:59 AM   #23
bad dog
bad dog's Avatar
bad dog is an unknown quantity at this point
fan task tic sale ad
bad dog is offline   Reply With Quote
Old 03-28-2011, 09:16 AM   #24
97nismo
97nismo's Avatar
Trader Rating: (53)
97nismo is an unknown quantity at this point
item 261 shipped to 29625?
Feedback:
http://zilvia.net/f/itrader.php?u=78978
97nismo is offline   Reply With Quote
Old 03-28-2011, 09:51 AM   #25
Otto347
Otto347's Avatar
Otto347 is an unknown quantity at this point
bump for a proper sale thread.
Originally Posted by atutt View Post
Or you could have stopped being a lazy asshat and done some research.
Otto347 is offline   Reply With Quote
Old 03-28-2011, 10:00 AM   #26
koukimuncher
koukimuncher's Avatar
Trader Rating: (29)
koukimuncher is an unknown quantity at this point
Feedback Score: 29 reviews
badass thread lol
koukimuncher is offline   Reply With Quote
Old 03-28-2011, 10:13 AM   #27
240sxdriftrat
best For Sale thread! bumpppp
Old 03-28-2011, 10:13 AM   #28
bigs
bigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of light
This is how all for sale threads should be.
bigs is offline   Reply With Quote
Old 03-28-2011, 11:09 AM   #29
RB180sxChris
RB180sxChris's Avatar
RB180sxChris is an unknown quantity at this point
item #061 s14 intake mani assembly shipped to 08879 PM me thanks!!
RB180sxChris is offline   Reply With Quote
Old 03-28-2011, 11:29 AM   #30
Chaw wee
Chaw wee's Avatar
Chaw wee is an unknown quantity at this point
What part of Oregon are you in? Nice FS add, Bump
Chaw wee is offline   Reply With Quote
