Old 12-06-2010, 09:02 PM   #1
StryfeS13
It's Always Broken.
StryfeS13's Avatar
StryfeS13 is an unknown quantity at this point
Running coolant lines T25 on a KA24DE?
I searched and found a few threads on various forums, but every link is no longer working.
On a KA24DE intake manifold, where the top radiator hose goes, there is that little water line, that i believe goes under the throttle body. I was wondering how I can run that to my turbo? Pretty much I need a fitting that will screw in to the turbo itself that I can run the hose to..
I drew this in paint to hopefully show you guys what I'm trying to say.
Pretty much I need to know where to find a fitting like that, and it needs to be the same size as the nipple on the upper coolant passage is. I think it's 5/16..not too sure.
Originally Posted by KoukiMonsta
once its done you can drive it off a fucking cliff for making such a fucking stupid thread.
Gotta love Zilvia.
StryfeS13 is offline   Reply With Quote
Old 12-06-2010, 09:07 PM   #2
Sileighty_85
Sileighty_85's Avatar
so you've been to KAT.org?
If not search there
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-06-2010, 09:13 PM   #3
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
http://zilvia.net/f/tech-talk/176575...e-ka24det.html
Nope, those nipples screw into the bango's and are 5/16" O.D. then you use 5/16" I.D. and then you are now able to tap into the two water outlet ports located in the intake manifold, you now have the option of illiminating the coolant feed to the TB if you like. Theres always a method to my madeness
Old 12-06-2010, 09:37 PM   #4
StryfeS13
It's Always Broken.
StryfeS13's Avatar
UNISA JECS, the link is broken in your post.
2.) Http://www.wicksaircraft.com/catalog...252/index.html
For the easiest connection to the water return and outlet pipe you will simply need to bypass your coolant lines to your throttle body and also use these fitting to tap into your banjo supplied 1/4" NPT tap with these 1/4" NPT to 5/16" straight hose fitting (HARD TO FIND!!!)
$1.45 x 2
Gotta love Zilvia.
Old 12-06-2010, 10:21 PM   #5
xX240-SXx
xX240-SXx's Avatar
Trader Rating: (29)
xX240-SXx is an unknown quantity at this point
Feedback Score: 29 reviews
nice just what i need!!!!!!!!!!!!
xX240-SXx is offline   Reply With Quote
Old 12-06-2010, 11:31 PM   #6
StryfeS13
It's Always Broken.
StryfeS13's Avatar
I'm pretty sure this will work. Just found this
1/4" Npt X 5/16" Brass Hose Barb
Gotta love Zilvia.
Old 12-07-2010, 03:39 AM   #7
GroundPerformance
GroundPerformance's Avatar
Trader Rating: (44)
GroundPerformance is an unknown quantity at this point
Feedback Score: 44 reviews
It's a T25 Journal bearing turbo save the trouble and $$ use that on a turbo timer instead. If you're running a BB turbo then you will definitely need it.
GroundPerformance is offline   Reply With Quote
Old 12-07-2010, 04:09 AM   #8
nieko
nieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfection
Yeah...
t25, who the fuck cares about water lines?
all they do is cool down the turbo when the car is OFF.
drive like a normal human being for a few minutes after hotlapping, let the car idle for a little, shut off.
done.
nieko is offline   Reply With Quote
Old 12-07-2010, 04:37 AM   #9
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
I used those barb bearings on another setup, heres a pic of an almost complete oil/water line setup I have right now thats going on my P11 G20t
